Go Back   Chevy and GMC Duramax Diesel Forum > Non Duramax Discussion > Gas Burners
Gas Burners Discussion of anything Gas powered.
Old 02-14-2009, 06:39 PM   eBay Motors  #1 (permalink)
Shake and Bake
rap2orrider660R's Avatar
Calling all Gas Motor Techs
My dad has a 1999 chevy 454, he is having a killer time starting it up..Sometimes it will start right up, and sometimes it takes 5-6 seconds of cranking before it starts up... and when it finally starts there is a small puff of blueish whiteish smoke comes from the tail pipe, and smells rich of gas. He just replaced the fuel pump, I belive he as also replaced the fuel pressure regulator. The odd thing is we also had a 1999 454 work truck for our company and it also had the exact same problem. Does anyone know of a common problem with this year model and engine type??
And yes, I already told him to get a D-Max, but he is sticking with the truck he has. And the D-Max is hard to find in a Suburban.
Aaron Blackwell
Cen-Tex Marine
Proudly Serving the Marine and Oil Industry
2007.5 D-MAX, EDGE DIGITAL GAUGES, QUADZILLA WITH DPF DELETE, TUNED AT 90HP NO MORE NO LESS, STRAIGHT PIPED, 17" CHROME SHAKER RIMS WITH 285 70 17 BFG KM2 MUD TERRAIN TIRES, AIR BOX MODIFIED,BUSHWACKER BED CAPS, RECON SMOKED LOW PROFILE CAB LIGHTS AND MORE TO COME (I HOPE)
rap2orrider660R is offline   Reply With Quote
Old 02-14-2009, 07:18 PM   eBay Motors  #2 (permalink)
Duraski's Avatar
Did he change the fuel filter when he changed the fuel pump? Just a thought. Also did he check the rubber neck that attaches to the fuel pump when he put the new pump in? My brother in-law had the normal gas fuel pump going out symptom(started that morning, then wouldn't start when he shut it off), pickup had about 150K so we replaced the fuel pump, as we were finishing up the pump swap we noticed a crack in the rubber connector neck and that could have been the problem, went ahead and finished installing new pump since the old one was on borrowed time any way. Just my .02.
2002 2500HD Dur/Al CC SB LS 4x4 Sprayed in bedliner, Sun Visor Star Board running boards from previous owner. Edge w/attitude is installed again.
Next Mods when I have the Cash
4" Stainless Exhaust Single Or Duals?
www.alligatorperformance.com
Duraski is offline   Reply With Quote
Old 02-14-2009, 08:02 PM   eBay Motors  #3 (permalink)
smog's Avatar
if the truck is sitting for long time and it takes long cranck : the fuel is draining back to the tank : this is why it takes long time to crack : the fuel pump have to built pressure back to the line and then to the injectors. there is check valve built in the fuel pump itself. even thou you have new pump. you have bad check valve. test the fuel pressure drop in return fuel line.
smog is offline   Reply With Quote
Old 02-14-2009, 08:28 PM   eBay Motors  #4 (permalink)
DuramaxSMOKE11's Avatar
i would check the spark plugs also to see how its been running. also i would then check cranking fuel pressure. i has anyone put injectors in the truck at all? i ask this because being that i own a few to many gas chevys i have seen guys put injectors in and pinch the o-rings and they dump fuel in the cylinders
Mike
2005 Chevy 2500HD Duramax LLY
BANKS ram air intake, MBRP 4" exhaust, CAT DELETE and NO MUFFLER, EGR Deleted, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, PPE standard, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
To come soon
AFE Intercooler, Raptor 150 pump, SunCoast tranny & TC
Big thanks to chad at Alligator performancewww.alligatorperformance.com
DuramaxSMOKE11 is offline   Reply With Quote
