gas to diesel conversion information - Chevy and GMC Duramax Diesel Forum
Gas Burners Discussion of anything Gas powered.
post #1 of 15 (permalink) Old 02-16-2010, 08:34 AM Thread Starter
I kinda in the research process and testing the water on this idea. I'm wanted info on a gas to duramax diesel conversion. Whats the process of this besides swapping the engine and trany? What about the truck frame for the weight of the diesel engine? Its a 90 C2500 chevy 8 lug 2wd 8600 gross weight.
davbell22602 is offline
post #2 of 15 (permalink) Old 02-16-2010, 08:48 AM
Its just a worktruck
DMAXchris's Avatar
It would probably cost more for the swap than it would to just go out and buy a used duramax.
06 LBZ EC/LB 4x4
Built Motor/Trans Bullseye s475/87/.9 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76 @ 115
DMAXchris is offline
post #3 of 15 (permalink) Old 02-16-2010, 08:51 AM Thread Starter
Even if the duramax engine and trany needed rebuilt before the swap and I did the rebuild work myself?
post #4 of 15 (permalink) Old 02-16-2010, 08:56 AM
DMAXchris's Avatar
A full rebuild costs almost 4 grand for the engine alone. Trans is another 3K. Then you need the rear end, dash cluster, ecm, tcm, bcm, driveshaft, wiring harnesses, and other misc items. Royal PITA if you ask me.
06 LBZ EC/LB 4x4
post #5 of 15 (permalink) Old 02-16-2010, 09:34 AM
gr8shot's Avatar
Best route would be a 12 valve cummins swap. Takes like what 3 wires to make it run? and all of the parts needed for a swap are readily available in the aftermarket community. It would be a much easier swap, and it's very common in that generation of chevy's. I've got a 95 3/4ton 2wd just begging for one
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline
post #6 of 15 (permalink) Old 02-16-2010, 10:55 AM Thread Starter
Whats involved in the v8 cummins swap then?
post #7 of 15 (permalink) Old 02-16-2010, 06:41 PM
gr8shot's Avatar
It's not a v8, the engine you'd want is an inline 6 cylinder. One of the best diesel engines out there. There's a couple different forums dedicated to just cummins swaps into other vehicles. The one I know of is called 4btswaps.com there should be tons of info out there in that site alone. Plus links to vendors who carry all the parts necessary to make it work.
Jesse
2004 LB7
Tastefully modded
Lots of miles
gr8shot is offline
post #8 of 15 (permalink) Old 02-16-2010, 06:55 PM Thread Starter
so the 5.9 is a inline 6?
post #9 of 15 (permalink) Old 02-17-2010, 07:49 AM
DMAXchris's Avatar
Yes. The motor you would want is a 12 valve Cummins from the mid 90's. They are extremely simple and have no computer controls. Like Jesse said, it takes very little to get one to run in any vehicle. Much easier and less $ than a Dmax swap.
We're not trying to say it cant be done or discourage you in any way. But in reality putting a Dmax in anything other than a GM pickup is a little hairy and not very easy.
06 LBZ EC/LB 4x4
post #10 of 15 (permalink) Old 02-17-2010, 07:52 AM
SzymoDmax's Avatar
my vote is a 12 valve, but you will have about 5 grand in the coversion.... ask me how i know
DUSTIN...04 LLY DMAX
EFI LIVE DSP 5 BY IDAHOROBhttp://www.atptrucks.com/
Danville 66mm stg2
GMax5 + ML Built by me
airdog II,AFE MP+Intercooler tubes http://www.meyerperformance.com/
7" Cognito Lift XD Monsters and 35"s,7" FTE Single stack, Tracton Bars, all the front end goodies, egr blocked, FRSK, 06 grill/ hood/mirrors, sunroof, 50g transfer flow tank and many more
1983 chevy 12valve cummins, nv4500,and some other stuff
Let men marry men and women marry woman...in 3 more generations there will be no more democrats
SzymoDmax is offline
