Electrical problem - Chevy and GMC Duramax Diesel Forum
post #1 of 5 (permalink) Old 08-02-2011, 03:10 AM Thread Starter
Electrical problem
Hey I have a 2004 gmc sierra 2500hd duramax. I went to start my truck today but it seemed like the batteries were dead because I had no power so I got someone to boost me the positive cable kept slipping off but eventually got it started but when I got it started I stilled had no power to anything so I drove it for about five mins then tried to shut it off but it wouldn't it would just flicker some light when I turned the key back so I started looking at the fuses and noticed the stud 1 was blown and the ign/edu relay kept clicking every so often so eventually to turn the truck off I pulled that relay then put it back now even with the ignition in the off position I have a few dim blinking lights I tried starting the truck again it will turn over and almost sound like it's about to start then die but once in awhile it will stay running but same problems have to pull the relay to shut it off I tested all the other fuses under the hood and there good but I pulled the stud 1 fuse and tested where it plugs into with a multi meter and there's no power even getting to the fuse. I don't know seems like a electrical mess to me but if anyone has any ideas that would be great thanks
vickery18 is offline
post #2 of 5 (permalink) Old 08-02-2011, 03:33 AM
xsivspeed454's Avatar
First thing I would do is pull your battery connections and make sure they are not all corroded. Then I would look into the problem further, but you need to start with the basics.
2003 CCSB 4x4
EFI Tuned by ATP -PPE Stage 5 -Silverline 4" Exhaust -MBRP Downpipe -PPE Boost Valve -CAI -Ported Intake Horn -Autometer Boost & Pyro -Airdog II 165
xsivspeed454 is offline
post #3 of 5 (permalink) Old 03-12-2015, 10:24 AM
2007 duramax desiel no power to dash. checked everything plus all fuses nothing. then all of a sudden windshield wiper go across once then nothing. any ideas?
marcia is offline
post #4 of 5 (permalink) Old 03-15-2015, 06:41 AM
Administrator
jc1843's Avatar
Moved to wiring
jc1843 is offline
post #5 of 5 (permalink) Old 03-15-2015, 12:05 PM
J83
J83's Avatar
07 OBS or NBS? electrically they are totally different.
2001 Chevy Silverado 2500 HD 6.6L LB7
Allison Transmission (stock)
Banks six gun | Banks intake | Fabtech Tierods | ARP head studs | Kryptonite UCA | PPE Blue placebo valve | Batmo lagwheel| Red Head Gear box
J83 is offline
