Installed Recon Smoked Cab Lights - Chevy and GMC Duramax Diesel Forum
Old 11-04-2012, 05:50 PM   eBay Motors  #1 (permalink)
anthonyshaw's Avatar
Installed some Recon smoked cab lights (hoping for no leaks, siliconed the crap outta them)
One question tho, I built a relay and triggered it from the brown/white wire that goes to the headlight switch assembly, but that only turns them on when the truck is running and the parking lights are on. I would like for them to turn on when the lights flash with the lock/unlock and when the truck is remote started and the parking lights are on, does anybody have any idea what wire i need to trigger my relay from for that?
anthonyshaw is offline   Reply With Quote
Old 11-11-2012, 12:36 AM   eBay Motors  #2 (permalink)
GMC04LLY's Avatar
Looks great, have no idea for an answer to your question, but did you install them your self or did you have some one do it? I am needing my headliner redone (sinking down a bit in the back) so I figured when I have that done I would get the cab lights installed then. Two birds one stone.
GMC04LLY is offline   Reply With Quote
Old 11-11-2012, 05:59 AM   eBay Motors  #3 (permalink)
polarisiq93's Avatar
I had mine installed and they didn't flash when I would unlock the truck either like other trucks I've seen. I took it back to him and now they flash. I'm not sure what exactly he did
Sent from my iPhone using Autoguide.com App
07.5 LMM ccsb ltz MATTE BLACK
8 inch fabtech lift,36x15.50 baja mtz's,20x12 fuel nutz,reflexxion hood,x-metal grille,s&b cai,8k hid's,dsp5 by Kory Willis,mbrp 5 inch TB,mbrp dp,7" black chrome stack,PPE boost and pyro gauges,edge insight cts,bd blow off,egr delete,pcv re-route, alpine touch screen, 2 10" type r's
polarisiq93 is offline   Reply With Quote
Old 11-11-2012, 08:01 AM   eBay Motors  #4 (permalink)
KensAuto's Avatar
on my lml, i used the actual stock connector on rt side of dash, found the pin that worked w/lights on, and it does what you want, flashes w/rest of lights. I can take a pic if you want. Did not need a relay either
2012 GMC 2500 SLT 4x4
H&S minimaxx, MBRP downpipe back SS duals, Insight CTS w/backup cam, Fass HD150, PPE rear diff cover, Amsoil front to rear w/by-pass
Cognito 4-6 NTBD w/idler/pitman braces, a-arms, Monster energy 18x9 w/BFG KM2s 35x12.5, Recon smoked cab lights
Titan 57 gal saddle tank, linex color matched bedliner w/kevlar, Trekstep bed steps x2, RBP rail steps
KensAuto is offline   Reply With Quote
Old 11-11-2012, 09:17 AM   eBay Motors  #5 (permalink)
dieseladdiction23's Avatar
I wired mine into the parking light and they flash when unlocked/locked
2004 lb7 ccsb 4x4. Efi live tuned by Rob at ATP, ARP head studs, tie rod sleeves, cognito traction bars, airdog 165, ppe boost valve, turbo horn, s&b cai, LML driver side manifold, cat fuel filter adapter 1r-0749, installed cab lights and tow mirrors. NBS back seats. 6 inch zone offroad lift lowered down and running 305/55/20, optima red tops, Mbrp 5 inch turbo back straight pipe exhaust.
Soon to come: Built trans, Built motor, and twins
dieseladdiction23 is online now   Reply With Quote
Old 11-11-2012, 11:12 AM   eBay Motors  #6 (permalink)
silver_lml's Avatar
Hey ken, could you post that pic? Im thinking on installing a set, i put them on my dodge and it wasnt bad. On the dodge there was the stock plug on the pass pillar and it worked great. It sounds like you got just what im looking for.
Tyler
2011 GMC 2500HD SLE CC/SB 4x4 __ B&W turn over ball, added tow mirrors with signals, Go Rhino Dominator III nerfs, cranked T-bars(stock keys), Zone shock ext, RS5000 stabilizer shock, 35x12.50 Toyo M/Ts on stock 20's!
silver_lml is online now   Reply With Quote
Old 11-11-2012, 01:30 PM   eBay Motors  #7 (permalink)
KensAuto's Avatar
Top row of pins, second one from left
Sent from my SCH-I510 using AutoGuide App
Old 11-11-2012, 02:03 PM   eBay Motors  #8 (permalink)
silver_lml's Avatar
Thanks!!!
Tyler
Old 11-11-2012, 02:13 PM   eBay Motors  #9 (permalink)
Looks good
Had 2008 f250 6.4-GONE
Now looking for duramax
jfrewjr is offline   Reply With Quote
Old 11-11-2012, 05:46 PM   eBay Motors  #10 (permalink)
I did the install myself... definitely a nervous wreck drilling holes in the roof of the truck for the wire connectors (3/8" hole or a little larger)
