HID and radio reception - Chevy and GMC Duramax Diesel Forum
Old 11-10-2012, 11:42 AM   eBay Motors  #1 (permalink)
Hey guys, Just got new HIDS in my truck lows and fogs. All of a sudden I am getting terrible radio reception. I can only get one radio station and its staticy. I talked to the guy at the shop who installed them and asked if I could possibly have a bad ground. He said its all plug n play stuff so he didnt ground it. Anyone have any ideas?
2006 LLY 4 door short bed, EFI LIVE, 5in turbo back, cold air intake, 6in lift on 35in NITTO Mud Grapplers
ckyaj is offline   Reply With Quote
Old 11-10-2012, 07:38 PM   eBay Motors  #2 (permalink)
What brand HID's are they? Shitty quality HID's will wreck your radio reception. If the ballasts are properly shielded, then you shouldnt have any problems.
So basically, the problem is whatever brand HID's you have.......they arent shielded properly. Theres nothing you can do to "fix" it.
Ben
05 dmax/allison
duratothemax is offline   Reply With Quote
Old 11-12-2012, 03:02 AM   eBay Motors  #3 (permalink)
There race sport HIDS. Apparently they are supposed to be really good quality. I bought them off car teks a place by me. They said they started using them because of quality. What do you mean by properly shielded I dont really no anything about HIDS. I have heard they sell a relay that will reground the kit so help elimnate radio problems. Or get a different frequency ballast to change problem
Old 11-12-2012, 06:26 AM   eBay Motors  #4 (permalink)
POWERTRIP's Avatar
Supposedly really good quality HIDs are made overseas and don't import them into the US because of the laws around them (aftermarkets anyway). The ones made here in the US are not of high quality and getting interferrence from the ballasts of these US made units are a common problem. I was thinking of puting them in my truck and was doing some internet research on it and that is why I am staying with the Halogens. I don't want any unwanted gremlins that cost money.
04.5 GMC Sierra 2500HD SLT LLY, 4X4 CCSB, Bill's Custom Intake Stage 4, S&B Powerstack filter,LBZ MP, 4" turbo downpipe into 5" exhaust, 7" MBRP tip, EFI Live w/ dsp5, Resonator plug, PVC rerouted and plugged, level kit, 33" BFG's, all-on mod
7-6-2011
Head Gaskets, ARP Headstuds, Full EGR Delete, Aftermarket exhaust manifold, Race Valve.
Coming soon:
CTS INSIGHT, AIR DOG II Lift Pump, Smoked tail Lights, Smoked cab clearance lights, Lift kit, and Built trans.
POWERTRIP is offline   Reply With Quote
Old 11-12-2012, 07:11 AM   eBay Motors  #5 (permalink)
HID's have always given me issues with my Ham Radio until I did the following:
1) Make sure all of your HID's are run through a relay harness
2) Install some Ferrite Chokes on the ground wires of the HID's
akcooper9 is offline   Reply With Quote
Old 11-12-2012, 07:17 AM   eBay Motors  #6 (permalink)
spoolinLLY's Avatar
My DDM tuning hid screw up my radio reception also. If i turn the hid on my fogs it gets worse. Its really annoying. At night i can't listen to my radio or driving into work in the dark early morning.
spoolinLLY is offline   Reply With Quote
Old 11-12-2012, 07:21 AM   eBay Motors  #7 (permalink)
DDM is just a ballast and a bulb....you need relays at a min to start loving your problem
Old 11-12-2012, 07:29 AM   eBay Motors  #8 (permalink)
spoolinLLY's Avatar
What do the relays look like or where can i get some. When i put the kit on it plugged right into the factory plug. I didn't know i needed relays
Old 11-12-2012, 07:37 AM   eBay Motors  #9 (permalink)
Xenon HID Conversion Kit Relay Wiring Harness H1 H8 H9 H11 9005 9006 9140 9145 | eBay
One relay harness with do one beam (you will need two if you have HID's in your high beams and low beams...and a third relay if you have them in your fog lights)
Not sure what year truck you have but make sure the harness you buy is compatible with the stock bulbs on your truck so they are just a plug and play deal.
For example, my 02 uses 9006 and 9005's for the high/low beams so the above link will work.
To figure out which bulb your truck has, you can use the below link
https://www.sylvania.com/en-us/appli...s/lrgmain.aspx
Old 11-12-2012, 01:45 PM   eBay Motors  #10 (permalink)
I highly doubt doing a relay is going to fix the problem. But you can try...
05 dmax/allison
