| Gauges, Electronics and Wiring. A place to discuss electronic / wiring issues and what gauges, audio, video, nav systems, lights, ect. are right for you. |
| Junior Member Join Date: Sep 2011 Location: Alaska
| Map lights reading lights lamps Ok I retrofitted my reading lamps map lights with LEDs. But when you energize them with the button they are dimmer than if you energize them with the dimmer switch is there a work around to get the full intensity of my led when each lamps button is depressed? |
| Junior Member Join Date: Oct 2011 Location: Morris, Oklahoma
| Have this same problem. Don't know what causes it sub'd to see if someone knows.
__________________ 04 CCSB, Lb7, 135k, PPE, Full exhaust, K&N cold air, Full h.i.d's, Diamond cut black lens headlights and Tail lights, Eclipse Double Din Nav, upgraded bose, all leather. |
| DuramaxForum Veteran Join Date: Jun 2007 Location: michigan
| ttt I am wanting to put LED's in mine also. Any ideas??
__________________ Rodger 07 classic crew cab long bed 2wd 2500 650,605 miles on 2-14-13. Rotella T oil. Have replaced entire fuel system, sending unit to injectors, lines included, Waterpump last year, hydro boost, besides that truck is factory original except ujoints and brake pads 3.73 rear, stock tire size bully dog , 5 inch turbo back, with 6 inch tip. rTitan 55 gallon aftermarket tank 115 gallon auxilary tank ![]() 5% tint on all windows, and "eyebrow" on front ![]() 86 burgandy Monte Carlo SS |
| Junior Member Join Date: Jun 2012 Location: Central Washington
| Is your truck in drive. My leds are dimmer when in drive.
__________________ 1969 Camaro with 2009 LY6 6.0 engine 2001 honda accord v6 (wife) 2005 GMC 2500 HD SLT 06 LBZ intake and turbo mouth piece, 4 inch straight exhaust, cat delete, PPE fuel rail shim kit, PPE EGR delete, air bags, 45 gallon custom fuel tank, resonator delete. EFI live switched by Edge CTS insight ![]() Jesus loves YOU, Have you asked Him to be your Savior yet? |
