Passenger lights out - Chevy and GMC Duramax Diesel Forum
post #1 of 24 (permalink) Old 11-26-2012, 06:25 AM Thread Starter
Cknight199's Avatar
My passenger tail lights are out as well as the fender lights (dually). Was thinking its the bulb, but then noticed the fender lights out as well, brake light still works but nighttime running tail light doesn't work, thanks!
Caden
LBZ, Built Motor. S483, Plenty of fuel.
Cknight199 is offline
post #2 of 24 (permalink) Old 11-26-2012, 06:28 AM
Administrator
jc1843's Avatar
Always check the bulbs FIRST.
jc1843 is offline
post #3 of 24 (permalink) Old 11-26-2012, 06:31 AM Thread Starter
Cknight199's Avatar
Okay how does one go about removing the taillight? Is it as easy as the headlights?
post #4 of 24 (permalink) Old 11-27-2012, 01:03 PM Thread Starter
Cknight199's Avatar
Bump, has anyone ever changed the brake bulbs to be brighter? Are there any kits that make the stock housing have LED's? And is your brake light and brake running lights the same bulb?
post #5 of 24 (permalink) Old 11-27-2012, 01:07 PM
duramaxallison's Avatar
To remove the tail light open your tailgate and there should be 2 screwes holding it in. And yes the brake light and running light is same bulb, it should be a double filament bulb.
You say your fender flare lights are'nt working too...does the front passenger running lights work? Almost make me think its a fuse.
2003 LB7 2500HD ECSB
-Edge Evolution CTS
-MBRP 4" w/ 5"tip
-Banks Ram Air
-35w AGT 6000k HID's
-5% tint allaround
-285/75R16 Michelin LTX A/T 2s
-340k miles and counting
-Daily Driver
duramaxallison is offline
post #6 of 24 (permalink) Old 11-27-2012, 01:11 PM
SuperBright LEDs are who I've always used for LED replacement. He's right about the two screws for the housing removal, not sure on your fender lights though.
Auston KCCO
2014 EX-L V6 Accord Coupe White
2013 Ducati Hypermotard SP Ducati Corse livery
2009 GMC D/A CC/SB 4x4 SLT 41,xxx mi. Sold
DuramaxxedLMM is offline
post #7 of 24 (permalink) Old 11-27-2012, 01:28 PM
Fender lights you have to reach behind the fender and turn them a quarter turn and they come right out.
-Edge Evolution CTS
-MBRP 4" w/ 5"tip
-Banks Ram Air
-5% tint allaround
-Daily Driver
post #8 of 24 (permalink) Old 11-27-2012, 02:02 PM Thread Starter
Cknight199's Avatar
Update, checked all bulbs, all good, checked running light and both are not working...
post #9 of 24 (permalink) Old 11-27-2012, 02:08 PM
Check the fuse for the running lights, I belive its in the fuse box on the drivers side of the dash, I know fuses for trailer lights are in there but I dont remember about the truck lights. Should be a left and right side fuse.
-Edge Evolution CTS
-MBRP 4" w/ 5"tip
-Banks Ram Air
-5% tint allaround
-Daily Driver
post #10 of 24 (permalink) Old 11-27-2012, 02:18 PM Thread Starter
Cknight199's Avatar
Update, checked all fuses in dash and under hood, no luck... Checked every fuse that had anything to do with lights... No luck whatsoever. Kindof a bummer pulling fuses thinking,"this one says right rear parking and side marker lamps! This fuse is the problem!" Then pulled it and its perfectly good... Any other ideas? I'm going to follow the wiring..
