| Gauges, Electronics and Wiring. A place to discuss electronic / wiring issues and what gauges, audio, video, nav systems, lights, ect. are right for you. |
| DuramaxForum n00b Join Date: Dec 2012
| 07 silverado keyless entry I bought an 2007 silverado 2500 it doesn't have keyless entry can I just buy a key fob and program it or do I need a aftermarket alarm system thanks joe |
| Duramax Forum Supporter Join Date: Apr 2007 Location: Wyoming
| what body style is it....? Is it a 2007 GMT-800 (classic body style) or 2007.5 GMT-900? (new body style) Does it already have power windows?
__________________ 05 dmax/allison |
| Sorry it's a classic with power windows and power locks |
| If it has power windows and locks, you can add it. Im actually surprised it doesnt have it...almost all classic trucks with power windows and power locks come with remote keyless entry by default. Since you just bought it, Id be willing to bet it actually does have keyless entry, and the previous owner simply just lost all the remotes....... ![]() Look at the glovebox RPO sticker and see if you see the following codes: "AU0" "A31" and "AU3". If you have all three of those codes listed, then your truck already has remote keyless entry and all you have to do is buy a new remote and follow the programming procedure that I listed below... If it doesnt ahve all three of those codes listed, that means it doesnt have keyless entry, BUT you can add it.......to add it, you'll need to buy the remotes (you can find them on ebay for like $20, make sure you get the proper remote though, for a 2003-2007 pickup), and you might need to have the dealer reprogram/reflash the BCM (body control module) with a Tech 2 to add/activate the keyless entry feature. Im not 100% sure it will need to be programmed though, it might work without being reprogrammed? To program the actual remotes themselves, follow these steps: 1. Close all the vehicle doors. 2. Insert the ignition key into the ignition lock cylinder. 3. Press and hold the door unlock switch. 4. While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF. 5. Release the door unlock switch. The doors will lock and unlock to confirm the program mode. 6. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter. 7. Repeat the previous step to program up to 4 transmitters. 8. Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter programming mode. 9. Operate the transmitter functions in order to verify correct system operation. SO basically what I would do is...buy a remote on ebay. Try the programming procedure I posted above. If it doesnt work the first time, try it again. Then if it still doesnt work, you'll have to go to the dealer and have them reflash the BCM. Depending how nice your dealer is, they might do it for free, or they might charge you the minimum allowable labor time (usually 1 hour or something, which kinda sucks because the actual reflash procedure only takes like 5 minutes) ben
__________________ 05 dmax/allison Last edited by duratothemax; 12-11-2012 at 07:09 PM. |
| Thanks alot for the info I will let you know how it goes. Thanks afain |
| | eBay Motors #6 (permalink) | |
| Senior Member Join Date: Mar 2012 Location: Shelby Township, MI
| Quote:
__________________ 2006 Silverado CCSB LBZ 1995 Tahoe (Off Road Truck) 1984 Monte Carlo 1969 Camaro (Still in the Works) | |
| | eBay Motors #7 (permalink) | |
| Quote:
If your truck has power windows, you can add remote keyless entry easily. If your truck has manual windows and manual locks, you basically cant add it (huge PITA), just do an aftermarket setup. If your truck has manual windows but power locks, same as above, you basically cant add it. Note this only applies to 2007 and older GMT-800 classic trucks. I dont know about adding keyless entry to 2007.5+ GMT-900's, I would have to do some research.
__________________ 05 dmax/allison | |
| Don't see it. But I have power windows and locks. That was a must for me when looking at trucks. ImageUploadedByAG Free1355352749.508090.jpg Sent from my iPhone using AutoGuide.com Free App
| Well I ordered a remote off eBay so we will see if programing it myself will work or not.
| | eBay Motors #10 (permalink) | |
| Quote:
