Edge CTS Insight vs overhead gauge pod vs a pillar gauge pod - Chevy and GMC Duramax Diesel Forum
View Poll Results: CTS vs Overhead gauges vs A pillar gauges
CTS 41 62.12%
Overhead Gauges 3 4.55%
A Pillar Gauges 22 33.33%
Voters: 66. You may not vote on this poll
Old 12-13-2012, 02:59 PM   eBay Motors  #1 (permalink)
FarmerBill's Avatar
Just like it says which one do you prefer. I have an 04.5 LLY and I am trying to pick a direction to go with for gauges. Also what are the pros and cons you guys have found with your gauge setups.
FarmerBill is offline   Reply With Quote
Old 12-13-2012, 03:23 PM   eBay Motors  #2 (permalink)
Diesel Enthusiast
MaxnSaxon88's Avatar
Sub.d
05 lly
Leveled
Efi Live w/dsp5
diamond eye 5in tb straight
Banks ram air intake
Pcv re-route, Egr Blocker Plate, Cts Insight
305/55/20 Nitto Trails w/ BMF Repr
Soon to come: Stage 5 Tranny, Lift pump
MaxnSaxon88 is offline   Reply With Quote
Old 12-13-2012, 03:26 PM   eBay Motors  #3 (permalink)
ALLY Cat's Avatar
I like the idea of having an analog EGT gauge always at eye level, always on. An Insight would make a good addition for checking other parameters or double checking the analog EGT readout from time to time. I tow a lot and keep an eye on exhaust temp, it gives an early warning of potential overheating.
2004.5 GMC SLT 4X4 CCLB LLY Ally, EFI Live V2 & DSP5 by Rob, Ride Rites, LBZ turbo inlet mod, po' man CAI, HIDs, stock height, Cognito tie rods, Bilstein 5100s, Isspros, H2 wheels with Toyo OC 285-70-17s, B&W turnover & Companion, Prodigy P3, dog snot on windows......
ALLY Cat is offline   Reply With Quote
Old 12-13-2012, 07:58 PM   eBay Motors  #4 (permalink)
SGMdmax's Avatar
I have the CTS mounted in the overhead counsel. Out of the way and out of site from thieves. Nice gauge that monitors a lot of info.
Be aware there are a few issues with the CTS and a few threads on hear. Mine has to be unplugged and plugged back in about one in ten when you start the truck.
2007 GMC Sierra Classic LBZ CCSB 4x4
LineX bedliner, Nasta SS Nerf Bars, 265/75R16 Revo 2 tires , front windows tinted to match rear, Tekonsha P3 brake controller, Bilstien 5100 shocks, MBRP 4" turbo back exhaust, Edge Insight CTS, EFI from ATP.
SGMdmax is offline   Reply With Quote
Old 12-13-2012, 08:20 PM   eBay Motors  #5 (permalink)
NEDuramax's Avatar
Thats weird that it does that. Is that a common problem? b/c ive had mine for almost a year now and have never had to unplug it for that reason...
But yeah I love my CTS, I have the EGT probe with it, itll chirp at you if the temps are getting too high as well as for any other things that go out of whack
____________________________________
~2005 GMC Sierra 2500HD CCSB SLT 4x4~
EFI Live DSP5 by Idaho Rob*Edge Insight CTS/Diamond Eye Downpipe/4" Duals (Husker Diesel)*Nicktane Filter Adaptor*LBZ intake/mouthpiece*All emissions bs GONE
NEDuramax is offline   Reply With Quote
Old 12-13-2012, 08:22 PM   eBay Motors  #6 (permalink)
FarmerBill's Avatar
I've been leaning towards a boost and egt gauge in the overhead console problems like that are part of the reason I'm leaning away from the edge.
Old 12-13-2012, 08:41 PM   eBay Motors  #7 (permalink)
nvrplzd's Avatar
I love my CTS. If i didn't already have an egt gauge i'd run an expandable probe to it in a heartbeat.
I run an analog boost since to read higher psi than the edge and then have the cts also sitting in my pillar.
Absolutely digging this setup
Tyler-
2007.5 3500HD SRW Long N' Looow
EFI by Kory Willis, DJM, DPC, PPE, Airdog, Nitto, Profab, Airlift, Cognito.. just to name a few.
4094 removed, back to stock turblow again
Currently piecing together an s400 setup
2004.5 LLY Ext Cab 8' ~EFI, Fabtech 6" and much, much more.. SOLD
nvrplzd is offline   Reply With Quote
Old 12-13-2012, 08:50 PM   eBay Motors  #8 (permalink)
boostnlb7's Avatar
i have three pillar gauges, mechanical i believe.. i trust them, soon i will hav a cts also to monitor more pyrameters.. other than that my pillar gauges havent let me down yet in 2 yrs...i also run a dsp5 switch, kinda think i shoulda went with a monitor to switch tunes with.. overall im satisfied..diff varities will work better than others
couldnt pass hazing to be a "pup bro"
03 lb7 ccsb 4x4-6" bds- 20"mkw's- p195/65/14 intercos-
auto meter boost/pyro/trans gauges- traction bars- 5'' DE straight pipe- PPE BIV- AD II 200 lift pump- edge insight CTS- spectre CAI- 45% over injectors- LMM cp3 & FPR -EFI live dsp5 flashed by tony burkhard with danville tunes- thanks to Brent @ Lincoln Diesel
boostnlb7 is online now   Reply With Quote
Old 12-13-2012, 10:21 PM   eBay Motors  #9 (permalink)
lparrill's Avatar
I have both and couldn't go back to one or the other. CTS w/ mechanical boost and pyro FTW
Levi
04 CCSB White LLY - Carrillos l Mahle Fly Cuts l Studs l Stage 2 heads with Socal Nitrous Cam l Manifolds l Up- pipes l 3" IC pipes and Y-bridge l Suncoast GMAX5 w/ 1058 l II Dual Feeders l II 40 over Injectors l Airdog II l Danville 72mm l Zex Nitrous l Traction bars l BT Lock up box l Airdog II l exterior/interior stuff
92 3000GT VR4
69 Mustang Mach 1
lparrill is offline   Reply With Quote
Old 12-14-2012, 12:43 AM   eBay Motors  #10 (permalink)
usafduramax's Avatar
I'm oldschool I like a-pillar.
usafduramax is offline   Reply With Quote
