| Gauges, Electronics and Wiring. A place to discuss electronic / wiring issues and what gauges, audio, video, nav systems, lights, ect. are right for you. |
| Duramax Forum Supporter Join Date: Jul 2011 Location: Fort Worth, Texas
| Cab Lights Not Working I have a 07 classic LBZ with smoke black Pacer Performance cab lights. About 3 months ago the lights started turning off and on when I started my truck. sometimes all of them would work and other times the middle bar would not come on. I Think there is a bad ground, but my friend told me that the middle bar might be bad. I haven't tried to replace the bulbs (I wouldn't think they would go out that quick). Can I change the bulbs without having to take the ceiling of my truck down?? I know they are sealed shut. Any help would be appreciated,I'm new to the Duramax Forum Thanks!! |
| Junior Member Join Date: Sep 2009
| i had the same problem, and was the housings were leaking and making a bad connection and the lights wouldnt come on
__________________ 2006 ccsb lbz 7-9'' cognito with 37'' toyos on xd hosses 4.56 gears and a truetrac 4" diamond eye with dp bd full bore manifold banks air intake with scoop alpine in dash nav with dvd and backup camera 4 jl audio tens www.performancetruckproducts.com |
| DuramaxForum n00b Join Date: Aug 2012 Location: Gregory Michigan
| Sounds like either a bad ground or lose or dirty connector, if you slightly pull down the front of the headliner not hard just a bit you should be able to tell if its wet. My dad had the same problem they were leaking a bit and there was a bad ground. Hope it helps
__________________ 2003 GMC ECT Cab Long box 4 In down pipe out straight piped Cold Air Intake. |
| I appreciate it. Im going to replace the middle bar it has a leak in there some where. Niclockw..I have an Edge evolution on my truck, has your dad every had problems with his fuel rail pressure? I got the error code P0087(fuel rail pressure to low) i replaced my fuel filter recently also. I don't run my truck on extreme a lot, I use the programmer for MPG. Should i replace the filter again with a better brand? I used the WSIX ( i think its a lower end Brand but not sure) |
