| Gauges, Electronics and Wiring. A place to discuss electronic / wiring issues and what gauges, audio, video, nav systems, lights, ect. are right for you. |
| Duramax Forum Supporter ![]() Join Date: Nov 2011 Location: Va.
| Bulldog Remote Start will crank but will not start All 2003 Chevy Silverado 3500 LB7 Diesel 5 speed automatic transmission. I have installed a Bulldog Deluxe 500 remote start. It will crank the motor but it will not start. I can insert the key and start the motor. I then can shut the motor off via the remote control. I have adjusted the crank time to the two setting, but is seem to not to make any difference in the crank time when I set it to one or two. I have the 791 install, but it’s red light is not light up. I can get into the program setting via the remote transmitter. Here is my wiring: Plug Truck Wire H1 Violet Large Yellow on steering column Red First Large Red on steering column Red Second Large Red on steering column Yellow Large Pink on steering column Pink Large White on steering column Brown Large Orange on the steering column H2 Red/White Fuse panel under driver (12V constant) White Brown on parking light switch Black Ground Red Fuse panel under driver (12V constant) H3 Antenna H5 Gray Not used Brown/Red White on the brake pedal Black Ground Blue/White Note used Gray/Black Dark Blue on back of the instrument cluster Green Not Used Violet Not Used White/Black Not Used Violet/White(Tach) Not Used H6 Not Used H7 Blue/Black Blue on 791 ByPass Module Black/Violet Not Used Brown/Black Not Used Black/White Not Used Black/Red Not Used Purple/Black Not Used Red/White Not Used Lt Green/Black Not Used Orange/White Not Used Orange Not Used H8 Valet Switch H9 LED The 791 ByPass is wired up this way: 791 Truck White Large Purple on steering column Red Lt Green on steering column Yellow Large White on steering column Orange Black on steering column Yellow/Black Large Yellow on steering column Thanks Bearwolf50
__________________ 03 Dually 6600 Turbo Duramax LB7 Allison 1000 5 Speed 4" West Coast Diesel Performance Exhaust System K&N Air Filter Hypertech Power Programmer III Stanadyne Diesel Fuel Additive LT 235/85R16 Cooper tires GM DRW club member #69 |
| All Discovered I did not have constant 12v at the 791. IT WORKS. Admin please close the post. Bear
