4 wd indicator light - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 03-27-2013, 06:08 AM Thread Starter
Anybody ever have a problem with there 4 wheel drive indicator light not lighting on there dash?
Surprise Duramax
2005 GMC
LLY,6 INCH LIFT,FOX SHOCKS WITH REMOTE RESEVOIRS,MOOG PITMAN ARM & IDLER ARM,FABTECH TIE RODS,REAR AIRBAGS,18 INCH BOYD CODDINGTON RIMS,12.50X35 OPEN COUNTRY TOYO'S,CAT LOST, 4" EXHAUST AND MONSTER MUFFLER,AFE MP,DEEP TRANS PAN,EARL'S LARGER TRANS COOLER WITH ELECTRIC FAN,LARGE FLUIDYNE OIL COOLER,AFE COLD AIR INTAKE,AFE MP,3 DOWNPIPE,CUSTOM MADE AIR SCOOP,ONBOARD AIR,TRAINHORN.CTS MONITOR,AUTOMETER PYRO GAUGE, DOUBLE LIMO TINT ALL THE WAY AROUND,6K HID HEADLIGHTS,REMOTE ELECTRIC BEDLOCKER,ELECTRIC TAILGATE LOCK,REVERSE LED LIGHTS
surprise duramax is offline
post #2 of 9 (permalink) Old 03-27-2013, 06:24 AM
These trucks do not have them.
looking for a LBZ/LLY crew 4x4
BowtieBrother is offline
post #3 of 9 (permalink) Old 03-27-2013, 07:27 AM
biketopia's Avatar
Yes they do... the manual transfer case ones light up on the dash.
OP if the light does not come on it could be the cluster it's self or the range switch could be bad. I just had one at work that thought it was always in 4x4 because the range switch on top of the TC was bad. This is all assuming you have the manual TC if it's the push button one then all you get is the lights on the buttons.
2003 2500HD LT CCLB, EFILive by Idaho Rob, 4" MBRP, Diamond Eye Down Pipe, Ported Intake Horn, S&B Intake, PPE Boost Valve, ADII, Nicktane CAT Adapter, CTS Insight, Cognito UCA, Rare Parts Tie Rods, Cognito Brace kit, Bilsteins, Gear Alloy wheels, Hankook RF10 285's, All on Mod, DDM 5k Low's & 4300 Fogs, air horn, on board air, limo tint, blue led interior
biketopia is offline
post #4 of 9 (permalink) Old 03-27-2013, 09:10 AM
ieetgluu's Avatar
Thats one thing I dont like about this truck. My 03 1500 has the floor shifter and a dash light that made it obvious that you were in 4 wheel. But this truck has the crappy push button and tiny little lights that are the same color whether youre in 4HI or 2wheel. Poor design. The dash is obviously already outfitted for a light, why not tie it in at the factory.
Chad
04.5 4x4 ~160k miles
DE 4", 5100s, LBZ MP, S&B LBZ air, KoryWillis Go-go Juice, Insight CTS, ADII, 8' Fisher, Highroller Ultimate Idler Arm, Profab delete, XD RareParts tie rods
Dirtymax this, Dirtymax that... :taunt
ieetgluu is online now
post #5 of 9 (permalink) Old 03-27-2013, 12:55 PM
Someone did a mod for that:
"This will work on all 03 and up full size GM trucks.": 4x4 Indicator on Instrument cluster mod - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Push Button 4x4 With Light on Dash - Diesel Place : Chevrolet and GMC Diesel Truck Forums
2003 2500HD Duramax CC LongBed 4x4
BFG KO2 245/75R16
262K+ miles on the stock injectors.
Fab Four Elite Bumper Replacement
Precision Billet Torque Converter
DSB'd: 2000 F250 Powerstroke ExtendedCab Shorty 4x4.
jblather is offline
post #6 of 9 (permalink) Old 03-27-2013, 08:39 PM
squeaky3's Avatar
i have the manual 4wd and my light used to work awhile back, but this winter it no longer works on my truck, i havent looked into it to much but i figured it was the switch on the transfer case not the light because of how little the light is actually lit up it was a slimmer chance it was burned out and no other dash lights are
Previous trucks
06 RCLB 6.0 gas lifted
03 LB7 ECSB
07 LBZ CCSB
Newest dmax 05 LLY Mostly stock but not for long
squeaky3 is offline
post #7 of 9 (permalink) Old 03-28-2013, 04:54 AM
biketopia's Avatar
If you have access to a tech 2 or a good snap on scanner you can command all the cluster lights on to see if it is bad. My overdrive cancel light does not work, but it still cancels. When we had a light that was staying on it would keep the front diff locked at all times, even in 2x4. Found the range switch bad on top of the case and it took care of everything.
post #8 of 9 (permalink) Old 03-28-2013, 12:06 PM
My overdrive disengage light doesn't work, either. I wonder if it's burned out....
BFG KO2 245/75R16
jblather is offline
post #9 of 9 (permalink) Old 03-29-2013, 06:01 PM
squeaky3's Avatar
i actually have a tech 2 at work, just have to remember to give it a try sometime, not to worried about it though, as long as i know i put it in 4wd and take it out
Previous trucks
03 LB7 ECSB
07 LBZ CCSB
squeaky3 is offline
