Stuck on Defrost?? - Chevy and GMC Duramax Diesel Forum
post #1 of 10 (permalink) Old 12-09-2009, 10:39 PM Thread Starter
Stuck on Defrost??
I just replaced my batteries and since i did that my heater is stuck on defrost i turn the climate control to anything else and nothing happens just stays on front window defrost? Any help would be nice and appreciated.
05 LLY 4 INCH MBRP STRAIGHT PIPED W/ 6 INCH TIP TURBO BACK, AFE TURBO INLET TUBE, K&N AIR INTAKE, BULLY DOG POWER PUP, BLOCKED RESONATOR, EGR BLOCKER PLATE, 386 RWHP
JLOP83 is offline
post #2 of 10 (permalink) Old 12-11-2009, 09:03 PM
Try pulling the fuse for a few minutes then popping it back in.
copmagnet is offline
post #3 of 10 (permalink) Old 12-12-2009, 09:18 AM Thread Starter
Id assume while the truck is not running then correct?? Or do you pull it out, then start my truck, then shut it off and replace fuse back??
JLOP83 is offline
post #4 of 10 (permalink) Old 12-12-2009, 09:32 AM
What truck do you have. I'm pretty sure mine starts out on defrost and then goes to the others after engine warm up. Can't remember for sure though because I always use command start. Might be what yours is doing.
Jason
2007 Classic Silverado LS 2500HD Z71 4WD
EGR Blocker and EFI Live by Idaho Rob at ATP
Amsoil in the engine
Jackrabbit tonneau cover with pop and lock
Billet Grille insert
Innovative Creations side bars
chrome rocker panels
Titan remote starter
Usually pulling 35' Montana Mountaineeer 5er
millwright01 is offline
post #5 of 10 (permalink) Old 12-12-2009, 10:05 AM
diesel_tech1's Avatar
sounds like your blend door motor went out.
2001 GMC SLT 2500 HD Crew Cab short box 4X4 LB7
4" straight exhaust 285/75/r16 210,000miles
Auto Meter Carbon Fiber Ultra Lite Pyro, Boost Gauges
PPE Boost valve.
Turbo MP Mod PPE HOT+2
30% over injectors
Transgo and Red Eagle Clutches
merchant auto pump rub kit.
diesel_tech1 is offline
post #6 of 10 (permalink) Old 12-13-2009, 08:54 PM Thread Starter
Ya gents i appreciate the advice and as stupid as it was i finally got a day above -5 degrees and warmed up enough to loosen something up and everything works fine cant wait for the -21 tonight but i tell you what this D-MAX starts everytime.
JLOP83 is offline
post #7 of 10 (permalink) Old 12-14-2009, 04:23 PM
I hope for ur sake that it wont be a problem in the future, but sometimes this is just a sign of a motor going out.
post #8 of 10 (permalink) Old 12-14-2009, 07:10 PM
I have this happen every time I disconnect the battery. I found that you have to turn the switch on after reconnecting batteries with everything in off position and on vent. Let in set with key switch on and not running, turn switch off and back on and listen to blend door movement before cranking. This seems to work everytime for me.
2-2004' Chev. 2500Hd. LLY one white that my son drives and one black that I drive. Triple-dog on son's truck, K&N air filter, and 5" exhaust and all stock on mine except for radio (Bose quit on me) and K&N air filter.
weakone is offline
post #9 of 10 (permalink) Old 07-03-2010, 05:36 AM
This worked for me this morning, i did the same thing and actually removed the key from ignition while in off position.
THANKS GUYS
2004 chev 3500, all stock
rackmaster2 is offline
post #10 of 10 (permalink) Old 11-03-2012, 02:00 PM
Hey guys, sorry to revive an old thread but we might as well keep all the info in the same place.
A week ago one of my idler pulleys separated at the bearings and completely came apart/fell off. So I disconnected both batteries at the negative terminals, replaced both idler pulleys and belt - and when I started my truck back up, air only blows through the defrost and some at my feet. The truck does allow me to enable recirculation, and a/c works, fan speed controls work - it just blows through the damn defrost. I have tried removing the fuse, starting the truck, replacing the fuse, any combination of key off/key on/ac off/ac on, disconnecting both batteries again and no cigar. On DieselPlace they said some trucks in this situation go through a cycle of defrost, floorboard, dash vents but my truck does not, even after disconnecting the batteries again. It is always on dash. It would be a hell of a coincidence if it was a hardware failure... Any help is appreciated, thanks!
2004.5 LLY Crew Cab Short Bed 2wd
TheDoubleDeuce is offline
