| Gauges, Electronics and Wiring. A place to discuss electronic / wiring issues and what gauges, audio, video, nav systems, lights, ect. are right for you. |
| Creepy ![]() Join Date: Feb 2010 Location: Look out your window, see that van?
| Where to wire stuff into? MBEC -MID BEC - Relay Center 2003-2007 The MBEC is under your dash on the drivers side. There is a small black plastic nut that you can take off without a tool and remove the cover. Inside is the SEO connector. (this is also the area where the elec brake plugs in) You can get a harness that plugs into the SEO - C8 position This plug has spots for you to wire in aftermarket stuff. There is a 30 amp Hot all times 10 amp hot run/start 10 amp hot run/accy 15 amp hot all times ground here is the link with pics, your looking for page B-8 http://www.gmupfitter.com/publicat/2...lectric_CK.pdf
__________________ '07 LBZ '12 Express Van |
| Ded Kough ![]() Join Date: Jan 2010 Location: San Clemente, CA
| Good info
__________________ The Truck: 06 Chevy LBZ CCSB Exhaust: Downpipe 4" MBRP turbo back straight piped Tires: 285/70/16 Nittos Front end: Rare Parts HD Tie Rods PPE Center Link Intake: S&B Other: HID 6000k Lows 8000k highs 5000k fogs, all on mod, Transgo Jr. EGR blocked, Intake air heated deleted |
| DF Sponsors ![]() Join Date: Jan 2010 Location: Aurora, CO
| good info. sticky! |
| The lmm's have this too. I ordered the wrong harness a ended up with the lmm one. oops
| "Darcy the Duramax" Join Date: Feb 2009 Location: Lacey, WA
| oh bad ass thanks man
__________________ 2006 GMC LBZ Performance- Quad Stealth, 5in straight pipe, Dimondeye downpipe, BD Manifold, S&B Intake, EGR Blocked, Resanator Plugged, PPE Lift pump, Transgo Jr Steering/Suspension- 6in Procomp Knuckle lift, Cognito tie rods, Cognito pitman/idler arms. Interior-Autometer, Kenwood indash Navi/DVD, 2 10in subs, Prodigy trailer brake, Viper 5902 remote start. Lighting- Full 6k hids with all on mod, Hella 500s behind grille |
| pic of lbz mbec plug ACD# pt1268 GM# 15306107
| Junior Member Join Date: Dec 2010 Location: upstate sc
| Do u have a PN# on that I need to order one for lmm
__________________ 2007.5 crew cab shortbed 6.6 LMM 4x4 EFI live dsp 5 tuned by Rob 4" Diamond Eye Exhaust straight pipe an down pipe Air Dog II 165; 285/65/18 on xd spys trail grabblers Edge Insight Monitor, 8000k hid 55w 6000k 30w fogs 30 gallon transfer tank custom built, fuel filter delete Stage V trans built by ME! :rockin transfercase brace EGR deleted an PCV rerouted, PPE shim kit Custom Tie Rods sleeve, custom built traction bars 4094 avnt; Diamond Eye Down pipe; 30% nozzles ................... ..................... . |
| Check this #. 20791502. And this TSB. 08-08-45-004a
| Junior Member Join Date: Sep 2010 Location: East Freedom PA
| Big thanks to the OP this helps me alot I am going to hook up my rear HVAC parking assist rear power outlet and wiper tonight to this location.
__________________ Mods EFI Live DPS5 tune from Nick Tie rod sleevs 20x9 +18 mb V drive wheels 285/55/20 Nitto terra's Magna flow exhaust no cat EGR Blocked 02 Escalade merged with a 07 2500HD CCSB the result is a 2500HD escalade with a LBZ ally6sp check out my project http://www.duramaxforum.com/forum/di...nds-build.html |
| Longbeds FTW Join Date: Oct 2008 Location: Natrona Heights, PA
| Great info James. Stuck.
__________________ 06 Dmax/Allison EC/LB 4x4 TTS PowerLoader III • full billet Bully Dog stage 7 • BCI 7" intake with custom snorkle • fender vents • quintuplet shotgun cat stacks • 22" Rockstars • Huge "Dirtymax" sticker • -60% nozzles • extra pcv with dual catch cans • compounded EGR • silencer ring MIA • 4.56 gears • Lowered 5.5" in the back • Lifted 6" in the front • Monster sticker • flat bill mod • 8' CB whip • blacked out reverse lights • gauges everywhere 08 BMW 528xi 00 Buick Regal GS |
