are these problems connected? - Chevy and GMC Duramax Diesel Forum
post #1 of 3 (permalink) Old 02-17-2017, 10:42 AM Thread Starter
lycan03lb7's Avatar
So the other day I noticed when I was going to leave for work my dome lights did not come on when I opened the door, the lights in the door turned on, dash lights worked. Tried the dimmer switch did not turn them on, I cycled the dome override nothing, but they will turn on if i push the map light buttons.. That night on my way to go home I unlocked with my key fob and my reverse lights did not flash, they don't come on at all. The reverse lights are the retro solutions crees, the dome lights are led from ebay. Is there a fuse that connects them? I would have looked but the weather has been terrible and I don't have a garage.
Nick
2003 Chevy LB7 2500hd 4x4. Federal Emissions system. PPE Boost Valve, XD Spy 17x9, 265/70/17 Kumho KL71, 4" ATS exhaust. Rancho7000mt , Firestone Airbags. Leveling kit. Retro solutions CREE reverse, LED Dome/map/L.P., Fass 150
lycan03lb7 is offline
post #2 of 3 (permalink) Old 02-19-2017, 02:09 AM
Jasong's Avatar
Not sure but I'd check for a loose wire at the overhead console.
Sounds like "door open" powee isn't getting up there.
If the lights in the door hadn't come on, I would've said bad door latch switch. Very common failure.
C2500HD ECLB, turn over ball & Andersen Ultimate hitch. 395,000 miles and counting. Stock except for LBZ mouthpiece.
41' Toy hauler @ 21K lbs.
Jasong is offline
post #3 of 3 (permalink) Old 02-19-2017, 04:28 AM
dlsacco's Avatar
Yep.. mine does that occasionally.. other symptom.. radio doesn't turn off when the door opened. I've made it "better" short term by lubricating the latch assemblies.
06 LBZ Allison CC LB Nicktane/Cat filter, Racor RK32313 DMAX PRIMARY FUEL FILTER KIT, PPE Transmission Cooler, BD Power Diff Cover, Magnaflow 5"Catback and down pipe, BD Power Full Flow exhaust manifold, Edge Evolution, B+H Turnover Ball with Companion 5th wheel hitch, Huper Optik tint.
dlsacco is offline
