Im wondering what you guys are doing for lighting the guages. Ive got the autometers and Im wondering what wire you would tap into so that they dim with the dash lights on my 2002 and how would you tap into it?
__________________ 2002 LB7 GMC CC SB 4wd Converted to 03-07 front end done by me
Suncoast stage IV w/ 1056 from Allisondan installed by Ultimate Transmission
EFI live tuned by IdahoRob
Mitusa lift pump w/ perma cool filter setup
Water/methanol injection and some other stuff
I can tell you that using the dimmer is not good idea.Causes the voltage to drop=not good.Can't you wire it to the batt/or hot side of ignition so that key is turned,hot,then use whatever dimmer came with your gauges,that's the easiest way/I'd do mine like that....
__________________ 2006 GMC 2500hd4x4SLE cc/sb...LBZ
HIFLO exhaust & ''HP enhancers''.
2002 GMC ex cab15002wd
1987 Monte Carlo SS
1978 Malibu/RUNS
2002 YukonXL321k,tuned! The left lane is built to pass,move or we'll run over yurassss!!Try me..
2005 Kodiak...don't ask! Kevin
''FORSHO''[Tm]
But wouldnt the light always be on that way? I think ive seen some do it but im not sure of the wire to use. Would this really cause the voltage to drop that much? Anyone ever had problems with it? I could just wire to a key on source but it would be cool to do it this way
there is a recent thread that discussed exactly where to put it..Not so much voltage drop I guess,but maybe FUBARing the switch..I'll try to find it for ya..
1987 Monte Carlo SS
1978 Malibu/RUNS
''FORSHO''[Tm]
refresh ya page/new posts ....New pyro gauge won't work is the thread!!You got it from here!
1987 Monte Carlo SS
1978 Malibu/RUNS
''FORSHO''[Tm]
Yeah i found that one i think. Its diesel manor i believe that shows installation pics but its for a 2006 lbz i think and mine is 2002. I wouldnt have a problem figuring it out myself but i dont have a voltmeter to test the wires. Thanks for the input, I appreciate it
i got a decent analog one from Auto zone twenty bucks w/batteries
1987 Monte Carlo SS
1978 Malibu/RUNS
''FORSHO''[Tm]
I'd would have been interested in looking into that but that thread was alot of help so i shouldnt need to now. I should be able to figure it out from here, thanks again
