Old 10-28-2008, 06:09 PM   eBay Motors   #21 (permalink)
Dmax15
Dmax15's Avatar
The PPE boost valve will need to be on the wastegate side(Passenger side) and you'll want to put the T fitting on the Turbo side(Driver side). Mine doesnt show a reading idling either, its normal and it wont need power to run, just make sure there are no kinks in the line and use the rubber grommets where it could possibly get cut. The super diesel manifold is an easy route also if you have the extra $100 dollars but on the LB7 it mounts after the intercooler so it will give a lower reading than what your boost off the turbo actually is.
2002 LB7 GMC CC SB 4wd Converted to 03-07 front end done by me
Suncoast stage IV w/ 1056 from Allisondan installed by Ultimate Transmission
EFI live tuned by IdahoRob
Mitusa lift pump w/ perma cool filter setup
Water/methanol injection and some other stuff
Dmax15 is offline   Reply With Quote
Old 10-28-2008, 06:20 PM   eBay Motors   #22 (permalink)
Caterpillar3208t
thanks. I appreciate it
Chassis: 03 Sierra K2500HD ext. cab short box SLE 80,000mi.
Intake: K&N
Exhaust: MBRP 4" TB 5"tip
Tuning: PPE standard Excellerator
Turbo: PPE Boost Increase Valve
PPE high idle switch
Interior: A-pillar with Cobalt Boost & Pyro gauge
Injectors: oem replaced @74,000mi
Tires: 285/75/16 BFG A/T
Caterpillar3208t is offline   Reply With Quote
Old 10-28-2008, 06:21 PM   eBay Motors   #23 (permalink)
Caterpillar3208t
what size wheels are u running? and what does your 2 inch lift consist of?
Intake: K&N
Old 10-28-2008, 06:25 PM   eBay Motors   #24 (permalink)
Dmax15
Dmax15's Avatar
Its just torsion keys up front and a small 1" block in the rear, uses the factory shocks, pretty simple. It was already on the truck when I bought it. I really like the way it sits. Once I get a camera I'll take a pic
Old 10-28-2008, 06:29 PM   eBay Motors   #25 (permalink)
Dmax15
Dmax15's Avatar
Oh and im running 33/12.5R17 pro comp all terrains. Rides smooth and hooks up fairly well
Old 10-28-2008, 06:35 PM   eBay Motors   #26 (permalink)
Dmax15
Dmax15's Avatar
To answer your questions in the other thread, your ride will be a little stiffer depending on how high you crank the bars. A block will work just fine if its only 1". You will need to do some trimming with a sawsall or trimmers but the job done with a sawsall will look alot better. My wheels are 17 by 10 and Im not too sure but if I remember right the offset is 9"
Old 10-28-2008, 09:10 PM   eBay Motors   #27 (permalink)
Durallymax
Durallymax's Avatar
A lower but more accurate reading as this is the actual intake manifold pressure. Rememeber you loose some psi through the intercooler.
The "Dieselholic"
Dieselholic Homepage
'03 GMC 2500HD LB7/Allison EC/SB 4x4 Dark Charcoal Metallic SLT. Injectors at 84,000. Sled Puller/DD
EFI Live: V7.5.5/V8.1.2 OS:03904405
Suncoast IV w/1055
512rwhp 1085lb-ft
13.6 @ 99mph
Many mods to come over the winter.
Durallymax is offline   Reply With Quote
Old 10-28-2008, 09:53 PM   eBay Motors   #28 (permalink)
Dmax15
Dmax15's Avatar
Yeah it shows the actual manifold pressure but if you're running the stock turbo and getting towards the 35 psi mark at the turbo then you'll want to keep an accurate measure by mounting before the intercooler. Also the higher the elevation the lower your max boost should be when determining what is safe for the turbo, the main reason for a boost guage with a stock turbo would be to save the turbo.
Old 10-28-2008, 09:58 PM   eBay Motors   #29 (permalink)
Dmax15
Dmax15's Avatar
Thats why I like the water/meth injection setup. It adds boost and cooler air without the turbo having to rev as high.
Old 10-30-2008, 04:32 PM   eBay Motors   #30 (permalink)
Caterpillar3208t
Installed the boost valve and notice a big difference. It hits the old boost max of about 18 and then buries it! I noticed my turbo sounds a bit different when I let off of the fuel as it is coming back to idle. I havent been able to hear from outside the truck yet.
Intake: K&N
