Old 11-16-2008, 01:54 PM   eBay Motors   #1 (permalink)
dington
dington's Avatar
Power at the trailer plug
I've tried for a long time to get power to the trailer plug for my interior trailer lights with no luck. I've hooked up the lug under the hood fuse block that said trailer power and still nothing. Any help would be great. Thanks Brig
2008 silverado LTZ crewcab summit white(What else is there?):tease
AFE dry filter
Stealth 2 70hp with an easy foot
mbrp 4inch
Now if this S.O.B. doesn't get some mileage Then I don't know WTF to do!
dington is offline   Reply With Quote
Old 11-16-2008, 02:44 PM   eBay Motors   #2 (permalink)
daddysLBZ
ONEFASTCOONASS..
daddysLBZ's Avatar
Have you checked all the fuses?Look in the underhood fuse box.There is some tape over all the fuses that supply trailer power.[next to driver side fender]
06.LBZ GMC[SLE1] 4x4 ....114k miles,4136 hours[Modded a bit.LOL]
1987 Monte Carlo SS 89k
1978 Malibu
FORMER DURAMAX FORUM MODERATOR...........i HAVE YOUR iNTERNET pROVIDER ADDRESS...:tease
Old 11-16-2008, 04:54 PM   eBay Motors   #3 (permalink)
New2DMax
New2DMax's Avatar
Sorry if this sounds stupid, but, when you hooked up the wire to the lug on the distribution panel, did you install the fuse?
Mine has one lug on the left, (actually the front) which is the power to the brake controller, and one on the right, (actually the back) that runs the +12VDC to the trailer plug.
Another thing to check is the actual wiring to the plug. There have been a number of posts that contain the correct wiring for both end of the plug (truck and trailer).
Hope this helps.
02' Chevy Crew Cab
Short box 4X4
BullyDog PowerPup
4" MBRP Down Tube back
KoolVue Tow Mirrors
Fifth Wheel & GooseNeck
New2DMax is offline   Reply With Quote
Old 11-16-2008, 05:55 PM   eBay Motors   #4 (permalink)
dington
dington's Avatar
There is a wire on the side of the box with a tag that reads aftermarket 12 volt trailer feed. I had to uncoil and connect to the post at the front of the box. That wire is now hot at the box but nothing at the camper connection or at the plug itself. I cant imagine that wire having another fuse on it somewhere under the truck.
AFE dry filter
mbrp 4inch
Old 11-16-2008, 06:04 PM   eBay Motors   #5 (permalink)
Murrow
Murrow's Avatar
anyone know anything about a good brake controller for the new lmm's. And how hard to install? they don't just plug up anymore now they need to be wired in to the system.
Jason
You Can't Be Cummin' or Strokin', Unless You're Hard As A Rock!!!!!!
08 Duramax LMM 2500 HD
Greystone Metallic Ex. Cab, Short Bed
G4 Elite Fold-A Cover
Home Made Custom Mud Flaps With Stainless
Uniden CB and Tekonsha Break Controller
4" Turbo Back, 5 inch tip, EDGE EVO RACE!!!!!! Thanks To Tyler At MPF!!!!!!
still need to install the EGR Block Plate
For all your wheel and tire needs www.discounttiredirect.com
Murrow is offline   Reply With Quote
Old 11-16-2008, 07:49 PM   eBay Motors   #6 (permalink)
bob213
bob213's Avatar
I had to add a 40a fuse in my fuse block under the hood before I got power to my trailer.
IIRC it was under a piece of tape also. There was just a blank place holder in its hole.
2005 GMC Crew Cab SLT 4X4
4" MBRP turbo back
Diablo Sport Predator/EGR Plate
BD Exhaust Manifold
AutoMeter UltraLiteII Pyro Gauge
Induction Overhaul Kit by "Killer Bee" with
True CAI by "KillerBee" THANK YOU!!! Michael...
bob213 is offline   Reply With Quote
Old 11-17-2008, 07:10 PM   eBay Motors   #7 (permalink)
dington
dington's Avatar
Iput the fuse in and have had power to the wire that says trailer feed.At the bundle of wire for a camper insert, there is no power to the red/ black wire nor is there power at the 7 way plug. I guess I'll start tracing the wire and find some.thing
AFE dry filter
mbrp 4inch
Old 11-18-2008, 06:33 PM   eBay Motors   #8 (permalink)
dington
dington's Avatar
Does anyone have a wiring diagram they could post. All I need is from the bed back. Thanks
AFE dry filter
mbrp 4inch
Old 01-28-2009, 06:25 PM   eBay Motors   #9 (permalink)
Blazonic
Blazonic's Avatar
Did you ever figure out what the problem was? I was checking my wiring the other day and mine doesn't seem to be working either... I have hooked the wire to the stud and the stud has power (fuse is in and not blown) and still have yet to get power to the 12V pin on the bumper connector
08 Crew 2LT, 07 TBSS, 00 SS Camaro, and an 8 sec S-10 Blazer. ALL CHEVY'S
Blazonic is offline   Reply With Quote
Old 01-28-2009, 07:08 PM   eBay Motors   #10 (permalink)
Hook'em_Horns!
Uhhhh.....Yeahhh!!!
Which pin are you checking at the plug?
