__________________ 06 lbz cc/sb ,afe intake,mbrp 4in turbo back exhaust
ppe tie rod sleeves,egr blocked
di-pricol guauges(boost and pyro)
ported fuel rail fitting,fuel valve shimmed
Air Dog II 165 lift pump stage 5 tranny built by me
(Twins)S475 over the stock turbo Efi live tuned
I agree with chris and you really cant use the T fitting. I drilled and taped mine into cast boost tube going from the intercooler to the air intake heater next to the alternator. The tubes on top of the motor are easy but there so thin Id be afraid of them blowing out eventually
i did as well tow master
__________________ 05' CCSB 4x4 DMAX/Allison is junk
# 15 top 25 slowest stock duramax www.performancetruckproducts.com
wooster diesel performance!
mine is on the tube on top of the motor right off the turbo so i know what its putting out. the motor sees around 2-3lb less then what my gauge says.
im not worried about it blowing out then again i drilled the hole and welded a fitting on cus im cool like that!
__________________ Vehicle 2008 Black Chevy Crew Cab Short Bed Z71 Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck Drivetrain LMM Duramax, Allsion 1000 Transmssion Performance ModsEFI Live and DSP 5 By MMLMM, RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC Other Mods B&W Turn Over Ball, Air Lift Bags, Titan 52gal fuel tank, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
You just dont see what the motor is seeing you see what the turbo is putting out...
I thought that's what the boost meter was for...to see what the turbo is putting out...if i'm wrong please correct me (be nice about it though!!! lol )
__________________ 08 Chev. 2500 LTZ Only option missing is heated seats. 403 CI alum. Duramax 4x4 sitting on 265/75R16's Charcoal Gray
There is a pressure drop between the compressor and the intake due to the restriction caused by the intercooler and piping. You may see 36 psi at the compressor outlet, and 30 psi at the intake. 36 psi would be over working the charger. You dont even wanna know what drive pressures are at that psi.
__________________ 06 Chevy LBZ/Allison 4x4 EFILive & DSP5, Suncoast IV w/1054, Suncoast Tcase brace, MA pump rub fix, PPE lift pump, AEM Intake, shimmed fprv, ported rail fittings, 4"-5" Grandrock/MBRP, torsion bolts removed, 4" drop shackles, stock turbo, stock wheels, Autometer GS boost/pyro, Aeroforce scangauge, PPE sleeves, Cognito pitman/idler braces, 8k HIDs, Recon LED tails & smoked 3rd brake, Pioneer DVD, 98,000 miles and counting 12.60 @ 105.41 mph #15---Top 25 Fastest Stock Duramax's Keystone 8 Luggers Videos
There is a pressure drop between the compressor and the intake due to the restriction caused by the intercooler. You may see 36 psi at the compressor outlet, and 30 psi at the intake. 36 psi would be over working the charger. You dont even wanna know what drive pressures are at that psi.
plus just to add once you get over 35psi the air coming from the turbo gets so hot you actually loose efficiency...for the short amount of time your turbo is still intact
__________________ Beech (thats my real name) EfiLive by Nick@duramaxtuner, likes to go fast
CC/SB LLBYE
Originally Posted by DMAXchris
No one ever said anything about lube or salami you sick bastard.
