Old 10-31-2009, 11:50 AM   eBay Motors   #1 (permalink)
diesel guy
diesel guy's Avatar
Trying to install a cb radio right now, but got a ??
The directions say to connect the red lead of the dc power cord to an accessory 12 volt fuse (fuse box).But can I run it straight to the battery?If it already came with a fuse in the line it should be ok right?Or can I use the same power source I used to connect my brake controller.The new LMM came with two stems under the fuse box to connect the brake controller.
2008 2500hd duramax crewcab Whelen 90 watt strobe lights Cobra 19dx iv cb radio with a 4'Firestik antenna
toys 2007 thor tahoe 22fb toyhauler 2005 honda 450 quad 06 polaris 200 auto(wife) and 06 polaris predator 50 (son) Seadoo gti se 155
diesel guy is offline   Reply With Quote
Old 10-31-2009, 12:12 PM   eBay Motors   #2 (permalink)
mico2112
mico2112's Avatar
If you run right to the battery it will be hot all the time not just when the key is turned, you'll have to shut it down each time, but it should be fine. Don't know about the brake controller
John
2004 Chevy 2500HD LB7 CC LS, AFE Stage II CAI, Silverline 4" exhaust, PPE Standard, ISSPRO gauges, PPE Boost valve, Intake mod, AD II, 285/75R16 Nitto Terra Grappler, Spray-in liner, B&W turnover gooseneck, Ride-Rite Airbags, BOSS Power V Plow
People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf. George Orwell
mico2112 is offline   Reply With Quote
Old 10-31-2009, 12:34 PM   eBay Motors   #3 (permalink)
fireman260
Lovin The Duramax
fireman260's Avatar
I hooked mine to the cigarette lighter...never had a problem with it. Id try to find something that has a constant 12v or higher. With some of the newer CB's on the market, you don't always get your peak wattage out of them unless you have 12v or higher. I've left mine on for days at a time and never had a problem.
What you call a hero, I call just doing my job!
2007 Chevy Silverado 6.6L Duramax Diesel lbz
Edge Attitude w/Juicer
4 Inch Turboback Straight Piped to 6 Inch Grand Rock Mitre Stacks
K&N Intake
3 Inch Leveling Kit
33 Inch Maxiss Bighorn Tires
4 Chime Train Horns
fireman260 is offline   Reply With Quote
Old 10-31-2009, 12:42 PM   eBay Motors   #4 (permalink)
diesel guy
diesel guy's Avatar
I think I will just use the fuse box after all just becouse it's easier to run the wires.I'll go out there and try it.
Old 10-31-2009, 12:43 PM   eBay Motors   #5 (permalink)
AO2005
AO2005's Avatar
i ran mine to the battery and it work great but i do get some alternator noise while accelerating
ALAN
05 lly CC/SB 4" mbrp turbo back no kitty no muffler LBZ mp
res. plugged quadzilla stealth 2 135 tune
AO2005 is offline   Reply With Quote
Old 10-31-2009, 01:47 PM   eBay Motors   #6 (permalink)
diesel guy
diesel guy's Avatar
what amp fuse did you use 15?
Old 10-31-2009, 02:36 PM   eBay Motors   #7 (permalink)
AO2005
AO2005's Avatar
no i just used the one that it came with
ALAN
Old 10-31-2009, 03:24 PM   eBay Motors   #8 (permalink)
diesel guy
diesel guy's Avatar
Yeah theres one on the "hot" wire but since I plugged it into the fuse box don't u need one there too?
