LB7 High Idle Installed! - Page 2 - Chevy and GMC Duramax Diesel Forum
Old 01-03-2013, 03:38 AM   eBay Motors  #11 (permalink)
farmtwin's Avatar
I also got mine wired up over the holiday week, but I used a relay and triggered off of my ebrake wire. Works like a charm.
2003 GMC 2500HD ECLB ZF6 SBDD, AFE stage 2 pro dry intake, FASS 165, EFI by me.
farmtwin is offline   Reply With Quote
Old 01-03-2013, 05:23 AM   eBay Motors  #12 (permalink)
That One Guy
WisconsinHick1's Avatar
For that setup you just had to have the ECM wire and 12v into the relay and then one wire coming off the ebrake that trips the light on the dash?
Mods: A little of this a little of that
Built With Help From Some Great Friends and Sponsor Jags Pro Truck Shop!
Old 01-03-2013, 08:09 AM   eBay Motors  #13 (permalink)
farmtwin's Avatar
Correct, have you read the high idle how to thread? The autos are as simple as just tapping into a wire on the brake switch, but mine being a manual that wire doesn't do the same thing. I had to find a different way to run it.
Old 01-03-2013, 08:40 AM   eBay Motors  #14 (permalink)
KyBowtie's Avatar
Originally Posted by dieseldave01 View Post
Southwest Ohio, pretty cold winters at times, so it would be handy. do you buy the switch from anywhere special, or just an autozone one do the trick?
I'm right on the other side of the river! Looking to do this soon also
Logan Faehr
04 lb7 ecsb 4x4
EFILive|Exhaust|Built Tranny|ADII|fuel hostage with nittos
KyBowtie is offline   Reply With Quote
Old 01-03-2013, 09:07 AM   eBay Motors  #15 (permalink)
That One Guy
I have not read the writeup. I like the idea of going off the ebrake I might have to buy a relay tonight. For my 12v source I just went off of my elocker power since they wont be on at the same time.
Old 01-03-2013, 09:13 AM   eBay Motors  #16 (permalink)
SparkZ03DMAX's Avatar
I didnt even need a toggle switch....
OLD VIDEO
2001 Chevrolet LB7 Duramax
EFI Live w/ Dsp5
and other goodies
www.trollperformance.com
Youtube Channel- http://www.youtube.com/user/SparkZ1420
GET OBAMA OUT OF OFFICE
Alligator condoms: cause sometimes you wanna put a bitch in a death roll.
SparkZ03DMAX is offline   Reply With Quote
Old 01-03-2013, 09:17 AM   eBay Motors  #17 (permalink)
My son and I did his and mine. I purchased a led switch from Radio Shack and installed it in the dash down next to the steering column. Keep it to one side incase you want to add another switch. Good luck.
Injector is offline   Reply With Quote
Old 01-03-2013, 10:04 AM   eBay Motors  #18 (permalink)
Bear9350's Avatar
Its been a while but I thought I wired mine into a switch in the brake. I thought all I did was run that one wire from the ecm through the firewall and spliced it in at the brake. I can turn it on when in park. As soon as I touch the brake pedal it turns off. I thing the wire is for some signal so it only has power when in park so the high idle can't be turned on when in gear. No extra relays or wires needed for this setup. Again iirc this won't work for manual trannys.
2003 Chevy 2500 LB7, Crew Cab
Bear Claw Front and Rear Bumpers
EFI Live DSP5 from ATP/Rob, 4" straight pipe from the downpipe, intake horn mod, modded air box, custom overhead gauge console, pyro and boost gauges
Cognito UCA, Kyrptonite Straight Centerlink and Tierods, BFG KM2 255-85 on stock wheels
Pictures: http://s1133.photobucket.com/albums/m600/Bear9350/DMAX/
Bumper Build: http://s1133.photobucket.com/albums/...0/DMAX/Bumper/
Bear9350 is offline   Reply With Quote
Old 01-03-2013, 10:41 AM   eBay Motors  #19 (permalink)
I'll need to try to see if the high speed idle switch works while in gear. Very good point. I believe we also went to the break switch so when you go to shift it into gear you push on the break pedal and that disables the high rev program.
Old 01-03-2013, 10:46 AM   eBay Motors  #20 (permalink)
Bear9350's Avatar
If the high idle is just switched from a power source it is possible for the high idle to be activated while in gear. Of this occurs the engine will run poorly at higher rpms I believe.
