P0087 Code - Chevy and GMC Duramax Diesel Forum
post #1 of 21 (permalink) Old 11-02-2011, 03:25 PM Thread Starter
P0087 Code
I have been getting this code occasionally lately on a 90hp tune on my Quad S2. What is this code exactly? I put's the truck in limp mode which is annoying.
I thought it was low fuel pressure, but i checked it when i put it to the floor on the highway. My Desired is about 26000 at WOT and m actual is about 23000-24000 at WOT. So this doesnt seem to low to me?
Any other idea's what it is or how to fix it?
Better not be injector's.
I am going to change my fuel filter and see if it fixes it as my fuel filter does have 5000 miles on it.
2007 GMC LBZ CC/SB
Zone, BDS, Rare Parts, Rancho, Cognito, Bilstien, Fox, Nitto, American Eagle, Core Racing, Tuff Country, Amp Research, AirDog, PPE, K&N, Quadzilla, MBRP, Kenwood, Kicker, Sub Thump, US Speedo, WeatherTech Auto Meter, AeroForce, AVS, KC, TruxPort, Bushwacker, Alligator Performance, MA
Boreen is offline
post #2 of 21 (permalink) Old 11-02-2011, 03:29 PM
rebpdt's Avatar
low fuel rail pressure
get a shim kit or race valve and it will stop it from dumping rail pressure at WOT
CCSB LB7 4x4
rebpdt is offline
post #3 of 21 (permalink) Old 11-02-2011, 03:34 PM
WishforaDMax's Avatar
man its weird that alot of people get low fuel pressure code on 90hp my truck didnt run out of fuel till i put it on 135 and it still didnt pop a cel i used to run my truck hard on the 110 daily
Names Yezin im 24 and yes i bought my truck myself
2006 CCSB 2500Hd Lt2 LLY DMax, Efi live 150hp Idaho Rob , 5in Straight Pipe 6in Black Tip:rockin, Diamond Eye Dp, Tie rod sleeves, Edge Insight cts, SDP Egr Delete Pipe, Fprv shimmed, Pcv Reroute, All On mod, Blue led's in gauges cluster, Clarion Nx700, 8000k HID's highs/lows/fogs, Rbp Locking Fuel Door, Recons with Led Reverse lights
Name is Sharks06LLY on Duramaxdiesels.com
WishforaDMax is offline
post #4 of 21 (permalink) Old 11-02-2011, 03:38 PM Thread Starter
I had never got the code on my Bully Dog once even on the 140hp tune, or the PPE on the 225 tune.I got it once on the Quad 135hp tune, now twice on the 90hp tune in the last two day's.
Guess i'll change the fuel filter first, than i guess its time to spend some cash soon.
Will i cause any damage to anything if i keep gettin this code and clearing it until i get a AirDog?
2007 GMC LBZ CC/SB
Boreen is offline
post #5 of 21 (permalink) Old 11-02-2011, 03:39 PM
fidget51691's Avatar
hey man. my truck did the same thing.. I replaced the fuel filter. and it stopped throwing that code.. lemme know if that is what fixes it for ya!
Cody
2005 LLY CCSB
PPE Stage 5 Transmission
EFI Live w/ DSP5 Underground Diesel
C grade head gaskets
ARP head studs
HSP cold and hot side intercooler popes
PPE Race Valve
Ported Fuel Fitting
EGR Delete
PCV Reroute
Fass150
3 MBRP Downpipe
4" Exhaust w/ 5" tip
S&B Intake with horn
Wicked Wheel Turbo Wheel
Traction Bars
Tie Rod Sleeves
Air Bags
fidget51691 is offline
post #6 of 21 (permalink) Old 11-02-2011, 03:44 PM
gonna need to shim it man, shiming is easy and cheap and then when you get your airdog you will be able to run whatever tune you want. but with you saying that im gonna guess fuel filter as well
post #7 of 21 (permalink) Old 11-02-2011, 03:46 PM
rebpdt's Avatar
your gonna wanna shim it before getting an AD bc it will still dump pressure even with and AD
PPE Release Valve Shim Kit
heres one
CCSB LB7 4x4
rebpdt is offline
post #8 of 21 (permalink) Old 11-02-2011, 03:48 PM
rebpdt's Avatar
and all of these are rated differently.
some at the crank, some to the wheels etc..
CCSB LB7 4x4
rebpdt is offline
post #9 of 21 (permalink) Old 10-21-2012, 08:13 PM Thread Starter
any other reasons to get this code?
truck is stock tuned, has race valve and airdog 165 now and still set this code at holding it wot for a kilometer or so.
2007 GMC LBZ CC/SB
Boreen is offline
post #10 of 21 (permalink) Old 10-21-2012, 10:19 PM
Hang it!...Fire!
TDIpowered's Avatar
or jsut get the alligator plug. turn up your airdog
Max - 07 LBZ ECLB LOWERED!
TDIpowered is offline
