Oily residue on back of truck? - Chevy and GMC Duramax Diesel Forum
post #1 of 19 (permalink) Old 11-06-2011, 06:06 PM Thread Starter
RivMan's Avatar
Hey guys, got a question!
I've put about 1000 miles on my truck since I picked it up 3 weeks ago. I washed it about 300 miles ago, and when I was filling it up today, I noticed the entire back of the truck had a thin oily film on it, from the back tire back. Is this a normal thing these trucks do, or do I have a leak to track down?
Thanks
-Rob
RivMan is offline
post #2 of 19 (permalink) Old 11-06-2011, 06:15 PM
biketopia's Avatar
Is it on both sides? It could be from too much tire dressing being applied. is it on the tail gate or only after the exhaust? Check all your fluids to be safe
2003 2500HD LT CCLB, EFILive by Idaho Rob, 4" MBRP, Diamond Eye Down Pipe, Ported Intake Horn, S&B Intake, PPE Boost Valve, ADII, Nicktane CAT Adapter, CTS Insight, Cognito UCA, Rare Parts Tie Rods, Cognito Brace kit, Bilsteins, Gear Alloy wheels, Hankook RF10 285's, All on Mod, DDM 5k Low's & 4300 Fogs, air horn, on board air, limo tint, blue led interior
biketopia is offline
post #3 of 19 (permalink) Old 11-06-2011, 06:19 PM Thread Starter
RivMan's Avatar
It's on both sides and tailgate, only behind the rear tires. No tire dressing ever on the these tires, so that's not it.
Thanks
-Rob
RivMan is offline
post #4 of 19 (permalink) Old 11-06-2011, 06:26 PM
biketopia's Avatar
well then, check under neath and see if fluid is maybe heaving out the rear diff?
post #5 of 19 (permalink) Old 11-06-2011, 06:33 PM
lugnut's Avatar
If it is under warranty, take it in. Sounds like you may have a leak of some kind. Check the ground where you park it over night and see if there is any evidence of a leak there. It has been cold the past few mornings here in SE Michigan. Something that may seal well when it was warmer may not be sealing as well now. This is the time of year everyone begins to notice their trans cooler lines leaking. Keep us posted.
2006 2500HD LBZ 4X4 CC/SB LT3, 265/75R16, Rhino Liner, PCV Reroute, Resonator Plugged, 35w 6K HID Low Beam & Fog Lights, LED Interior Lights, ISSPro Pyro, Boost, & Rail Pressure Gauges in A-Pillar, Cognito Idler/Pitman supports, more to come soon.
1996 K2500 Suburban 7.4L, 265/75R16, Brush Guard, Nerf Bars
lugnut is offline
post #6 of 19 (permalink) Old 11-06-2011, 06:52 PM
TakeEm's Avatar
What year is this? (sorry on my phone can't see your sig)
Sent from my Autoguide IPhone app
Caleb
2011 Denali LML
Wehrli Emissions Compliant 475/stock kit, Wehrli Dual CP3 Kit, Merchant Auto Trans, Fass Pump
Tuned by Duramaxtuner
Sold 7/2015: Twinned 07 LBZ
TakeEm is offline
post #7 of 19 (permalink) Old 11-06-2011, 08:04 PM Thread Starter
RivMan's Avatar
Thanks guys! The truck is an 07 LBZ with 108k, so no warranty here.
It seems as though I'm one of the lucky ones. I'm guessing these are the trans cooler lines, passenger side under the bumper.
Are they a tough fix? Do they normally leak enough to cause a huge problem?
Thanks
-Rob
RivMan is offline
post #8 of 19 (permalink) Old 11-07-2011, 04:28 AM
biketopia's Avatar
They can leak enough to cause big problems, a few of the vendors like alligator performance have an aftermarket line kit that is easy to install and will take care of your problem, it will be money well spent.
post #9 of 19 (permalink) Old 11-07-2011, 06:22 AM Thread Starter
RivMan's Avatar
Thanks guys, I've seen the Alligator kit, and the Husker diesel kit. Are there any others out there I should consider?
Thanks
-Rob
RivMan is offline
post #10 of 19 (permalink) Old 11-07-2011, 06:40 AM
Banned
Allseason makes a good one.
I just took the lines off and took them to a hydrolic line shop and had them recover the ends and hard lines, then had them smooth crimp new stainless braided hose onto my lines so they will last forever now. Plus, it was cheaper than new lines from GM that I know will eventually leak again................
smokinlmm is offline
« AC Prob | 20x14's »
