Block heater: is it bad to leave plugged in for long periods? - Chevy and GMC Duramax Diesel Forum
post #1 of 28 (permalink) Old 01-04-2012, 06:26 AM Thread Starter
2011LousDuramax's Avatar
I usually plug it in when i get home at night and leave it all night... im wondering if after i get to work in the morning if i should plug it in and leave it plugged in all day. Will this prematurely wear anything out? Is it bad to have it constantly plugged in? Should I wait til about 4-5 hours before leaving work then plug it in?
Any help would be great!
Thanks
2011 GMC 2500HD LML
EFI live custom tuning by Kory Willis @ PPEI
Banks Cold Air Intake
4" Turbo Back 6" Dual Tips
15% Tint Front 12% Rear
Cognito UCA's,Fox Monotube Shocks
Steering Braces
55W 8K HID's
Denali 18" Rims
295/70/18 Nitto Terra Grapplers
2011LousDuramax is offline
post #2 of 28 (permalink) Old 01-04-2012, 06:32 AM
it stinks and whistles :)
Brennan's Avatar
get a timer for it to come on a few hours before you need the truck, i have one that also has temperature control
06 lly,
Efi From ATP trucks,
5" straight pipe, egr blocked, cognito ucas,
rare parts gen2, bilstein 5100s, all season brace,
merchant pump rub fix, drp trans cooler lines,
air dogII 165
Brennan is offline
post #3 of 28 (permalink) Old 01-04-2012, 07:06 AM
LMMzach's Avatar
Bad for your electric bill lol but houldnt hurt the heater, a lot of guys rig up a timer on whatever outlet you are using
2008 single cab gmc efi, straight pipe to 6" stack, sdp egr delete pipe, American force 22x12 on 305/55R22 toyo proxes st, custom track bars, mesh grille, paint match headlamps, paint match chrome
LMMzach is offline
post #4 of 28 (permalink) Old 01-04-2012, 07:21 AM
Banned
If you leave it plugged in for longer than 5 hrs in weather over 30 degrees it can scorch the coolant............
Other than that no detrimental effects............
smokinlmm is offline
post #5 of 28 (permalink) Old 01-04-2012, 08:15 AM
ADC
yeah i also plug mine in all night long and unplug it in the morning.... what is the ideal temperature to plug it in at?
2005 2500hd LLY Crew Cab
Black Moto Metal Rims 285 Fierce Attitude tires, black bowtie, black toolbox, Rhino lined bed and rockers, Leveling Kit, Towing mirrors, 5 inch turbo back exhaust, EFI live tuning by "IDAHO ROB"
ADC is offline
post #6 of 28 (permalink) Old 01-06-2012, 09:02 AM Thread Starter
i was wondering the same!
2011 GMC 2500HD LML
Steering Braces
55W 8K HID's
Denali 18" Rims
post #7 of 28 (permalink) Old 01-06-2012, 09:14 AM
LMMzach's Avatar
I've heard on newer trucks not till below zero
LMMzach is offline
post #8 of 28 (permalink) Old 01-06-2012, 09:30 AM
badassstepsides's Avatar
Anytime it gets into the 20's or below ill leave my Pete plugged in all night. They only get maybe 125 degrees and if you think about thats alot less then operating temp so how would it "scorch"" your coolant?. Just make sure to never start your truck with it still plugged in, some strange cases of them exploding can happen from water pump cavitation.
Garett-24 07lbz CC/SB,Lowered,Big Dipper IV,Suncoast "777",Pump rub fix,Fass220,MBRP 3"Dp 4"split rear exit w/5"tips,Efi wDsp5,SDP EGR delete,PCV rerout,PPE fuel bypass plug and ported fittings,Cognito UCA's and brace kit,kryptonite tie rod's,Moog Idler/pitment arm,Bilstein Shocks,Sb Intake,Isspro EV2 Pyro/boost/trans,305/50/20's on 20" Gloss black Hoss's,Pioneer Indash Touch screen Nav,All on mod,8k HID's (Hi's,Low's,Fog's) 15% Window tint
56 Chevy Pickup-Built 350,M21 4speed,13.5@100
55 Chevy sedan-350/350
57 Chevy Sedan-Soon to have ls1/T56
49 GMC Rat rod pickup-chopped and channeled
2010 StreetGlide
badassstepsides is offline
post #9 of 28 (permalink) Old 01-06-2012, 09:42 AM
gr8shot's Avatar
If you leave it plugged in for 8 hours a night, 5 days a week it'll cost you $3/week. 10 hrs a day, 7 days a week goes up to $5.25/week. Not terribly expensive, but it all adds up.
After about 2-3 hours it isn't doing anymore good anyway. Get a timer set for 3 hrs before you leave for work. And don't bother plugging it in unless its below zero.
Sent from my phone, probably while driving and eating a sammich
Jesse
2004 LB7
Tastefully modded
Lots of miles
Built by Husker Diesel
gr8shot is offline
post #10 of 28 (permalink) Old 01-06-2012, 10:14 AM
^^ agreed timer works best and as long as your on a set schedule or remember to re set it if you have to wake up early.Being a truck driver and sometimes not knowing when you will be leaving its just safer to leave it plugged into a properly working box w/ a braker incase it ever shorts out. But if your glow plugs are working properly you shouldn't have any problems till its below 0. And at that temp I'd be more worried about treating my fuel haha.
2010 StreetGlide
