diesel exhaust fluid problem - help! - Chevy and GMC Duramax Diesel Forum
post #1 of 14 (permalink) Old 02-29-2012, 11:55 AM Thread Starter
Unhappy diesel exhaust fluid problem - help!
I have a 2011 duramax with under 10k miles that has been in the shop almost continuosly for the last 4 weeks due to the exhaust fluid issue and i dont know what to do...My dealer says they have finally replaced the entire exhaust fluid tank and sensors but cant recalibrate the truck. they say they are in touch with the "regional technician" which i assume means the GMC representative for this dealer...No answers. How does one get answers on this from GM? is there a systemwide problem with DEF systems in GMs such that a recall should be issued? anyone know anything? aghhhh!
fundygundy is offline
post #2 of 14 (permalink) Old 02-29-2012, 12:00 PM
twinturbo3150's Avatar
What problems are you having? I just bought a 2011 that had 8 miles on it and it now has 800 miles on it and my DEF light came on and i took it in this morning and they had forgottin to fill it. So they filled it and also did the recall. Which was reflashing the ECM for the DEF system.
twinturbo3150 is offline
post #3 of 14 (permalink) Old 02-29-2012, 12:31 PM
Keep all your documents and research lemon law in your state.
2011 Black Denali CCSB
2008 White Z71 ECSB (unfortunately sold to my brother, it doesn't shake)
camino70 is offline
post #4 of 14 (permalink) Old 02-29-2012, 12:38 PM Thread Starter
dealer service dept update just received
they just told me there are two in line exhaust fluid sensors - one at the particulate filter and one at the turbo (there are also new sensors in the newly installed DEF tank). They just ran a diagnostic, as suggested by the GM tech, and it showed one sensor way out of range - So, GM is overnighting 2 new sensors to put in...tomorrow will tell if works
post #5 of 14 (permalink) Old 02-29-2012, 01:09 PM
Keeping my fingers crossed for you.
2012 Silverado 2500HD Duramax Long Bed Crew Cab
Real pickup trucks don't need stacks
RyanZ71 is offline
post #6 of 14 (permalink) Old 02-29-2012, 01:34 PM Thread Starter
Thanks Ryan. i have had 2 f250s and 2 z71's and this duramax. And, despite the limited amount of time in the duramax, i have otherwise been thrilled with it. I really hope they get this silly exhaust fluid injection system fixed as i do love driving the truck.
post #7 of 14 (permalink) Old 02-29-2012, 04:46 PM
I do too. I've also heard from other sources that there have been issues with DEF freezing and other issues on the other brands too. It's a shame what the auto makers are forced to do now a days thanks to the enviro hippies.
RyanZ71 is offline
post #8 of 14 (permalink) Old 02-29-2012, 04:48 PM
^^^The recall on the ecm reflash is suppose to take care of the DEF freezing! so I was told
TSB # 11001 software V2399 Diesel Exhaust FLuid Calibraton to Prevent cold weather Freezeing recalebrate sensor in Diesel Exhaust Fluid tank
post #9 of 14 (permalink) Old 01-16-2014, 07:44 AM
Since I have had my '11 Duramax, it has been to the dealership twice for the DEF system, and once to a private truck shop. The truck shop replaced both nox sensors and the entire DEF system 10,000 miles ago. Yesterday the service exhaust light, and the service engine light came on again! Codes read that the nox sensors are gone, and there is a problem with the DEF system!
Called the dealership where I bought the truck, and the service manager told me his diesel guy has no idea what is going on, and that I should continue to work with the private truck shop.
He says there is nothing the dealership can do, and that GM's technical bulletins do not address the issue
I am now in the process of having the truck shop eliminate the system!
My next stop will be a Ford dealership, thanks GM!
Downtoearthnh is offline
post #10 of 14 (permalink) Old 01-16-2014, 08:40 AM
DuramaxForum Guru
dukcaln's Avatar
you will be back! once you do a dpf delete, why switch to a Turd!
04.5 LLY ECSB 4WD On 22's, Ram Air Hood & Tonneau, 3" Drop w/Fox 2.0, Kryptonite Tie Rods, Kryptonite SS Center Link, Kryptonite Death Grip & Xtreme Idler Support, Kryptonite T-Case Brace, HSP Intake, HSP Turbo Inlet, HSP Hot-Cold Pipes, FASS 150-FASS Bowl Delete w/Beans Sump, PPE Fuel Mods, Built Trans w/Precision ML TQ - Idaho Robs EFI Live - 1/4 @ 13.01 - 103.8mph
dukcaln is offline
