Anyone try the cat filter adapter from Aligator? thoughts? - Page 8 - Chevy and GMC Duramax Diesel Forum
Old 10-23-2012, 06:55 AM   eBay Motors  #71 (permalink)
joshmundy's Avatar
Originally Posted by Blackcloud556 View Post
answered. killed my hard drive on my new computer so i have been sparse the last few days . manged to recover 80gb of data.
back your shit up!!
Yes always back it up!!
I'm a network admin and you would not believe how much important data people think is just safe sitting on a drive. Cloud storage or a file server makes this a much simpler task
Glad you got 80 gb back, that's alot of data
2008 Chevy 2500HD LTZ CC/SB LMM
NorCalTruck Stage 5 Cognito Leveling Kit - Cognito UCA, Fox Resi Shocks, Rare Parts HD Tie Rods, Cognito HD Swaybar Endlinks and HD pitman and idler arms.
BMF M80 death metal wheels 17x9 Nitto TeraGrappler 285/70-17
EFI LIVE with locking dsp5 switch tuned by Kory Willis
Edge CTS Insight with pyrometer, MBRP SS Turbo Back 4" exhaust no muffler w/ 5" tip, EGR Block Plate
Transgo Jr, PCV Reroute, Resonator Plugged
Big Thanks to Following Vendors!!
NorCalTruck Alligator Diesel Performance
joshmundy is offline   Reply With Quote
Old 10-23-2012, 08:06 AM   eBay Motors  #72 (permalink)
Go Green!
Blackcloud556's Avatar
Got everything on my 2tb external now.
Blackcloud556 is offline   Reply With Quote
Old 10-30-2012, 06:52 AM   eBay Motors  #73 (permalink)
CactusBob's Avatar
Link says product not found?
2006 Chevy Silverado CCSB 4x4 LBZ
1999 Pontiac FireHawk Trans Am
1991 Pontiac WS6 Trans Am
1984 Harley Davidson Wide Glide
CactusBob is offline   Reply With Quote
Old 10-30-2012, 07:01 AM   eBay Motors  #74 (permalink)
SoCalMike's Avatar
Diesel Performance Parts & Products | Alligator Performance
look at this too. Diesel Performance Parts & Products | Alligator Performance
http://www.trollperformance.com/
SoCalMike is offline   Reply With Quote
Old 10-30-2012, 08:13 AM   eBay Motors  #75 (permalink)
I bought this adaptor and I am happy with it. Couldn't beat the price and how easy it was to install. Took literally 10 min.
-06 LBZ CCSB (white + debadged)
S&B intake, 4in turbo back exhaust, Diamond Eye DP, EGR Block off, PCV re-route, EFI live (IdahoRob), AD 165, Transgo Jr, Alligator Cat adaptor/filter, Cognito UCA's/pitman/idler arms, Sulastic shackles(WASTE OF MONEY), Billstein struts/stabilizer, Fabtech Tie Rods, B&W turnover ball, Edge insight CTS, Alpine dvd h/u, 4300k HID's, Leveled mirrors, Amsoil fluids, 285/75/16 Goodyear Duratracs
Whiskerbiscuit is offline   Reply With Quote
Old 10-30-2012, 08:19 AM   eBay Motors  #76 (permalink)
knaffie's Avatar
So I just have to ask. Why is it that the other filter adapters require taking the filter head apart and this one doesn't? What is better / worse about this one compared to the others? Obviously a simple spin-on is preferred, but are we giving up any functionality, flow, etc.?
06 CCSB LBZ 4x4 LT3; torsion key lift (leveled); 265/75-16 Pro Comp A/T on OEM wheels (winter), BFGoodrich Rugged Terrain 275/70-18 on XD Diesel 18x9 (summer); MBRP 4" turbo back with Corsa muffler; EGR blocked; Edge Insight CTS gauges; EFI Live DSP2 by Idaho Rob - 80HP DD and 40HP tow with turbo brake (love it!); Rancho 9000XL shocks; updated rear cab mounts; Transgo Jr.; Merchant Automotive tie rod sleeves; everything synthetic; Access Tonneau hiding Line-X; tinted windows 5% all around; Tekonsha P3 brake controller; HIR bulbs, more to come soon......
knaffie is offline   Reply With Quote
Old 10-30-2012, 09:44 AM   eBay Motors  #77 (permalink)
Go Green!
I was having back end issues with that product listing. so i deleted it and started over. which changed the link for it. damn random ass computer glitch.
Old 10-30-2012, 09:51 AM   eBay Motors  #78 (permalink)
Go Green!
The theory is that it flows more fuel. Im dont think anybody has actually tested both adapters to see if there is a flow drop or not. I do know that i have seen 700hp twin turbo trucks who still run the factory filter. so the check ball cant be that restrictive.
Old 11-20-2012, 04:35 AM   eBay Motors  #79 (permalink)
knaffie's Avatar
YES YOU DO NEED TO TAKE THE CHECK BALL AND SPRING OUT!!!!!! Mine ran fine for a couple days, then last night wouldn't start. So in freezing temperatures with a flashlight between my teeth, I took the check ball and spring out and it fired right up.
I called Alligator specifically to ask if you need to take the check ball and spring out and was told no, just spin on the filter and run it. It wasn't hard to do, but I would have rather done it in 65 degree weather in the daylight when I originally installed it.
Alligator will be getting a call today about this. I am pissed.
HUGE thanks to Dane at Mad Jack (where I got the Donaldson filters from) for taking my call and going out of his way to help me out!
MadJack Diesel Performance - MadJack Diesel Performance
Old 11-22-2012, 08:40 AM   eBay Motors  #80 (permalink)
First time Duramax owner....Happy as the proverbial pig in the poo. Nephew and I both bought 06 LB7's. Diesel filtration however is not a new thing to either of us. Commercial boat captains learn about fuel and water rather quickly.
In my life no truer words ever spoken: "If a diesel engine won't run....it's fuel".
From the Big EMD's down to smoky old Detroit 2 strokes... clean fuel is imperative. That is why most marine applications filter primary to 30 microns and secondary to 2 microns.
Keeping that in mind I ask: What is the factory filter micron rating? 10? If it is, then wouldn't replacing it with a 2 cause it to stop up too soon? I would like to have 30 microns on the suction side and 2 on the pressure side.
Lastly: Napa filters are wix filters.... and they are good.
2006 GMC 2500HD SLT CCSB 4WD, K&N, Autocal DSP5,RDS Toolbox/Transfer Tank, Nicktane Cat Filter, PCV Reroute, Toyo 285 AT II's, FASS 150 HD, ADP Sump, EGR Block, leveled.
CapnDean is offline   Reply With Quote
