which gear is best for towing?? - Chevy and GMC Duramax Diesel Forum
Old 11-08-2012, 02:00 PM   eBay Motors  #1 (permalink)
Heres the deal
2006 3500 single axil Duramax 4wd, extended cab, 8 ft bed, 63000 miles.
Was pulling my toy hauler (heavy) up the fla turnpike and tried a couple of things.
MFG readings from dash panel
numbers approximate but very close
held speed at 55 MPH on cruise
in 4th gear got 15 MPG @ 2200 RPM
in 5th gear got 13.5 MPG @ 1900 RPM
in 6th gear got 11.5 MPG @ 1650 RPM
I like the higher miliage but which is best for the drive train?
Thanks
seamore is offline   Reply With Quote
Old 11-08-2012, 02:21 PM   eBay Motors  #2 (permalink)
FAIRCHASE's Avatar
I beleive peak torque is 1600-1700. I am suprised at your MPG.
FAIRCHASE is offline   Reply With Quote
Old 11-08-2012, 02:31 PM   eBay Motors  #3 (permalink)
Hotdogstand's Avatar
I'm personally surprised at such high mileage in 4th and at that RPM.
2003 Chevy 2500HD D/A ECSB 206K
EFI Live, AD 150, Kryptonite tie-rods, MBRP 3" downpipe, MBRP 4" turbo back, batmowheel & BD wastegate, 33" BF Goodrich A/T KOs on H2s
Goals: Built trans and 4" lift, and maybe something about this turbo (again)
Hotdogstand is offline   Reply With Quote
Old 11-08-2012, 02:34 PM   eBay Motors  #4 (permalink)
DieselLuver's Avatar
Hard to believe 15mpg at 2200rpm. Need to hand calculate
2007.5 Silverado 2500HD CCSB LTZ LMM
- 6" Fabtech - 35" Procomps - 17" Xd Spy's - Efi live by DDP - MBRP 5" with muffler and 6" tip - Resonator plugged
2011 Sierra 2500HD CCSB LML (Buisness vehicle) - 2.5" leveling kit, 35" micky Thompsons, 20" fuel boost rims - color matched cut out style flares
www.TrollPerformance.com
DieselLuver is offline   Reply With Quote
Old 11-08-2012, 03:46 PM   eBay Motors  #5 (permalink)
Next time try you test with the tow haul engaged. Your rpms indicate you did not have tow haul engaged and the reason for the lower MPG's in the higher gears. Most likely when you were in 4th the torque converter may have been locked. But in 5 th and 6th it was not.
If it was your 5th gear rpm should have been 1562 and the 6th gear should have been 1342.
lavarock is offline   Reply With Quote
Old 11-08-2012, 04:07 PM   eBay Motors  #6 (permalink)
LHN...We ARE the Joneses
Towin' heavy, higher RPMs, lower gear, less boost, lower EGT.
I show people again and again when we're on cruise and towing big/heavy; come down to 5th from 6th and it bumps from 17xx to 21xx or so and the DIC will just start clicking up by the tenths.
Never have messed around much in 4th, too slow.
Old 11-08-2012, 04:40 PM   eBay Motors  #7 (permalink)
chevor's Avatar
I just dont like to listen to all that noise. I like the truck as quite as possible. Personally when I pull I drive with my foot in M mode. Just hold steady on the throttle and downshift before the hills. I usually dont go over 60. It depends on the wind.
chevor is offline   Reply With Quote
Old 11-21-2012, 08:04 AM   eBay Motors  #8 (permalink)
Thanks folks, will be towing tommorow and check again, maybe my mpg readout isn't correct
Old 11-21-2012, 08:26 AM   eBay Motors  #9 (permalink)
Go Green!
Blackcloud556's Avatar
Yep, I like kicking it down a gear to give her some rpms, push some air and reduce egts
Im with everybody else tho. You cant trust the DIC numbers. Also to get accurate numbers you would have to make the same round trip each time.
I made a long road trip to utah and was getting anywhere from 13-21mpg depending on the terrain i was on. So the only way to check accurately what tune changes would do would be the very next day to run the same trip. because even outside temp can change it a lil bit
Blackcloud556 is offline   Reply With Quote
