| Senior Member Join Date: Oct 2010 Location: Southeast Iowa
| v8 diesel vs. I6 diesel Ok guys first off I just want to say I love my truck, but I am just wanting to know why you guys believe a v8 diesel is superior to a I6 diesel. I have been wanting to find this answer for some time now. I'm not just talking Power Stroke, Cummins, and Duramax. I'm talking just design in general. What has really got me thinking about this more and more is you will see on youtube that A LOT of the road trains down in Australia are pulled by v8 Macks, where as here in the states you hardly ever see a v8 semi. Thanks for reading and answering guys Michael
__________________ Mike - 23 SOLD - 2003 Cummins | 5" TBE exhaust w/ 7" tip | Boost, egt, tranny gauges | 2.5 inch leveling kit | 285/75/17 Nitto Terra Grapplers on stockers Current - 07 lbz - EFI Live | 5" Diamond Eye | C.A.I | EGR Blocked | Pump rub fix | 285/75/16 Cooper Discoverer S/T | Alligator tranny lines |
| Senior Member Join Date: Feb 2012 Location: Dodge City, KS
| First off, this is just some opinions I have just to be able to add to your thread. I am not overly educated on the subject so none of it is necessarily fact. I think they both have their advantages and disadvantages. In my opinion, an inline motor is probably the better design when it comes to a truck that pulls a lot of weight as its sole purpose. They inherently produce more torque at a lower rpm than a v8 diesel does. However, I don't think they have the RPM potential that a V design can have. They also generally have a very strong foundation by design. I think the length of the crankshaft allows more main bearing surface, but this design also takes up a lot more room and weighs more than our v8's. I'd say a big reason you see the v8's in pickup's like ours is the fact it can compare in size to a gas counterpart. The cummins engine is pretty tall as well as long. Not saying they cant put it in a pickup, as it obviously fits. I think a v8 works well in a pickup application as most people that own them don't need to make power as low as an inline, and the RPM potential makes them very streetable. The are a decent amount of V-design diesels that aren't so great compared to an inline cummins in my opinion. I feel the duramax is the exception, not the rule. It has been well engineered and updated frequently as problems were found.
__________________ 2003 Silverado 2500LS CCSB 4x4 ZF6 EFI live with DSP5, Nicktane Aux Filter adapter and Filter head adapter with CAT water separator and 2 micron filter, Raptor 150 lift pump with check valve bypass, MA Engine Mounts and Trans Mount, MA Pump Rub Kit, SBC Dual disc, Straight pipe, Roadmaster active supension, Moog pitman/Idler/Support Bracket, Cognito support kit, Rare parts tie rods, Profab Turbo Horn, Intake heater delete, Kennedy high idle and airbox mod ------------------------------------------ |
| DuramaxForum Veteran Join Date: May 2009 Location: East Wenatchee WA
| 07keo02 pretty well nailed it. Inline engines do produce torque at lower RPM but don't like high RPM's in general. The bigger you go the less they like to run the high RPMs. Cummins actual makes v-8 diesels or use to anyway. Cat makes some of the biggest v style diesels for some of there big off road equipment. Big rigs run inline mostly do to fitment and the low end torque. Which most V style diesel will produce peak torque a few hundred rpms after a similar size inline now. It isn't so much that they produce more power or torque then v8s anymore it's mostly come down to fitment. The V8s seem to be easier to produce big power with and also seem to be able to spool larger turbo's more easily then an inline of similar size.
__________________ Adam BIG THANKS TO ROB CODDENS AND DUSTIN GULLETT AT ATPTRUCKS FOR ALL THERE HELP WWW.ATPTRUCKS.COM www.alligatorperformance.com DMAXSTORE.COM Last edited by chevy71pickupman; 11-16-2012 at 06:37 PM. |
| Junior Member Join Date: Oct 2012 Location: Seymour IN
| I work at Cummins so I deal with the inline motors daily. Cummins does make a V8 engine called the V903 which is mainly used for military perpouses now. Inline motors have larger bearings areas for the rods. The also have less side loaded of the piston which is inherent of a V motor. Cat does make very large offroad V motors (254 liters V16) Cummins also just started making a 95L V16 called the Hedgehog with an option to go larger in the future. Inline motors are longer and taller due to the design and being able to get the stroke and bore spacing needed for a larger displacement but with only 6 cylinders. In my opinion inline motors are easier to work on. Each engine has the pros and cons. |
| JUST TROLLING AROUND Join Date: Feb 2010 Location: NH
| the mack superliners your talking about has the cat 3208 eng they were great eng but in big trucks now the I6 like the 3406 cat are better from 1980s-2007 all junk after that
__________________ 05 lly 2500hd ccsb http://s1135.photobucket.com/albums/m635/vinnie_1965/ |
| Thanks for the input guys. Now you guys talking about the big cat motors in off road equipment, why does cat use a V for that? Wouldn't a inline be better since it has a bigger stroke?
| Senior Member Join Date: Sep 2012
| i would think that overall engine size has alot to do with it. you can really only make a motor so big before it becomes more efficant to add cylinders. a V-8 would be a much better fit than I-8.
__________________ 07 lbz ccsb Danville 4094anvt w/billet wheel, floor-it-diesel stg II cp3, atp tuning, suncoast, RDL uppipes, egr delete, Y bridge, 5" ex, edge insight, EXAXT, cognito uca's, traction bars, AD II 165, banks IC, extra leaves, 305/70/16's, blacked out grill, cowl hood, tough country bumpers Dyno - 582hp 1209tq - SJD, 561hp 1247tq floor-it-diesel (stock turbo & inj.) Track - 12.82 @ 105.5 mph @7300lbs 1.82 60 ft 07 lbz rclb tuned by Kory, 4" ex, RDL egr delete, banks IC, edge insight, bd lift pump w/remote WS, nicktane, ranch hand front |
| Like stated before a V motor is better suited than an I because of the packaging of the engine when they become that large. A V engine also helps with packaging of the turbos an aftercoolers since they can be put in the intake valley. I know for a fact the turbos on the large CAT motors are the size of a pizza pan and there are 2 of them on those engines. The large engines are low speed engines so max rpm is around 1100rpm. This is mainly due to engine vibrations with an engine that large |
| DuramaxForum Veteran Join Date: Nov 2009
| Inline 6 has half as many moving parts as it's v8 counterpart. Half as much to go wrong....at least on paper.
__________________ My Stormtroopers 2003 ccsb lb7 s364 12.6@107 Sold! 2011 Sierra 1500 ccsb 5300 vortec 2005 ccsb lly stock...ish |
| Longbeds FTW Join Date: Oct 2008 Location: Natrona Heights, PA
| I think inline motors are smoother.
__________________ 06 LBZ EC/LB 4x4 Built Motor/Trans • Bullseye s375 • Stock CP3 • Built and Tuned by Blackout Performance • 11.76 @ 115 There are a lot of hacks in this industry. Be very careful with who you choose to do work on your truck! |
