Leaving the ignition turned on - Chevy and GMC Duramax Diesel Forum
post #1 of 8 (permalink) Old 11-18-2012, 08:29 AM Thread Starter
Question Leaving the ignition turned on
I was curious with my 2011 Chevy D/A if it is okay to leave the key turned on to leave the ignition on. I am asking because I have a truck camper with a battery disconnect. There are times I would like to leave the key on for extended periods of time to utilize some of the trucks battery bank. I have been curious about this for some time! My specific question is will leaving the key on for hours and hours damage my truck in anyway other than drawing down the batteries?
Thanks in advance
Dave
dave17352 is offline
post #2 of 8 (permalink) Old 11-18-2012, 08:35 AM
07keo02's Avatar
I assume your asking if this will affect anything other than the batteries? I don't see why it would hurt anything else but it could obviously draw your batteries down to where you couldn't start it but that would be a judgement call. I use the overhead light in my toy hauler while connected to my truck but thats it and they do not draw much power. I guess I may not understand exactly what your asking, when the trailer is hooked up on mine the lights work without leaving the key on.
2002 Silverado 2500 CCSB 4x4 Auto
2003 Silverado 2500LS CCSB 4x4 ZF6 (Sold)
07keo02 is offline
post #3 of 8 (permalink) Old 11-18-2012, 08:41 AM
Lincoln Diesel
Aaron@LDS's Avatar
It should be fine. You could kill the batteries as you know, but thats all I can think of.
-Aaron-
Need LB7 Injectors? Check these prices out!
Lincoln Diesel Specialties
"Quality Parts and Service at an Unbeatable Price"
Or call us... 920-361-7700
SOLD
2001 GMC Sierra 2500HD, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler, FASS 150, LBZ FPR, Shimmed FPRV, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires
Aaron@LDS is offline
post #4 of 8 (permalink) Old 11-18-2012, 08:42 AM Thread Starter
Keo; I should have been more clear. What I am asking is will it do any damage to the trucks igintion system or electrical system to leave the ignition turned on for hours and hours at a time.
post #5 of 8 (permalink) Old 11-18-2012, 11:40 AM
07keo02's Avatar
Okay, that's what I was kind of thinking, wasn't trying to being ignorant or anything just making sure. I agree with 01 D max and think that it would only hurt batteries as well. Will the accessory position not provide the power?
07keo02 is offline
post #6 of 8 (permalink) Old 11-18-2012, 12:28 PM
If you turn on the ignition, to the run position with the engine cold the glow plugs would cycle.
I have worked on engines all my life, spent 19 years at FreightlinnerI live in the Kootenay region of B.C. I have a 2007 NBS White 3500 GMC SLE Duramax Alison 17 inch aluminum SRW Crew-cab long-box White linex in the box and black in the wheel wells BW turn-over ball. all stock.
Johnp33 is offline
post #7 of 8 (permalink) Old 11-18-2012, 12:40 PM Thread Starter
Yes it has to be in the run position to connect my batteries to the truck camper. That is how the relay is set up. And yes the glow plugs would get activated would they continue to cycle over and over again or just activate once. I would really like to get a definitive answer on this.
post #8 of 8 (permalink) Old 11-18-2012, 03:34 PM
Lincoln Diesel
Aaron@LDS's Avatar
When the light goes out the glow plugs have ended their cycle. I wouldnt want to leave the key on all the time personally. The charging terminal in your trailer plug should feed power at all times... Unless you mean your is setup to cut power unless your key is on. I'd sooner run jumper cables to the camper batteries if it were me. Then your truck wont use any power with the key on, but you canstill use the trucks battery power.
-Aaron-
SOLD
