High Idle, good or bad?! - Chevy and GMC Duramax Diesel Forum
Old 11-19-2012, 03:26 PM   eBay Motors  #1 (permalink)
james007's Avatar
I bought a BD high idle kit for my truck a while back because i was reading a topic stating that while your truck is idling at 700ish rpm a small amount of fuel continusly goes into your crank case. so hear i go by this. I use it sometimes when im running in somewhere so this wont happen, this is true? if not why do they make this high idle kit? and is it harmfull to my truck? btw the high idle revs at 12h00is
2003 LB7 "Daisy"
Full K&N Intake
EFI Live
BD Watch Dog
4" MBRP to 6" single chrome stack
PPE boost vavle
BD High Idle
james007 is offline   Reply With Quote
Old 11-19-2012, 03:28 PM   eBay Motors  #2 (permalink)
6266diesel's Avatar
I thought it was only to warm the truck up when cold.
Evan
05 lly 4x4 single cab 2500hd
EFI live by kory, blocked resonator,
4in straight pipe,afe mouthpiece,
blocked egr, isspro egt gauge,
295/70/17 trail grapplers on h2s.
89 k5 6.2 diesel 8in lift 38.5 boggers
X over steering D60, 14bolt
6266diesel is offline   Reply With Quote
Old 11-19-2012, 03:33 PM   eBay Motors  #3 (permalink)
Offical LB7 "Tech"
01 D_Max's Avatar
This was the main purpose.
-Aaron-
2001 GMC Sierra 2500HD, Limited Edition, CC,SB
EGT's Never higher than 1150*
Cognito Braces, and ATP Sleeves, BD Manifold, ARP H.Studs, BATMO, M.P. mod, MA Aluminum Bleeder, PPE Boost Valve, Banks Ram Air- Intercooler- Wastegate, FASS 150, LBZ FPR, Shimmed FPRV, Built Trans, 4" MBRP turbo back exhaust w/6"tip, Corsa Muffler
Air Lift, Bilstein Shocks, Leveling Kit, Recon LED tail lights & over cab lights, 20" Forged Aluminum WELD Racing Rims, 295/55/20 Nitto Trail Grappler Tires,
MANY More extras inside...
01 D_Max is offline   Reply With Quote
Old 11-19-2012, 03:38 PM   eBay Motors  #4 (permalink)
gmctruck44's Avatar
Or to use PTO accessories. Your engine should not have cylinder wash if it is operating normally. A oil analysis is the best way to identify if you have a cylinder wash problem (fuel in oil) usually caused by failed injector or during engine warm up.
2007 GMC Seirra 2500, Reg. Cab Long Bed
EFI LIVE, Diamond Eye Duals, Fass lift pump, Transgo JR, Shimmed Relief valve and Ported Fittings
18" XD Hoss Wheels, 285-65-18 NITTO Trail Grapplers
2007.5 GMC Seirra 3500HD CCLB DRW SLT
stock
1994 4x4 Chevy S10
350 small block
fuel injected
http://www.dmaxstore.com/
gmctruck44 is offline   Reply With Quote
Old 11-19-2012, 03:39 PM   eBay Motors  #5 (permalink)
james007's Avatar
wow i never would have thought that, i thought you wanted the truck to warm up slowly
2003 LB7 "Daisy"
Full K&N Intake
EFI Live
BD Watch Dog
PPE boost vavle
BD High Idle
Old 11-19-2012, 03:41 PM   eBay Motors  #6 (permalink)
james007's Avatar
so the main reason for this part is to warm your truck up?
2003 LB7 "Daisy"
Full K&N Intake
EFI Live
BD Watch Dog
PPE boost vavle
BD High Idle
Old 11-19-2012, 03:45 PM   eBay Motors  #7 (permalink)
gmctruck44's Avatar
[QUOTE=gmctruck44;1836495]Or to use PTO accessories.QUOTE]
I dont know if LB7's have the elevated idle option but my LBZ came with one automaticlly raises the idle when the engine temp is bellow 32 degrees!
stock
1994 4x4 Chevy S10
350 small block
fuel injected
Old 11-20-2012, 05:35 AM   eBay Motors  #8 (permalink)
KC2GIW's Avatar
[quote=gmctruck44;1836501]
My LMM does this too. 1000 RPM idle with the turbo vanes closed. My neighbors LOVE it.
2007.5 GMC 2500 HD. XC/SB. Edge CTS, MBRP 5", leveled.
2002 Z06. 520/500 hp/tq @ wheels.
2009 VRSC DX. Screamin' Eagle "race" cams, Dyno tuned, TAB exhaust, etc. 130 hp @ wheel.
2007 F8 Sno Pro. Now in 1000 tiny little pieces in the woods. That was fun.
facebook.com/matthew.antonio
KC2GIW is offline   Reply With Quote
Old 11-20-2012, 08:18 AM   eBay Motors  #9 (permalink)
premis's Avatar
My LLY has a high-idle setting built in, if it's cold it will idle up to warm the motor. It sounds like a jet taxiing in my driveway!
There is no way idling it causes fuel to go in the crankcase. I bet I have idled my truck a cumulative 500 hours and never had a problem. It runs at least 10 minutes every morning year round to warm up and usually stays on when I run into a store or any other place for less than 15 minutes.
A buddy of mine in AZ use to idle his for 5-6 hours while he was out riding just to keep the A/C on.
2005 Black Duramax Crew Cab Short Box
Edge Juice w/Attitude - 4" straight pipe (shaved the muff and killed the kitty) with 5" tip - Blocked EGR - triple guage pod (Aux Fuel, Air Bags, Boost) - air bags w/compressor and 2 gallon air tank - train horn - tint (5 back/15 front) - custom grill - pace roll-top cover - 28 gallon aux fuel tank (gravity feed) - Pioneer AVIC-D3 in dash DVD/GPS/Bluetooth unit with XM Nav Traffic - metra on-star adaptor - PAC SWI-PS steering wheel remote interface - 2 10" MTX subs with Rockford amp - head rest monitors - passenger visor monitor - viper remote start - 07 mirrors (w/ DIY leveling) - DIY pre-OEM Cat fuel filter - boost stick - AEM Brute Force CAI - 20" black spoke KMC wheels mounted with 305x50x20's
premis is offline   Reply With Quote
Old 11-20-2012, 08:45 AM   eBay Motors  #10 (permalink)
Super Moderator
jc1843's Avatar
There are TWO different "High Idle" programs--
"Elevated idle" is a factory program that can be set on/off through the steering wheel controls or other. It ONLY will work if the temperature is below freezing and will turn off if you apply the brake or put in gear. The idle is only one speed -1000 RPM-??
The other idle is "High Idle" -- is normally a PTO option where there are three different speeds. It is set through the cruise controls, and will work at any temperature. The option can be added to most vehicles by sending power to the ECM- terminal.
If wired correctly, it will turn off with the brake or when into gear.
