| I'm new need help I bought my first diesel its an 06 duramax I'm trying to learn about tuners exhaust and air filter can anyone tell me the best exhaust for good sound and a good tuner and air filter I'm not looking for extreme stuff I don't wanna build transmission I just want a great sounding daily driver that has enough hp torque but not to much to be tearing stuff up also will I have to change injectors if I use a tuner? Any advice and help would be greatly appreciated |
| DuramaxForum Enthusiast Join Date: May 2011 Location: Pinedale WY
| Use the search bar on top of the screen. Type what you want to know about. Bam, tons of good threads with all your answers. No need for an intake. If you want it loud get a straight pipe. Pipe is pipe. No you don't have to change your injectors to run a tuner. Get EFI live. Sent from my Autoguide app.
__________________ Caleb 22 2007 LBZ CCSB S475/stock Wehrli Twin Turbo Kit/Suncoast Built by Dmitri Millard EFI Live DSP5 by Duramaxtuner.com 5" DE, rerouted, debadged, demolded, 18X9 BMF Novakanes Stealth wrapped with 285/65/18 Nitto Trail Grappler MTs, 45 gallon transfer flow replacement tank, Amp power steps, All Season bulletproof trans/power steering line kit, Airdog II 165, Nicktane with Cat filter, Edge Insight CTS with pyro ![]() Big thanks, Duramaxtuner.com & Willie @ Synthetic Motorsports |
| Thanks for the reply and y is a air intake not usefull I heard it makes u hear the turbo better and improve mpg |
| No. The stock intake on these trucks is good up to 500HP and flow way good. They also have the best filtration IMO. Wait until you put exhaust on. You will have all the turbo sound you will ever need! I recommend: Kory Willis from PPEI Nick at duramaxtuner Or Rob at ATP for EFI Live. I know ATP is having a black Friday sale, with exhaust and EFI packages. May check it out to save a dime or two. I ran my LBZ tuned for a year without a lift pump. That being said, I also recommend putting on a lift pump before it's tuned. Runs way smoother and pulls harder. Also, block your EGR. Post up a pic of this beast! Sent from my Autoguide app.
| DF Sponsors ![]() ![]() Join Date: Mar 2009 Location: Kathleen, GA
| Hey bud, as far as exhausts go Diamondeye, MBRP and afe Power are all popular and provide improvements in lower egts, small bump in hp and provide a better sound. Normally the 5" systems have a nice grawl to them over the 4" but its a personal preference. As far as tuning goes, custom tuning with an EFI Live autocal or tuned ECM are about the best out there for the Dmax. With this setup, you get a switch that allows you to switch between up to 5 different tunes on the fly as you need them. I offer Kory Willis' tuning and can help with exhaust selection as well. As far as CAIs go, they are right in that the stock setup is pretty good for up to about 500hp. If you are set on getting one, afe Power and S&B are popular. Go with a dry filter over wet. The wet ones tend to foul out the MAF sensor. If I can be of assistance with pricing, let me know. Take care,
__________________ Willie AMSOIL Premier Direct Jobber 06 LLY CCSB EFI Live |
| Okay great how much roughly is the egr block and also the tuner and 5 inch exhaust that you are referring too i may stay away from intake if its just wasted money |
| And is this egr block a tune or involve removing/adding parts and important hearing that doing egr delete requires deleting something else as well? |
| Any tune that adds more than 100 HP over stock, can damage the Allison. The TransGo Jr. Allison shift kit, is recommended for the 6 speed.
| Senior Member Join Date: Apr 2009 Location: Green Mountian State
| Quote:
The items i have added to my truck are what I did to achieve the results you wanted. I went with a 4" exhaust over the five because i have read the 5" has a slight more drown especially when on the highway. I might add the quite tone front pipe to mine because i love the sound outside, just want it quite as possible inside when on the highway. My recommendation is go with EFI live for a tuner! My edge tuner is great, never a problem but now want EFi live so just start there.
__________________ 2006 2500HD Crew LLY EFI Live...4" exhaust...Transgo JR...Blocked... EDGE EVO RACE as a monitor AMSOIL nose to tail Don't blow smoke, it confuses treehuggers into discontinuing the use of soap, which gives normal people a headache. | |
| Senior Member Join Date: Aug 2009 Location: Des Moines, Iowa
| If you are looking for more turbo whistle, remove the turbo resonator, it's the black "box" on top of the engine that says "6.6" on it. Plug the hole on the turbo with a rubber plumber cap, I think it is 2 1/2" For exhaust, if you want to hear the turbo whistle and lower your EGTs, go with a turbo back straight pipe. It does require removing the catalytic convertor and muffler, it is your choice if you want to do that. If you have to smog your vehicle, it will never pass. I bought my 4" straight pipe on ebay for $285. I would suggest getting an aluminum one, I bought galvanized and had to replace it after 3 years. duramax 4 straight pipe duramax 4 straight pipe | eBay Start with those mods, if you want a little more whistle, a cold air intake with a METAL intake tube will produce a little more turbo sound, but not much. Here is a video of my truck with 4" straight pipe, cold air intake, and turbo resonator removed. I clipped a lapel mic to the bumper on the muffler side, that's why it is so loud. It's actually pretty quiet in the cab. My girlfriend loves when I go under a bridge boosted and then let off
__________________ 2005 Black Duramax Crew Cab Short Box Edge Juice w/Attitude - 4" straight pipe (shaved the muff and killed the kitty) with 5" tip - Blocked EGR - triple guage pod (Aux Fuel, Air Bags, Boost) - air bags w/compressor and 2 gallon air tank - train horn - tint (5 back/15 front) - custom grill - pace roll-top cover - 28 gallon aux fuel tank (gravity feed) - Pioneer AVIC-D3 in dash DVD/GPS/Bluetooth unit with XM Nav Traffic - metra on-star adaptor - PAC SWI-PS steering wheel remote interface - 2 10" MTX subs with Rockford amp - head rest monitors - passenger visor monitor - viper remote start - 07 mirrors (w/ DIY leveling) - DIY pre-OEM Cat fuel filter - boost stick - AEM Brute Force CAI - 20" black spoke KMC wheels mounted with 305x50x20's |
