| Junior Member Join Date: Dec 2010 Location: Syracuse, NY
| Filter Head Removal? The back story is I installed my Cat filter adaptor from ADP the other day and I'm losing prime. Looks like the adaptor-to-filter-head seal is leaking a little towards the back of the engine. I get the feeling this would be easier to deal with if I removed the filter head like in their YouTube video. That being said...I see two wires. Check. Two bolts - already removed these once. Check. Two fuel lines. not-so-check. If I open the bleeder and let air back in to maybe drain some fuel back can I just remove these lines without having to do anything special? Once I hook them back up - if I prime the system normally should I see any other issues? I cant imagine there would be but I thought I'd ask first. I'm being selfish and trying to do it all from the top. Thanks for the . -Matt
__________________ 2007.5 GMC 2500 HD. XC/SB. Edge CTS, MBRP 5", leveled. 2002 Z06. 520/500 hp/tq @ wheels. 2009 VRSC DX. Screamin' Eagle "race" cams, Dyno tuned, TAB exhaust, etc. 130 hp @ wheel. 2007 F8 Sno Pro. Now in 1000 tiny little pieces in the woods. That was fun. ![]() facebook.com/matthew.antonio |
| DuramaxForum Enthusiast Join Date: May 2011 Location: Pinedale WY
| Yep, you are right on track. Just pull both suction lines off. No need to do anything but pull the clamps and remove the lines. Once you are going back together just bleed the filter as you normally would. Sent from my Autoguide app.
__________________ Caleb 22 2007 LBZ CCSB S475/stock Wehrli Twin Turbo Kit/Suncoast Built by Dmitri Millard EFI Live DSP5 by Duramaxtuner.com 5" DE, rerouted, debadged, demolded, 18X9 BMF Novakanes Stealth wrapped with 285/65/18 Nitto Trail Grappler MTs, 45 gallon transfer flow replacement tank, Amp power steps, All Season bulletproof trans/power steering line kit, Airdog II 165, Nicktane with Cat filter, Edge Insight CTS with pyro ![]() Big thanks, Duramaxtuner.com & Willie @ Synthetic Motorsports |
| Excellent! Thanks!
| PS - How does the airdog hold up with snow salt and road junk?
| Senior Member Join Date: Nov 2010 Location: Ogden Utah
| I don't have the air dog I run the raptor and Mine has done great in the snow, salt, and dirt roads for work.
__________________ 2001 EC/SB S475 batmo. Tuning from ?. Trans from EPR 4 inch exhaust. Raptor Traction Bars. 510hp 1244 tq uncorrected. Stock Turbo, injectors,cp3. 13.02, Stock turbo, injectors, cp3. http://www.trollperformance.com/ |
| Te AD does fine in snow/weather. It has a lifetime warranty. Pretty sure they hold up just fine. Haven't heard anything bad about them. I recommend a lift pump if you have any tuning. Better filtration and safer for your injectors. Sent from my Autoguide app.
| Got it off and got it fixed last night. Turns out the sealing surface was all corroded. For some reason the thinner stock filter o-ring sealed OK against it but the thicker ring in the ATP adaptor didn't like it. Went after it with some emery cloth and a scotch brite. On a side note - Am I the only one who has issues with corrosion? It seems like every spring clamp, every nut, every bolt on this truck is covered in rust and it's only like 4-5 years old. Stupid salt. I never drive my cars in the winter - they stay perfect but this thing....everything is a struggle because of rust.
| Oh yah, thanks for the advice by the way - it was easier to take the hoses off the front of the motor rather than try to squeeze my hands between the AC line and diipstick to pull them off the filter head. again...all covered in corrosion. Well jokes on them...now it's all covered in diesel. SMH
| Senior Member Join Date: Sep 2012 Location: Prince George, BC
| Quote:
