Block heater tripping GFCI - Chevy and GMC Duramax Diesel Forum
post #1 of 14 (permalink) Old 11-26-2012, 08:50 AM Thread Starter
premis's Avatar
I had the truck plugged in all night last night for the first time this year. I came out in the morning and it had tripped the GFCI on the outlet. Any one else had this problem? Any good fix?
2005 Black Duramax Crew Cab Short Box
Edge Juice w/Attitude - 4" straight pipe (shaved the muff and killed the kitty) with 5" tip - Blocked EGR - triple guage pod (Aux Fuel, Air Bags, Boost) - air bags w/compressor and 2 gallon air tank - train horn - tint (5 back/15 front) - custom grill - pace roll-top cover - 28 gallon aux fuel tank (gravity feed) - Pioneer AVIC-D3 in dash DVD/GPS/Bluetooth unit with XM Nav Traffic - metra on-star adaptor - PAC SWI-PS steering wheel remote interface - 2 10" MTX subs with Rockford amp - head rest monitors - passenger visor monitor - viper remote start - 07 mirrors (w/ DIY leveling) - DIY pre-OEM Cat fuel filter - boost stick - AEM Brute Force CAI - 20" black spoke KMC wheels mounted with 305x50x20's ----SOLD-----
Now I drive a 2015 Chevy 1500 Z71 LTZ with the 6.2....for now.
premis is offline
post #2 of 14 (permalink) Old 11-26-2012, 09:22 AM
Varty Yo's Avatar
Could it possibly be the cord you ran from the truck to the plug in? Check that out first
2006 LBZ
Mike L Stage Awesome!
Airdog2 165, 5" MBRP Turbo back
EFI Live tuned by Idaho Rob, DSP5, ATP
Cognito set at 8" Nor-cal Truck
Fox 2.0 shocks all around, Deaver 6" springs
SS idler support/ Rare parts tie rods
37x13.50x20" toyo MT's/ XD Hoss wheels, Fuel Octanes
HID's All on mod/ AMP reaserch steps
Varty Yo is offline
post #3 of 14 (permalink) Old 11-26-2012, 09:26 AM
Ya play hard Ya pay hard
DieselDog05's Avatar
i ran a heavier gage cord, solved my problem.If that dont work try to plug into a reg outlet?
2014 Silverado CCSB
Airdog 165 4G
EFI by Kory Willis
PPE Downpipe
Flo Pro 4" Single exhaust
XDP EGR Delete
S&B Intake
Insight CTS2
DRP PCV Reroute
DieselDog05 is offline
post #4 of 14 (permalink) Old 11-26-2012, 11:43 AM Thread Starter
premis's Avatar
Cord is good, it's the same cord I used last year. Also tried it on my miter saw to test it. Worked fine.
premis is offline
post #5 of 14 (permalink) Old 11-26-2012, 11:57 AM
I had same problem, replaced the GFI plug and problem was fixed. 6-7$ at Home Depot and 5 minutes to replace it. Also put it on a programmable timer so it comes on at about 4:30 AM instead of running up my electric bill all night. Works great.
Jeremiah
2006 LBZ W/ EFI DSP 5 by RGR Racing, DP 3794 Stg 2 Turbo, AFE intake and 4" EX. Down pipe, EGR blocked, Autometer boost & pyro gauges. All Amsoil. 235k Miles
D2DAMAX is offline
post #6 of 14 (permalink) Old 11-26-2012, 12:23 PM
Charliechevy's Avatar
I had this issue as well. It wasn't with my diesel, but I live in Alaska and I had to leave my vehicle plugged in over night a lot as it would drop to -60. My problem was I had a 3 way plug that the oil pan heater, battery blanket and block heater plugged into. The three way plug had gone bad causing my GFCI to fault out. swapped my three way plug and everything was good to go afterwards.
2015 Chevy 2500 HD Duramax, Crew Cab Z71 LT, Stock for now, Morimoto Retro Kit soon.
Charliechevy is offline
post #7 of 14 (permalink) Old 11-26-2012, 12:27 PM
nick1camper's Avatar
Just curious, but why do you plug it in? I used to until I realized it has to be well below 0 before it is necessary.
2005 ext cab sb LLY
4" exhaust w/muffler, EGR delete/Sinister diesel, Kodiak LBZ mouthpiece, PCV rerouted, Nicktane/CAT adapter, Autometer pyro & boost gauges, EFI Live by Kory, Transgo, pump rub kit, LBZ intake conv, H2's, Debadged
nick1camper is offline
post #8 of 14 (permalink) Old 11-26-2012, 03:09 PM Thread Starter
premis's Avatar
I've found that plugging it in allows much quicker warm up times and no need for "high idle". That saves me on fuel and neighbors getting mad about a jet engine taxiing in my driveway.
premis is offline
post #9 of 14 (permalink) Old 11-26-2012, 03:35 PM
rms
rms's Avatar
^^^ And, you get warm air in the cab before you get out of the neighborhood.
2007 LBZ 4x4 regular cab
S & B Intake - Diablo Predator
285/70/17 Michelin AT's on H2's - 8' Bedslide
Amp Steps - short KYB's - Fumoto
The Arizona Diesel Club
rms is offline
post #10 of 14 (permalink) Old 11-29-2012, 05:39 PM Thread Starter
premis's Avatar
I've tried multiple cords and multiple outlets, it is definitely a problem with the truck. Does anyone know if the cord can be removed easily so I can check it before ordering a block heater?
premis is offline
