| DuramaxForum n00b Join Date: Jan 2013
| How cold will my Duramax start without plugging in Hello men. I'm new to the forum and live up north. I'm waiting to pick up my new to me - 2008 Duramax this week. It gets damn cold here in the winter. At what temperature does the fear of your duramax diesel not starting begin ? I swore I'd never buy another diesel after a '99 ( brand new ) F250 diesel left me stranded on several occassions. Lol. ...... And here I am. ( buying another diesel ) The truck I traded ( 2004 2500HD 6.0 gas ) silver birch. The 2008 is silver birch as well. So , how cold , and what's the starting procedure ? - glow plugs ? |
| DuramaxForum Enthusiast Join Date: Jan 2012 Location: SLC, Utah
| I start my lly cold in 10 degrees temps daily without issues. A little shaky and smokey but she fires right up no problem. Just turn the key on, wait for the wait to start/coil light to go off then fire it up. And trust me, your new lmm WILL NOT leave you stranded like your old stroker did. Duramax is a whole new machine compared to a 7.3
__________________ 05 lly EFI Live 4094 vvt Built Trans BT Lockup Box Supporting Mods |
| DuramaxForum Veteran Join Date: Sep 2012 Location: South Whitley, IN
| Duramax's have no problem starting in cold weather unlike your old powerjoke so you're good to go
__________________ The Sound Of Madness 2004.5 LLY ECSB EFI Live, MA700 Trans, Airdog 2 165, MBRP 5" with 6” tip, Profab Downpipe, LML Manifold, LBZ Mouthpiece, AFE Stage 1 Intake, EGR Blocked, PCV Rerouted, Resonator Plugged, ADP Race Valve, MA Rear Housing Support, MA Pump Rub Fix, Rancho RS9000xl's, Amsoil Synthetics, Autometer Cobalt’s Boost & Pyro, Tint (5% back, 20% front), HID's, US Speedo Custom LED Gauge Cluster, Line-X’d rockers To Come!! :Profab EGR Delete 4094vvt 40% overs |
| Senior Member Join Date: Aug 2008 Location: Abilene, Texas
| I'm from Texas, usually I will plug mine in when below 20 degrees F. For us down here, that is damn cold. I have had this truck for 2.5 yrs now, and only had to plug in once when got down to 16 degrees F one night. Only thing is, remote start does not work when plugged-in to block heater.
__________________ Black 07.5 Chevrolet 2500HD LTZ Z71 4X4 CC/SB LMM Duramax Garrett 4094 Stage II turbo, ARP head studs 30% over injector nozzles, 42% over CP3, Air Dog II 165 All Season Diesel Super High Flow (EGR delete) kit PPE ported fuel rail fitting and race FPRV EFI Live by Rob Coddens, Built tranny Dyno'd 4/13/13: 643 HP/1086 tq Fabtech 6 in. lift, Maxx Suspension leveling kit 35 X 12.5 Toyo M/T tires on 20 X 10 BMF Novakane Death Metal Black wheels 4" Flo-Pro DPF delete pipe (with bunges), Flo-Pro CAT delete DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource |
| Senior Member Join Date: May 2012 Location: ND
| I would guess the HUEI system would be the cause of starting problems with the 7.3 in extreme cold? To thick of oil so the injectors can't fire??
__________________ 2009 CCSB LMM-EFI live with DSP5 by Idaho Rob. Some other stuff Props to ADP ATP MPF And Husker Diesel DMAXSTORE.COM, Your Duramax Diesel-Only Shopping Resource |
| DuramaxForum Veteran Join Date: Feb 2010 Location: College Station, Tx
| when we used to go to colorado i have had my truck start with no issues. Usually when it was below 10 degrees i would plug it in at the hotel we were at. Well one night when a blizzard blew in it got to -7 outside the next morning and i guess someone thought it was funny to unplug me and my dad's trucks... I can say it was before the storm because the snow was over the extension cords, so they had been unplugged for atleast a few hours. Well my 01 and his 07 started up with very little problem. We always run winter de-gel additives when up there and it wasn't bad. His did better then mine and it took a little longer than normal but not more than one cycle of the starter. Ran rough as hell but didn't die and didn't leave us stranded.
__________________ -Austin- Fightin' Texas Aggie 2001 LB7 2500HD CC/SB 2WD 5" Flo~Pro Straight w/ 7" Tip| ProFab Intake Horn |Spectre Stage-2 CAI | EFI Live w/ DSP-5 | PPE Stage IV Transmission | ProFab Downpipe | PPE Boost Valve | Holley Black Lift Pump | Intake Heater Delete | GlowShift Guages (Boost, Pyro, & Fuel Pressure) | 3" Drop Shackles | 18x9 Falken ORC 952's | Nitto Terra Grapplers 285/65/r18 | Kenwood Deck | 2 12" Kenwood Subs on 2200watts | 4 6-1/2" Pioneers (Doors) on 350watts | JML 6000k HID Lo-Hi/Fog | Herculiner Bedliner | Westin Side Steps | Ranch Hand Full Front and Rear Bumper Replacement. 546hp & 1025 ft/lbs at Lone Star Dyno, Spring Branch Tx. |
| My 03 has fired up in -10 degree weather numerous times(snowmobile trips) now when im home i will not plug mine in unless it is less than 15-20 degrees, or i know its going to sit for a few days or so just to keep things warm the while time.. Ive got 400 miles on brand new injectors and pump, and when its about 20 in the a.m it will be a hair shaking for a second or two, and just a fuzz of smoke for a sec, but thats a diesel for ya especially an lb7.. I should edit that, its hit or miss on me plugging it in, i do forget half the time. Lol
| Junior Member Join Date: Aug 2012 Location: Denver CO
| two weeks ago I was in Steamboat for the weekend at my in-laws house. They had a party the night before so we had to park our trucks away from the house so guest could get closer. Well temps dropped to -25 overnight and the truck wasn't plugged in. She started and probably wasn't happy haha but fired right up.
__________________ 2005 LLY CCLB Kenwood DNX 6180 indash nav/bluetooth/DVD JL amp and custom box with two JL 10's behind the seat. LBZ mouthpiece- 4 in. MBRP straight *coming soon EFI Live, zone 6 inch lift, 20's with 35's* http://i16.photobucket.com/albums/b9/nvrider/gYBF5.gif |
| Senior Member Join Date: Oct 2009 Location: Colorado
| As long as your system is ok (batteries, glow plugs, CP3, fuel additive etc etc, I have yet to see a Duramax not start due to the cold. I plug mine in most if the time but I've had it sit for 12+ hours in negative temps and it was always fine. I still use 1540 oil so it cranks a little slower and sounds like a diesel for a bit but levels off nicely. Sent from my iPhone using AutoGuide.com Free App
__________________ 04 lb7 285/75/16 BF Goodrich A/T, 4" Exhaust and 5" Tip Fumoto Valve PPE High Idle/Valet Switch Bilstein shocks Pro Comp Leveling kit Air Ride 5000 bags Nictane Cat Adapter 1R-0750 Filter DSP2 By Nick, www.duramaxtuner.com |
| Senior Member Join Date: Jan 2011 Location: Red Deer, Alberta
| I had to start mine in -30 C once without plugging it in. It didn't like it but it started anyways, I didn't let it warm up much and the transmission was acting funny like it was in 3rd gear to start but was fine after restarting. I usually don't plug it in unless it's gonna be colder than -15. SENT FROM MY S3
__________________ '09 GMC 2500HD SLT 285/70-17 Cooper Zeon LTZ Bilstein 5100's Amsoil Bypass Filter |
