| Banned Join Date: Nov 2008 Location: Arizona
| Homebuilt S475 What do you need to make your own kit and save $500+?? Heres what you need for a LB7.. Intake:... bought from Dmax711 on DuramaxDiesels, built me one complete with clamps, it's 5". Filter:... Source automotive S&B for 2nd gen dodge 24valve stock/75mm twins, fits perfect. Turbo: Forced Inductions in Alabama Coolant block off plug for stock turbo; Tony @ All Season Diesel Performance ATS A5k 4" downpipe and hot side intercooler tubes with boots, clamps and O-ring Driver side dipstick from Merchant-Automotive RDL t4 pedestal, 7" tall BD Diesel stud and bolt kit(bolts turbo to pedestal, also t4 gasket. Merchant automotive; Turbo feed/drain kit. Think that's it... Still waiting on my S475, but this is the same stuff that I bought instead of paying 3200$+ for a ready to run kit. ![]() ![]() here's some pics so far... ![]() ![]() ![]() ![]() ![]() ![]() ![]() How she sits waiting... Last edited by Hondarider552; 02-02-2013 at 10:09 PM. |
| Meyer Performance ![]() Join Date: Oct 2008 Location: groveport, ohio
| Sooooo, did you sell the ccsb?
__________________ Joe 2008 CCLB LT2 DURAMAX LMM was once stock ![]() |
| Also, whats the suspension setup you ask? How did he do that? 3" DJM shackles, running 2 leafs in rear on each side, 7* shim to bring the pinion angle back so the driveline is happy. Front is stock torsion keys all the way down, I plan on buying drop keys and lowering the front 1-1.5" to level the truck. Caltracs traction bars for the rear. Stay tuned! Rancho "lowered truck shocks" adjustable in all 4 corners. Crank It Up Diesel centerlink, and tie rod sleeves. Yes Joe, I sold the GMC 2 months ago to a firefighter guy in Illinois. I miss the truck Last edited by Hondarider552; 02-02-2013 at 10:19 PM. |
| DuramaxForum Veteran Join Date: Sep 2012 Location: South Whitley, IN
| Should be pretty sweet once it's all in
__________________ The Sound Of Madness 2004.5 LLY ECSB EFI Live, MA700 Trans, Airdog 2 165, MBRP 5" with 6” tip, Profab Downpipe, LML Manifold, LBZ Mouthpiece, AFE Stage 1 Intake, EGR Blocked, PCV Rerouted, Resonator Plugged, ADP Race Valve, MA Rear Housing Support, MA Pump Rub Fix, Rancho RS9000xl's, Amsoil Synthetics, Autometer Cobalt’s Boost & Pyro, Tint (5% back, 20% front), HID's, US Speedo Custom LED Gauge Cluster, Line-X’d rockers To Come!! :Profab EGR Delete 4094vvt 40% overs |
| Im Superrrrr! Join Date: Apr 2007 Location: Central Illinois
| where is the turbo just you ask??
__________________ Goes by John --2001 ECSB SDP Big Single, Wehrli Dual Fuelers, 50% sticks, Front Coilover Conversion, Anorexic .....much much more Sponsored by Creatures of the Night Performance and SDP --2005 CCLB Dually The tow pig Tuned and Edge Insight CTS ![]() ![]() |
| I-6 killer Join Date: Sep 2009 Location: Wilmington, NC
| Thats gonna be sick man!!
__________________ 05 LLY BLACK Air/Fuel/Stance Thanks to: Caleb @ Blackout Performance Kory @ PPEI |
| the SLEDGEHAMMER Join Date: Sep 2011 Location: upstate nj
| well look whos back from the hammer...
__________________ 04.5 2500hd |
| Senior Member Join Date: Aug 2011 Location: Jersey
| Subscribed
__________________ 2006 Chevy Silverado ..LBZ..mbrp 5" turbo exhaust (no muffler or cats) modified stock air intake, EFI by Kory Willis, Big Dipper stage IV trans, Precision ML, Pump rub fix, Alligator trans lines, Autometer guages, Airdog II-165, Ready Lift leveling kit, 285/75 Nitto Dune Grappler, Bilstein shocks, Cognito idler and pitman arm braces, PPE tie rod sleeves, fingerstick, blocker plate, pvc reroute,air intake regulator blocked, Banks boost tube, All Amsoil fluids |
| Junior Member Join Date: Aug 2010 Location: Peoria, AZ
| Like all your trucks brian this one looks sweet bro
__________________ LB7 under construction ![]() |
| Yep, just call and talk to them they can build whatever you want. Their guy knew exactly what I wanted. Thanks Dave! I hope its ready before the March AZ races, it will be close. Thanks boss! |
