poor cab heat - Chevy and GMC Duramax Diesel Forum
post #1 of 9 (permalink) Old 02-06-2009, 08:27 AM Thread Starter
poor cab heat
My duramax doesn't seem to heat that well even with a cold winter front installed. It looks like everyone I see must be having the same issue as they all have winter fronts. Is there a magic bullet to solve this?
shade tree mechanic is offline
post #2 of 9 (permalink) Old 02-06-2009, 08:31 AM
Buck's Avatar
floor it! i know it sounds childish but sometimes you got to make it want to make heat. whats your temp gauage say? it was 8* here this am and after a 15min warm up my gauge barely moved off the stop, once you put a lil heat in her shes fine, untill you park it to get b-fast then its cold again. the cooling system is so massaive that all it takes is a few min at idle to bring the temp back down then the t-stat closes and there is not as much hot water going through the heater core.
Vehicle 2008 Black Chevy Crew Cab Short Bed Z71
Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims
Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck
Drivetrain LMM Duramax, Allsion 1000 Transmssion
Performance Mods EFI Live and DSP 5 By MMLMM, RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC
Other Mods B&W Turn Over Ball, Air Lift Bags, Titan 52gal fuel tank, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
Buck is offline
post #3 of 9 (permalink) Old 02-06-2009, 08:32 AM
welcome to the DF..fill out your signature of what year truck you have and any modifications you have done
How cold is it where you live?
2004 GMC Sierra LB7 CCSB
--sold...lookin for another
dirtymax04 is offline
post #4 of 9 (permalink) Old 02-06-2009, 08:45 AM Thread Starter
I'm in Wisconsin. Not uncommon to be zero or below, but that really isn't the issue. I have an edge monitor in the cab and the engine is running about 190, so it should be heating better. I have had 4 powerstrokes and never had an issue even without a winter front. I kind of had just wrote it off to the aluminum block and the issues it can create, but have heard from others in this area with the same complaints and thought there should be an answer.
post #5 of 9 (permalink) Old 02-06-2009, 08:49 AM
timespentsearching's Avatar
if its an LB7 you got to ge a high idle kit. the Dmax is the wort heat building machine at idle out there. cold in winter. high indle my pick will sit aroung 185 temp at idle, with out it it baily made it above 160
03 EC/LB LB7: EFI LIVE, S&B intake, 5" DE, ATS manifolds and up pipes, Stock turbo (for 1 more weeks), airdog 150, pieced together trans, sleeve (trac bars and centerlink soon), 8" rear air bags-overload springs+2" blocks, bilstein 5100 shocks, leveled, nitto 285/75/17's and BFG KM2 255/85/16's for winter.
timespentsearching is offline
post #6 of 9 (permalink) Old 02-06-2009, 08:51 AM
jon5212's Avatar
If you are at 190 you should have no problem with lots of heat. Sounds like your heater core is plugged up. I'd get the cooling system flushed out real good.
2001 Chevy 2500 4x4 ECSB, 6 speed with Southbend Clutch, 4" MBRP straight pipe exhaust. EFI Live tuned thanks Brayden and Jarrod!!! Dyno numbers 6-6-09 Fass Diesel Nationals 441 RWHP/900+ RWTQ Yeah baby!
jon5212 is offline
post #7 of 9 (permalink) Old 02-06-2009, 01:33 PM
Buck's Avatar
ya if your at 190 its the heater core.
Buck is offline
post #8 of 9 (permalink) Old 02-06-2009, 01:40 PM
Durallymax's Avatar
duramaxes are not aluminum blocks they are cast. The heads are aluminum.
If your temps are ay 190* you should get it checked out, at that temp with the heater cranked youll see me driving around with my windows down like a flaming idiot. Usually on my way to school in madison, its chilly at first but by the time i get there im sweating.
Durallymax is offline
post #9 of 9 (permalink) Old 02-06-2009, 02:09 PM
DuramaxSMOKE11's Avatar
Send a message via AIM to DuramaxSMOKE11
plugged heater core
Mike
2005 Chevy 2500HD Duramax LLY
BANKS ram air intake, MBRP 4" exhaust, CAT DELETE and NO MUFFLER, EGR Deleted, Fisher SS ExtremeV plow, Auto Meter Gauges, Boost, Pyro, Fuel Pressure, turbo resenator blocked off, PCV Reroute. SoCal Stage 1 heads, ARP Studs, BD Manifold, diamond eye down pipe, AFE mouth piece, AFE intercooler pipes, KMC Rokstars 20" wheels with Nitto Terra Grappler AT
EFI LIVE TUNED BY NICK
Big thanks to chad at Alligator performancewww.alligatorperformance.com
DuramaxSMOKE11 is offline
