| Premium Membership | |
If you would like to help support Duramax Forum, get some sweet stickers for your truck and more priveleges on Duramax Forum.com, click here | | | General Discussion General Diesel Discussion. |  |
08-26-2005, 12:10 PM
eBay Motors
#1 (permalink)
| | Junior Member
| bad U joint=cracked trans I've got a '03 3500 4x4 duramax/allison with 74k miles, the first u-joint behind the transfer case went bad & cracked the trans. Has anyone ever heard of such a thing???? When I took it to the dealer the tech said when that joint freezes it sets up a vibration that breaks the trans. They gave me an estimate of $8,000.00 to replace it. Chevy does not want to assist in the repairs (even though I think it's a design flaw) they said it's my fault, caused from the bad u-joint. Believe me it didn't take many miles once it was noticable. |
| Advertisement
08-26-2005, 05:49 PM
eBay Motors
#2 (permalink)
| | Member
| that is defiently the first ive heard about that happen...
__________________ 2005 Chevy 3500 4x4 (dually), LLY, LT, CC
Previous Vehicles:
2003 MCS Indi-Blue, 6SPD Manual, sport, performance packages (I really Miss this vehicle)
1994 Chevy Silverado Reg Cab 3500 Black on silver 6.5TD 5spd Manual (don't really miss this) |
02-01-2008, 08:27 PM
eBay Motors
#3 (permalink)
| | Junior Member
| its quite comon the most likely part that broke is the reverse housing witch is about 400.00 bucks plus labor ive replaced probraly 10-15 of them try a new shop |
02-01-2008, 08:36 PM
eBay Motors
#4 (permalink)
| | Gear Jammer...
| Yeah usually just the rear/tail housing on the trans cracks, you should be able to jusy have that replaced. Suncoast makes a transfer case brace that is supposed to eliminate the chance of this happening! Suncoast Transfer Case Brace
__________________ 05 Chevy 2500HD dark blue reg cab ZF-6 speed/W South Bend Clutch ,Power by EFI Live W/Dsp2 , PPE GT4094R, ATS CP3x2, Modified Volant intake, MBRP front pipe, 4" side pipe, Holley Blue lift pump, Isspro gauges,Cognito Braces, SD Centerlink, Caltracs, ATS Tie Rod Sleeves Best ET 12.53@ 109 mph 04.5 Chevy 2500HD, silverbirch, D/A, CC/SB , EFI live, SCIV w/ATS 5Star converter,McRat shim mod, Wicked Diesels modded FPR, Kennedy dual lift pump, Modified Volant intake, Cognito Braces,CUD tie rod Sleeves, EGR BLocker,Diamond eye Down pipe, 4" dual exhaust, Elocker, MA Tcase Fix, B&W GN Hitch Best ET 13.53 @ 101mph |
02-01-2008, 09:44 PM
eBay Motors
#5 (permalink)
| | Super Man Moderator
| I have heard of that happeneing but thats rare. Have you had your services done at the dealer ship? If so they should of been able to see it so they could be held partially liable. If not id stillsay get ahold of a GM rep. With only 75k on your truck the ujoint shouldnt go that bad. IMO GM should help you out in some way.
__________________ Jason 2006 Silverado Shortbed Crew Cab LBZ Escalade handles, Line-x, Painted bumpers and towing mirrors, Tinted Front Windows & Tail lights 2 MTX 10in Subs & Punch 250amp in a custom box. Autometer Ultralite II Pyro & EGT gauges with pillar pod MBRP Turbo Back stainless exhaust (Straight piped), AFE Stage II Intake, PPE Hot+2 265/75/16 Nitto Terra Grapplers on Gear Alloy wheels Lost Kitty Reward if found!! 1999 Ford F-550 Powerstroke Tow Truck-Wrecker **Jerr-Dan Bed, S&B Intake |
| Advertisement
