Chevy and GMC Duramax Diesel Forum (http://www.duramaxforum.com/forum/)
-   General Discussion (http://www.duramaxforum.com/forum/general-discussion/)
-   -   03 or 05?? (http://www.duramaxforum.com/forum/general-discussion/203194-03-05-a.html)
AlaskanBullWorm 07-17-2013 10:17 PM
03 or 05??
2 Attachment(s)
looking to get a duramax, would like some opinions
2003 Chevy 2500hd= Ext cab 4x4 sb, 213,000 miles but transmission has been rebuilt with heavier duty parts as well as a triple disc converter, njectors have been gone through as well 4 were replaced and the rest have been tested to make sure they are all within specs. Truck does come with Efi live from Anderson performance tuning, S and B intake as well as full 4 inch exhaust, S and B intake as well as full 4 inch exhaust, leather. guy want $12500
2005 Chevy 2500hd= crew cab short bed 4x4 fully loaded leather heated power seats. newer tires and rims, 220k miles put 4 new injectors in it last month all new steering components and front hubs. guy wants $13500
lifteddirty 07-17-2013 10:27 PM
they are so close to even its not even worth a debate, i would brive both of them and figure out which one you like the best. they both have their pros and cons.
DaJokr 07-18-2013 12:19 AM
Lb7, injectors. Still needs 4 done. Lly, head gaskets and cooling system. Are you planning on hauling at all?
Personally I'd go for the 05 as I prefer a cc to an ec. That, and I don't like the idea of changing injectors on the lb7's. IF it ever needed them done again.
Take your time making a decision I say. Good luck :thumb
LOLinjectors 07-18-2013 12:22 AM
03 for the build trans :)
AlaskanBullWorm 07-18-2013 07:32 AM
not planning on hauling much. the most I'd pull is a little utility trailer with a zero turn mower. would hauling heavy loads factor into the 05's problems?
AlaskanBullWorm 07-18-2013 07:34 AM
are both prices reasonable or should i try to bring them down a lot?
whitemax&al 07-18-2013 07:43 AM
id go newer and its a crew cab plus i like that hood and front end on the newer trucks
DURAMAXD219 07-18-2013 08:04 AM
I like the LB7
And I would offer 11
HD Dmax Machine 07-18-2013 08:15 AM
Id go with the LB7. & like said above offer $11K.
leadfoot33 07-18-2013 08:24 AM
i would LLY (05) i prefer crew cabs and i as well dont like the idea of changing injectors on Lb7.
but the 03 is on its way to being a well modded truck
Powered by vBulletin® Copyright ©2000 - 2017, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
