| DuramaxForum n00b Join Date: Dec 2008
| Oil Capacity Can someone tell me the oil capacity on a 01 6.6L d-max. All stock, no mods? Thanks in advance... Fishon |
| Longbeds FTW Join Date: Oct 2008 Location: Natrona Heights, PA
| 10 quarts.....
__________________ 06 Dmax/Allison EC/LB 4x4 TTS PowerLoader III full billet Bully Dog stage 7 BCI 7" intake with custom snorkle fender vents quintuplet shotgun cat stacks 22" Rockstars Huge "Dirtymax" sticker -60% nozzles extra pcv with dual catch cans compounded EGR silencer ring MIA 4.56 gears Lowered 5.5" in the back Lifted 6" in the front Monster sticker flat bill mod 8' CB whip blacked out reverse lights gauges everywhere 08 BMW 528xi 00 Buick Regal GS |
| Thanks, Chris You the MAN:rockin |
| ASE Certified PartsWhore ![]() Join Date: Feb 2007 Location: Gretna, Nebraska
| 2.5 Gallons
__________________ Husker Diesel, INC. | 402-502-6961 HDP on Facebook | HDP on YouTube | www.huskerdiesel.com | Email us! Don't sacrifice the best customer service and expertise to get the best price. We will gladly match any competitor's deal! ![]() |
| Duramax Forum Supporter | 9.463529 liters
__________________ sent from my android phone that wishes it was an ifone while eating a big mac and drinking a Slurpee while driving with my knee Bryan 03 GMC 2500HD LB7 4x4 CCSB | 285/75/16 Hankook DynaPro on PYO | 4" MBRP Cool Duals | PPE High Idle Switch | Efi Live | Recon Line of Fire and Ice | Recon Smoked LED 3rd Brake light | Brite Box Headlight mod High/Low and Fog Light | HID 6k H/L Fogs | PPE BIV | AD165 |ADP CAT Adapter (RED) Toys-99 Civic Si-Turbo 654hp 453 tq. 11.19@132 mph 1.797 60', 1995 Buell S2, 2009 Buell XB12R Firebolt |
| Disc Diesel Performance ![]() Join Date: Oct 2008 Location: So Calif.
| Yep 10 qts like said above. Let me know if I can help you with Amsoil at wholesale pricing. Dane
__________________ ![]() 2013 Chevy CCLB 4X4 Victory Red email us Amsoil Distributor #1466322 Specialist in Longevity, MPG and Easy Maintenance Factory Authorized Nicktane Dealer Filters 4 your Dmax cheaper than most other Vendors Fumoto Valves, FilterMags, Fuel Filter Access Doors CAI, Exhaust, EFI Live by Kory Willis Your Satisfaction is Our Satisfaction! |
| Here is a little sheet I put together for the Dmax fluids and filters. Dmax Capacities and other info. Your Duramax will take 10 qts (2.5 gal) of oil in the engine with the filter change. With dual bypass it will take 11.5 qts. Recommended oil for pre DPF trucks is 15W-40. The Newer 2007.5 and up trucks that have a DPF need the CJ-4 rated oil which is 5W-40 The Allison transmission will take 7.4 qts (2 gal) for a pan drain with the spin on filter change. Get 5 gal if you are doing a flush to get the oil into the torque converter. For the Allison you want the Torque Drive ATF if you are going to use the Amsoil. The rear diff will take 4 qts of 75W-90 gear oil with the stock cover. If its an aftermarket such as the Mag-Hytec it will take 7.5 qts. If you are doing a lot of towing or hauling heavy loads I recommend you use 75W-110 in the rear diff. The Amsoil Product for this is Severe Gear oil. If you have 4wd: The Front diff will take 2 qts 75W-90 The transfer case will take 2 qts of either ATF or 5W-30 synthetic motor oil depending on which way you want to go. If you use the over fill method through the speed sensor it will take 3 qts. There is nothing really special except with the Trans spin on filter. There is a magnet on the top of the filter that will need to be cleaned real well and put back on top of the new filter before installing it. Also there is a magnetic drain plug in the front diff that needs to be cleaned it will have shavings on it. On the fuel filter make sure you dont cross thread the plastic WIF sensor. Its easiest to take out the inner fender well on the pass side to get at the fuel filter its 8 plastic clips.
| Senior Member Join Date: Jan 2009 Location: Anchorage, AK
| 9 463.52946 CCs, 640 US tablespoons, 2.0816846 Imperial gallons 20 pints 0.0806451613 US beer barrels 0.0946 hectoliters 0.33 cubic feet 0.0124 cubic yards that should pretty well cover it. Hope your oil change goes well!
__________________ Devin 2006 Silverado 2500 HD CCSB LT3 LBZ, Black/Black PPE Programmer (set to level 3), nothin' more but hopes and dreams. More go fast parts on the way! |
| Junior Member Join Date: Jan 2009 Location: south jersey
| i just put in 11 qts 10 plus 1 for the filter
__________________ 2003 d/a lb7 4x4, cc, dually white tornado, kennedy air box mod, stock exhuast with magnoflow muffler, daytime running lights turned to foglights ------------------------------------------------- 22000lb 5th-wheel hitch, tecomsah p3 brake controller, air-lift air bags ------------------------------------------------- trailer- 43ft sunnybrooke toy-hauler rv triple-axle, (hauling alpacas) ------------------------------------------------- 2004 d/a lb7 4x4 cclb silver birch tornado, kennedy air box mod,bed cap |
| 10 Usually gets me up to the hash with the filter.
