P0621 Generator L-Terminal Circuit - Chevy and GMC Duramax Diesel Forum
post #1 of 3 (permalink) Old 04-21-2009, 10:32 PM Thread Starter
Tyler_LS1's Avatar
Lightbulb P0621 Generator L-Terminal Circuit
What does this mean?
it was brought up on a scan on a 06 LBZ
Thanks
USAF
2006 Silverado LBZ CCSB Stock and ready for some goodies
2006 Silverado LBZ ECSB - BatMo s475 - DA built trans - Exergy 60 overs - EFI/DSP5 and supporting mods (SOLD)
Thanks to Dustin at Diesel Addiction.
Old owner ran 12.4 @106 with just a built trans and tuning. No new times with current set up
1999 Camaro SS LS1 6-speed - bolt-ons
12.6 at 111 N/A stock motor (SOLD)
Tyler_LS1 is offline
post #2 of 3 (permalink) Old 04-21-2009, 10:42 PM
Send a message via AIM to dieseltekbham
Do these steps
Ignition OFF, disconnect the harness connector at the generator.
Ignition ON, test for less than 1 volt between the generator turn ON signal circuit terminal B and ground.
⇒ If greater than the specified range, test the circuit for a short to voltage. If the circuit tests normal, replace the ECM/PCM.
Engine running, test for greater than 3.5 volts between the generator turn ON signal circuit terminal B and ground.
⇒ If less than the specified range, test the circuit for a short to ground, an open or a high resistance. If the circuit tests normal, replace the ECM/PCM.
If the circuit test normal, replace the generator.
dieseltekbham is offline
post #3 of 3 (permalink) Old 04-21-2009, 10:45 PM Thread Starter
Tyler_LS1's Avatar
wow, thanks.
sounds complicating, i dont have the truck with me to test it. i did a prepurchase inspection and it came up. so is it a big deal?
USAF
