Old 09-04-2007, 07:55 AM   eBay Motors   #1 (permalink)
js818
2004 duramax won't
This thing just died in the driveway. Changed filter, primed, pumped, pumped, pumped. Got it to run a few times as long as 5 minutes, I kept it running by pumping. Fuel looks ok. Has anyone had a similar problem with the Duramax?
js818 is offline   Reply With Quote
Old 09-04-2007, 02:45 PM   eBay Motors   #2 (permalink)
05_LLY
Gear Jammer...
05_LLY's Avatar
Is it a lb7 or a lly? Check the 8th digit of your vin to tell, 1 for lb7 and 2 for lly. Hows the oil look, smell? Can you smell fuel in the oil?
Caleb
05 D/ZF Reg. Cab
Under the knife to attach a second turbo
04.5 D/A CC/SB- SCIV w ATS 5star converter,Mike L cooler
Waiting install of GT4094R
Old 09-04-2007, 06:56 PM   eBay Motors   #3 (permalink)
js818
It is a LB7, and I think the oil is fine. The dealer said something about the oil and possible injector leaks. Now I can't seem to get it started. If I follow some of the diagnostics it seems to take me to a possible pump problem.
Old 09-04-2007, 07:10 PM   eBay Motors   #4 (permalink)
05_LLY
Gear Jammer...
05_LLY's Avatar
My guess would be injectors, could be a pump problem but most all cases it is the injectors!
Caleb
05 D/ZF Reg. Cab
Old 09-04-2007, 08:35 PM   eBay Motors   #5 (permalink)
PETERBILT TECH
PETERBILT TECH's Avatar
is your truck smoking when idling if it is what color is it..
Iceman
PETERBILT TECH is offline   Reply With Quote
Old 09-05-2007, 02:00 PM   eBay Motors   #6 (permalink)
gm tech
pump primer until hard to push then check for fuel leak around filter gasket and bleeder screw
gm tech is offline   Reply With Quote
Old 09-05-2007, 08:12 PM   eBay Motors   #7 (permalink)
PETERBILT TECH
just serviced saturday,i have cleaned thefuel tank ,tried 3 different type of fuel filters,had my entire fuel system checked fuel rates,flow.the tuck starts fine when cold it only does it if its hot from driving..i work for peterbilt and my truck is maintained very well.i have exhausted all of my guesses.. i also use additives in every tank and my mileage is great.
Iceman
Old 09-05-2007, 08:55 PM   eBay Motors   #8 (permalink)
05_LLY
Gear Jammer...
05_LLY's Avatar
Im still saying injectors, What fuel rates were checked, you should have the return rates checked, the problem comes from the injectors returning to much fuel to the tank!
Caleb
05 D/ZF Reg. Cab
Old 09-05-2007, 08:59 PM   eBay Motors   #9 (permalink)
PETERBILT TECH
i dont know how this happened but im not the one with the 2004 that wont start in the driveway,but mine is hard to start.
Iceman
Old 09-06-2007, 03:53 AM   eBay Motors   #10 (permalink)
05_LLY
Gear Jammer...
05_LLY's Avatar
I thought you were saying yours was hard to start when it is warm, that is a typical condition for injectors going south.
Caleb
05 D/ZF Reg. Cab
« roar | pictures »
