I have always been told to change my oil EVERY 3000 miles. I have driven about 3000 miles but the oil change index in the truck still says 60%. I figure if I waited until the computer said 0% I would have driven about 8000 miles. What I need to know is if you wait until the computer says to change the oil are you going to get the same longevity out of this motor?
__________________ Jason
Wenatchee WA
2004 White LLY/Crew Cab 4x4 LS
Leveled w/285's/Debadged
6K HID Headlights and Fogs
Banks Cold Air Intake/LBZ Turbo MP
Silverline 4" Turbo Back SS w/5" tip
Lots more to come!!!
you have to remember on a diesel you have at least twice the oil in there than on a gas engine and the oil usually doesnt get contaminated like on a gas engine either. Normally on conventional oils you change it at 7500 miles. If you do an oil analysis you can go further, but if you are on conventional oil, the cost isnt that much to change it.
I change mine every 10K. I use Amsoil with the Amsoil Duel by-pass filtering system. The oil stays cleaner longer, and the by-pass filter takes out the soot. With two filters, that also gives me two more quarts of oil in the system.
I could most likely go longer with an oil analysis, but like I said, cheap insurance!
__________________ '05 Crew Cab Long Bed 65,000 miles, 7" Lift, 35x12.5X17 Toyo A/T, 4.56 Gears. (All BANKS POWER!) Intercooler, Intake, 4" Turbo-Back Exh, Economind, PDA, & SpeedBrake. EGR Block Plate, BD Trans & Torq. Converter, modified MP. Running Amsoil in everything, with Remote by-pass Oil System. Mag-Hytec Trans. & Diff. 20 MPG MT/ 12 Towing toy hauler.
You could definitely go longer even without the analysis with a bypass system. AMSOIL Warrants their CJ-4 Rated 5w-4- & 15W-40 for up to 3X OEM specs or up to 60K miles without oil analysis. I know this sounds to good to be true, but again, it is "Warranted" against failure.
Now, like stated above, if you are going to use conventional then yes, you want to change at least every 7500 because they suffer from viscosity and thermal break down more than Full Synthetics.
Yes I could go longer than 10K. Since I use my truck for towing 95% of the time, and it usually takes me @ 1 year to reach 10K, It ends up being 1 oil change a year.
Besides, oil is cheap insurance!
On highly modified engines with larger turbos, injectors, AND tuning, it is a good idea to change more often. I have seen trucks with problems from fuel contamination more than anything, but anytime you increase the power and torque to the point that you are adding power to the tune of 500+ hp then the true extended drain intervals go out the window...
