Old 07-15-2009, 02:30 PM   eBay Motors   #1 (permalink)
A/C Re-Charge
The Compressor on my truck is kicking off and on and I i want to recharge the system/find the leak. What should i load the Low side to (PSI) with the compressor engaged? I must have searched 15 different ways and couldn't find any thing documenting this. I also checked my alldataDIY account and couldn't find any solid number to be at.
Thanks in advance guys.
03 Silverado 2500HD CC (6.6L), Cold Air intake, 5 inch Strait Pipe (Turbo Back), Banks Six Shooter + Speed Loader, 6' RCD Lift, 35' Tires and a Camper Top that makes my truck look like an SUV.
Bonz099 is offline   Reply With Quote
Old 07-15-2009, 02:33 PM   eBay Motors   #2 (permalink)
My Truck is a Ginger!!!
seth999's Avatar
try buying some refridgerant with stopleak in it...the kits at most auto parts chains have gauges showing where it needs to be
2" x 3" Pic Diesel World Mag. March 2010 Pg.120
08" CHEVY 2500HD CCSB LTZ
Custom Burnt Orange Paint
37" toyo's on Diamo 20's
9" Fabtech Lift--HDTie Rods
AMP Steps
Transgo jr.
5" MBRP Turbo Back--MBRP Downpipe
EFIlive by IdahoRob--DSP 5
Banks Intake
PPE Lift Pump--Rail Shim--Ported Rail Fitting
TAX MONEY=Turbo--tranny will make it
seth999 is offline   Reply With Quote
Old 07-15-2009, 02:35 PM   eBay Motors   #3 (permalink)
Ironman070809's Avatar
its hard to tell cause the pressures cycle its eaiser just to evacuate the system and put the right amount it.....
but here is a little explination
•Normal readings on high and low side with AC OFF (static pressure) - Depends on outside temperature, but normally is between 80-105 PSI
•Normal low side reading with AC on high speed and MAX & engine at 800-1000 RPM’s - Ranges from 25-35 PSI - Note that on many Chrysler products a normal reading on the low side may be 15-25 PSI
•Normal high side reading ranges from 200-350 PSI
Here is a link Adding Freon to Car AC - Gauge Readings Explained |
05 Duramax LLY
Bullydog Tripledog(Crazy Larry)
w/ outlook monitor
Ironman070809 is offline   Reply With Quote
Old 07-15-2009, 02:41 PM   eBay Motors   #4 (permalink)
Freakin thanks, this is exactly what i needed!!!
Now im a bit worried cause i think last time i checked the comp running pressure was at 50psi. Ill check static and see if im lowish.
Old 07-15-2009, 02:51 PM   eBay Motors   #5 (permalink)
low pressure just means its undercharged but do you have a hi low gauge set?
05 Duramax LLY
w/ outlook monitor
Old 07-16-2009, 08:45 AM   eBay Motors   #6 (permalink)
Just low, but purged the system last night cause it was WAY over charged, and it blows colder than a witches tit in there.
Thanks again for the solid numbers for static and running.
Old 07-16-2009, 09:07 AM   eBay Motors   #7 (permalink)
No problem a/c systems suck
05 Duramax LLY
w/ outlook monitor
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154
