I recently just bought these for my 03 dmax and I can't put them on myself so i took my truck to les schwab to have them installed and they said that they wouldn't work on my truck. do they just not know what they're doing or has anyone else had this problem?
__________________ 2003 Chevrolet CC/SB LB7 Homemade 5 inch "shorty" stack, Kennedy boost valve, Autometer Phantom II Boost and Pyro gauges, 35's on all black Ultra Goliaths, front end leveled, 2% tint, SD tierod sleeves, 2 Kicker CVT 10's w/ Sony amp, 10,000k HID headlights, blacked out taillights and brake light, spray on bedliner on front end
I would guess they didn't know what they are. I don't have them on my truck but thought they would be pretty straight forward on the install. Try asking a different garage/shop about them maybe they can help you.
__________________ 05 QC/SB, cummins/6spd, SBC DD, Gauges, SMARTY TNT/R stacked with Stg. 2 Dr. P, ARP Studs, 90horse injectors, Ats Manifold, 66mm Silver Bullet, Enterprise Cam, CIA, 5" exhaust into 6" stacks, II Dual CP3s, and Hamilton 110s.
Remove tire. Back locknut off a bit and use a hacksaw blade to lightly score the tierod. unscrew tierod nut at the spindle and tap tierod out. Unscrew the tierod end and lock nut(you can count turns, but not needed with the mark you made). Screw the sleeve on and then nut and tierod end. turn the nut past your mark and screw the tierod end right to the mark and reinstall the end into spindle. Tighten up both nuts. Do the other side.
Go try out some high boosted launches. Come back and have a beer while you try and find all the stuff that flew into your back seat from the various cubby holes.
__________________ 2007 LBZ Daily driver, single stock cp3, stock engine 11.70 @ 115mph on #2, 677 HP
2002 LB7 Fun truck 9.801 @ 139+MPH on #2 fuel only
haha okay thanks man. also they said if i put them on it will chew up my tires, probably just more BS huh?
Yes, more BS. All this product does is go over the factory tie rods as you know. Doesn't change anything except make the tierods stronger.
alright thanks man i thought so just needed some good feedback
