Grease Fittings - Chevy and GMC Duramax Diesel Forum
post #1 of 34 (permalink) Old 09-26-2009, 05:38 PM Thread Starter
Grease Fittings
Hi guys,
I know there have been a few posts on this subject but I'm still stumped and can't find my last couple grease points.
Here is what I have found and greased thus far:
Upper and lower ball joints (4)
Inner and outer tie rods (4)
Center Link (2)
I've greased the 2 joints that connect the idler arm and pitman arm to the center link. These point straight up. I counted these as my Center Link fittings above.
I don't know if there are more fittings on the Pitman and Idler arm? Also, is the Drag Link the same as the Center Link?
I believe I'm missing at least one fitting but can't seem to find it anywhere.
Thanks!
2012 3500 DRW
Duramaximos is offline
post #2 of 34 (permalink) Old 09-26-2009, 05:43 PM
mijdirtyjeep's Avatar
These are the ones you have on the front of your truck. There are 11!
2 - Upper ball joints
2 - Lower ball joints
2 - Outer tie rod ends
2 - Inner tie rod ends
2 - Idler arm (one on top and one on the ball joint)
1 - Pittman arm
Jim
mijdirtyjeep is offline
post #3 of 34 (permalink) Old 09-26-2009, 05:44 PM
try googling "duramax grease fittings" the pics were gone on the links I found but this is the list they all repeat, 11 total:
2- outer tie rod ends
2- inner tie rod ends
2- upper ball joints
2- lower ball joints
2- idler arm
1- pitman arm
2017 Denali HD CC/SB
2012 Denali HD CC/SB - gone to new home
2005 CC/SB Duramax/Allison - gone to new home
anfo is offline
post #4 of 34 (permalink) Old 09-26-2009, 05:45 PM
jinx'ed hahahah
anfo is offline
post #5 of 34 (permalink) Old 09-26-2009, 06:21 PM Thread Starter
Thanks guys! That narrows things down a lot.
I'll focus on the idler arm tomorrow morning.
2012 3500 DRW
post #6 of 34 (permalink) Old 11-09-2009, 04:14 PM
Dura2thaMax's Avatar
Whats the recommended grease for these fittings?
07 Sierra 2500HD CC SB Classic. Loaded
LBZ
4" Rancho Susp. Lift
K&N Intake-Edge Evo Race CS-Diamond Eye Downpipe
20" Helo Maxx 8's 305/55/R20 Mickey Thompson ATZ's
Dura2thaMax is offline
post #7 of 34 (permalink) Old 11-09-2009, 04:57 PM
JuniorDiesel's Avatar
Send a message via Skype™ to JuniorDiesel
When greasing these fittings, do you just pump grease until it starts to come out?
2007.5 Silverado 2500HD LMM
MBRP 4" Turbo back exhaust, EFILive, H.I.Ds, Billstien 5100's, 18" XD Monsters, Nitto Trail Grabbers, Cognito UCA.
AMSOIL
www.syntheticmotorsports.org
JuniorDiesel is offline
post #8 of 34 (permalink) Old 11-09-2009, 05:23 PM
go-dwr's Avatar
Curious myself
2009 Silverado 2500HD LTZ EX-Cab 4WD EFI Live Idaho Rob, Turbo back 4" exhaust, EGR turned off, PCV reroute kit, CTS for gauges Diesel
go-dwr is offline
post #9 of 34 (permalink) Old 11-09-2009, 06:41 PM
WC911EOC's Avatar
I know the upper and lower ball joins have rubber boots that hold grease, just pump until they start to buldge. if you overfill they pop and will squirt grease out the sides. This isn't the end of the world but it will wear them out faster. These rubber boots will also dryrot eventually causing them to leak grease. Salt plays a big factor in this to for those of us in the cold climates. I know there is another fitting or 2 with a boot but I'm drawing a blank as to where it is. If there isn't a boot, just pump until you can see the grease coming out.
I personally use Lucus Red N Tacky, and I grease everytime I change the oil.
Brian, 911 Dispatcher, Volunteer FF/EMT.
2006 LBZ Duramax 2500HD CCSB, Allison 1000
"All on" Highbeam Mod
Banks Ram Air Intake
Some Emergency Lights and a Mobile VHF Radio
www.huskerdiesel.com
http://www.alligatorperformance.com/
WC911EOC is offline
post #10 of 34 (permalink) Old 11-10-2009, 05:45 AM
deegee's Avatar
I just went to the local Menards and bought the grease that was next to the grease gun. I think its a red synthetic grease? I just pumped out grease until the joints were good and lathered.
LB7 - 2003 w/ cranked t-bars, rear airbags, lvl2 Bullydog PowerPup, and running BFG A/T KO 285s. I love my Duramax!
My baby
deegee is offline
