Old 11-02-2009, 03:08 PM   eBay Motors  #1 (permalink)
Vibration while in 4X4
My truck 2005 GMC Duramax has a vibration while in 4X4. Its not a u joint. Gets going at about 60 mph and increases with speed. Any suggestions?
stonewallmp5 is offline   Reply With Quote
Old 11-02-2009, 03:11 PM   eBay Motors  #2 (permalink)
Why are you going 60 in 4wd??
2006 Chevrolet CC/SB LBZ 4x4
MBRP 4" Down Pipe Back w/ 5" Tip...Bye Bye Kitty!!!!
285 BFG All Terrains on Factory 16"
Tinted Front Windows 20%
B&W Turnover Ball
http://www.alligatorperformance.com/
http://www.performancetruckproducts.com/
LBZ_Duramax is offline   Reply With Quote
Old 11-02-2009, 03:13 PM   eBay Motors  #3 (permalink)
Not the point. Ever since I have been driving I've had 4X4 85 chevy 3/4 ton. Never have had this vibration.
Old 11-02-2009, 03:16 PM   eBay Motors  #4 (permalink)
Ridin'GMC's Avatar
Sounds like you cranked up the t-bars too much. Steep cv driveshaft angles will make vibrations at high speeds.
06 LLY CCSB
Just another white truck on the site.
Tuned by Killerbee's Original LBZ tune.
KB's tuning - 480 rwhp & 830 lb-ft of torque as of 11-7-09 on stock engine and stock tranny **still running with a cat on**
killerbeeperformance.com
Ridin'GMC is offline   Reply With Quote
Old 11-02-2009, 03:27 PM   eBay Motors  #5 (permalink)
There turned up a little but not much. The truck still sits up higher in the rear.
Old 11-02-2009, 03:28 PM   eBay Motors  #6 (permalink)
another red name!!!
ob_1jr's Avatar
Have you checked your wheel hubs? Jack the front off the ground and then try to rock the tire at 12 and 6. If there is movement, change the hub.
It could be as stated above..your torsions are cranked too much too.
Racor 2 Micron pre-OEM with heater & water sep.
Old 11-02-2009, 03:31 PM   eBay Motors  #7 (permalink)
Ridin'GMC's Avatar
Do what ob_1jr said. It should be either one of those. If its not the hubs, crank down the t-bars. If it continues, replace the cv driveshaft. How many miles are on your truck and how often do you drive it in 4x4?
06 LLY CCSB
Old 11-02-2009, 03:33 PM   eBay Motors  #8 (permalink)
Torsion bars are not up much at all. Wheel hubs would vibrate even in 2wd.
Old 11-02-2009, 03:37 PM   eBay Motors  #9 (permalink)
another red name!!!
ob_1jr's Avatar
ok dont take our suggestions. I had the same exact thing happen and it didnt vibrate very bad until i put it in 4wd and then it felt like the front end would come apart. it is a simple check...just do it.
Old 11-02-2009, 03:40 PM   eBay Motors  #10 (permalink)
Ridin'GMC's Avatar
Alright, definitely not the t-bars or cv driveshaft. Check the hubs, see if you hear a growling noise while driving. It should sound like a bearing going bad with no grease in it.
06 LLY CCSB
