Old 11-04-2009, 05:23 PM   eBay Motors   #21 (permalink)
GrimReaper
GrimReaper's Avatar
Originally Posted by duramaxchris06 View Post
You would be surprised at how dumb some of the people are that they hire in their service garages.
Sorry to get off track, while this may be true in some areas, there are actually a lot of us GM techs out here that take pride in our work and also work hard to maintain a good reputation.
I dont mean to come off as a jerk....its just frustrating to always hear how stupid us tech's are
2000 Pontiac Trans Am WS6
408ci|th400 w 5500stall | Direct Port N20| 823hp!!
2008 GMC 2500HD LMM
Banks Economind | Banks Intercooler | MBRP Single Black Stack| MBRP DP | Banks Intake | Banks Gauges | EFI Live | Suncoast 1056-3D | Trans Go JR | Allison deep pan | EGR Blocker Plate | AD II 165 | 358 hp and 921 tq...on the MD Dyno @ Scheid!
GrimReaper is offline   Reply With Quote
Old 11-05-2009, 06:16 AM   eBay Motors   #22 (permalink)
cfox68
cfox68's Avatar
Yes your right it would have worked once, then the fault code came back. That disables your remote starter.
This is out of your owners manual. let me know what you find today and I will help more if you need it.
The vehicle cannot be remote started if the key is in the ignition, the hood is not closed, or if there is an emission control system malfunction.
Also, the engine will turn off during a remote vehicle start if the coolant temperature gets too high or if the oil pressure gets low.
Chris
cfox68 is offline   Reply With Quote
Old 11-06-2009, 03:58 PM   eBay Motors   #23 (permalink)
CMONTGOMERY325
Originally Posted by cfox68 View Post
lets start here, these are the two reasons for the code they are
•If DTC P2610 is set, turn the ignition OFF and then completely disconnect the ECM harness connector from the ECM for approximately 1 minute. Reinstall all of the ECM connectors and then clear codes with the scan tool.
⇒ If DTC P2610 resets after code clear, test for an intermittent condition in the Battery Positive Voltage circuit at the underhood fuse block connector X2-D3.
•Replace the ECM.
What I have seen is a loose battery cable connection at the fire wall connection.
the remote start will not work with the check engine light on.
Chris
Ok, so I disconnected the ECM for about 2 minutes. Reconnected and cleared the code. I then started the truck three times and no problem, no code. Then I tried the remote start again everything was good. I then restarted the truck again with the key and still no light. I shut the truck off and got side tracked answering the phone and helping customers at work. (left keys in the ignition but not turned on) I came back out, jumped in the truck and the freaking light came on! I dont know want you mean by the X2-D3 fuse block connector. I looked for it but saw nothing marking which one it was. Please help this light is driving me nuts!
[center]2007.5 GMC SIERRA 2500HD WHITE6.6 DURAMAX LMMCREW CAB SHORT BED6" FABTECH LIFT35" DICK CEPEK TIRES20" AR BLK WHEELS[/CENTER
CMONTGOMERY325 is offline   Reply With Quote
Old 11-06-2009, 04:49 PM   eBay Motors   #24 (permalink)
GrimReaper
GrimReaper's Avatar
I sent an email with an attachment to the email address you have listed on this web site. i hope that will help clear up x2-d3, i took the information from the gm site today after work
2008 GMC 2500HD LMM
Old 11-06-2009, 07:52 PM   eBay Motors   #25 (permalink)
CMONTGOMERY325
I didnt get it. I'm going to pm you another address. Thanks in advance.
Old 11-06-2009, 07:53 PM   eBay Motors   #26 (permalink)
CMONTGOMERY325
Any other ideas?
Old 11-07-2009, 05:32 AM   eBay Motors   #27 (permalink)
cfox68
cfox68's Avatar
if you are sure the connector x2-d3 is tight, and it is resetting the p2610 code you have to replace the ECM. I have seen this before and it's having a hard time with the internal timer in the ECM .
But I have to say this has been fixed tightening the x2-d3 , It's on the firewall passenger side level with the battery. usually the left lug loosens up
Chris
Old 11-07-2009, 09:31 AM   eBay Motors   #28 (permalink)
GrimReaper
GrimReaper's Avatar
resent emails to both pm'd address's
2008 GMC 2500HD LMM
Old 11-07-2009, 04:39 PM   eBay Motors   #29 (permalink)
mkhristo
GM has become a horrible company!!!
GM as a company has become a huge pile of crap........... The dealers don't have authority to think, everything is done by instructions of GM. GM is pinching pennies and avoiding as much warranty work as possible. Yet another perfect example why one should go Japanese or German.
Originally Posted by CMONTGOMERY325 View Post
I have a 2007 GMC Sierra LMM CC. All stock, except lift and tires/wheels. (exhaust and programmer waiting to go on till the problem is fixed) So my check engine light is on. I have been into the dealer 5 times. The first four times they say its that the ECM needs replaced. They replace it under warranty, tell me my truck is fixed. I show up to get it and remote start doesnt work, walk over jump in and turn the key and the check engine light is on. I go inside, they act dumb founded and reschedule me for later in the week. So today I go in again, wait around for 2 hours and they say its done. I'm like so what was the problem? Service manager says "theres a new bulletin out and we overlooked it it says when reprogramming a new ECM it must be unplugged for 90 sec prior to programming, then started several times to make sure the codes are erased. We did all that and its fine." So as the service manager is telling me this while walking out to my truck with me I lock the truck with the key fob, hit the remote start, it fires up, he's like see all fixed, about that time the truck shuts off, he's dumbfounded, i open the door climb in and turn the key and the Freakin' check engine light is on again. By this time I'm pissed! I throw him the keys, walk back into the waiting room and sit down. About an hour later he comes back and says "I talked to the techs at GM and they say its a bunch of things I need to try to diagnose the problem and it could be a number of things, loose wire somewhere, bad battery, etc... which are not covered by your warranty due to the miles on the truck, the extensive process of diagnosing could take severalhours which you would be responsible for. I grab the keys, tell him how much bs this is and storm off.
If anyone else has experienced this or can tell me what options I have I would greatly appreciate it. Thanks!
mkhristo is offline   Reply With Quote
Old 11-07-2009, 05:54 PM   eBay Motors   #30 (permalink)
apelineman
apelineman's Avatar
the reason why america is where its at with thinking like that
07.5 chevy 2500 z71 ltz cc 5% tint all around
efilive tuned by husker
bye bye dpf and cat
sb intake
08 thundercat
05 honda rincon(wifes)(wifes bummin sold it)
08 ac 90 and 08 70 cc sazuki dirtbike(my boys whips)
my daughters tuning 2 so we will see what she gets
apelineman is offline   Reply With Quote
