Old 11-02-2009, 07:39 PM   eBay Motors   #1 (permalink)
CMONTGOMERY325
My Dealer is Retarded, Someone please help!
I have a 2007 GMC Sierra LMM CC. All stock, except lift and tires/wheels. (exhaust and programmer waiting to go on till the problem is fixed) So my check engine light is on. I have been into the dealer 5 times. The first four times they say its that the ECM needs replaced. They replace it under warranty, tell me my truck is fixed. I show up to get it and remote start doesnt work, walk over jump in and turn the key and the check engine light is on. I go inside, they act dumb founded and reschedule me for later in the week. So today I go in again, wait around for 2 hours and they say its done. I'm like so what was the problem? Service manager says "theres a new bulletin out and we overlooked it it says when reprogramming a new ECM it must be unplugged for 90 sec prior to programming, then started several times to make sure the codes are erased. We did all that and its fine." So as the service manager is telling me this while walking out to my truck with me I lock the truck with the key fob, hit the remote start, it fires up, he's like see all fixed, about that time the truck shuts off, he's dumbfounded, i open the door climb in and turn the key and the Freakin' check engine light is on again. By this time I'm pissed! I throw him the keys, walk back into the waiting room and sit down. About an hour later he comes back and says "I talked to the techs at GM and they say its a bunch of things I need to try to diagnose the problem and it could be a number of things, loose wire somewhere, bad battery, etc... which are not covered by your warranty due to the miles on the truck, the extensive process of diagnosing could take severalhours which you would be responsible for. I grab the keys, tell him how much bs this is and storm off.
If anyone else has experienced this or can tell me what options I have I would greatly appreciate it. Thanks!
[center]2007.5 GMC SIERRA 2500HD WHITE6.6 DURAMAX LMMCREW CAB SHORT BED6" FABTECH LIFT35" DICK CEPEK TIRES20" AR BLK WHEELS[/CENTER
CMONTGOMERY325 is offline   Reply With Quote
Old 11-02-2009, 07:41 PM   eBay Motors   #2 (permalink)
Hondarider552
Still on build 66 :)
Hondarider552's Avatar
well.....
whats the code ?
Old 11-02-2009, 07:56 PM   eBay Motors   #3 (permalink)
CMONTGOMERY325
Originally Posted by Hondarider552 View Post
well.....
whats the code ?
I have not seen it. All the deale rhas said is bad engine control module. Can I plug in the quadzilla S2 and read it?
Old 11-02-2009, 07:58 PM   eBay Motors   #4 (permalink)
Hondarider552
yes you can, their should be like a diagnostic feature in it to read DTC (engine trouble codes)
Old 11-02-2009, 08:19 PM   eBay Motors   #5 (permalink)
duramaxchris06
duramaxchris06's Avatar
if your not able to figure anything out with the QSII then id say take it to another dealer and have them run a diagnostics machine on it. You would be surprised at how dumb some of the people are that they hire in their service garages.
2006 Chevy Duramax LBZ 3500HD CC Dually LT3 4X4
4" turbo back exhaust, 5" pollished stainless steel tip,
Turbo Resonator plugged, FPRV Shim, & EGR Blocked
PPE Hot+2
Autometer Cobalt, boost and pyro
Painted front bumper, bowtie emblem, tow mirrors, and fender flares, Cadillac style handles, Recon Fire and Ice light bar, clear cab lights and 3rd brake light.
2008 emblems
Michelin LTX A/S 265/75/R16, 2" spacers.
duramaxchris06 is offline   Reply With Quote
Old 11-04-2009, 09:45 AM   eBay Motors   #6 (permalink)
CMONTGOMERY325
well.....
whats the code ?
Just hooked up the quad s2. The code is 2610. Any advice?
Old 11-04-2009, 09:52 AM   eBay Motors   #7 (permalink)
Buck
Buck's Avatar
whoa there first things first how many miles on this LMM?! becasue if its less then 100,000 i would drive it right back over there! DO NOT plug in that QS2 again!
Vehicle 2008 Chevy Crew Cab Short Bed
Tires & Wheels 285/75/R16 Load Range E BFG A/T's on Stock Rims
Suspension Cognito UCA kit with Bilsteins all around from Nick at Nor-Cal Truck
Drivetrain LMM Duramax, Allsion 1000 Transmssion
Performance Mods RBP downpipe back exhaust (no CAT or DPF), TransGo Jr, Mag Hytec transmssion and rear end covers, PPE Hot+2 Race LMM tuner (160hp setting), PPE Air Box Mod, Resonator Blocked, Auto Meter GS Boost, EGT, and Transmission gauges, Auto Meter triple pillar with speaker cutout. all from Tyler at Meyer Performance & Fabrication, LLC
Other Mods B&W Turn Over Ball, Air Lift Bags, Wether Tech FloorLiners, SpeedLiner spray in bedliner, debadged whole truck except bow ties and D-Max/Allsion logo
Buck is offline   Reply With Quote
Old 11-04-2009, 09:55 AM   eBay Motors   #8 (permalink)
maxthis
maxthis's Avatar
ECM/PCM Internal Engine Off timer Perf
(thanks to Huskers niffty Xcel file that I have saved on my desktop)
Whatever that means.....
04.5 LLY 68,000 miles and not a problem one!
-6" superlift
-35x12.50 Toyo MT's on 18" Ultra Predators
-PPE standard, shim kit, egr and resonator blocked
-4" banks turbo back and 5" MBRP miter cut stack
-AFE mouthpiece, K&N Stainless intake
-full Transgo shift kit
-weld in gooseneck plate
-Cowl hood, spray in bed liner
-Suncoast, DSP5, lift pump an possibly a turbo after harvest!
maxthis is offline   Reply With Quote
Old 11-04-2009, 09:57 AM   eBay Motors   #9 (permalink)
mijdirtyjeep
mijdirtyjeep's Avatar
Code B2610=Passenger compartment dimming 1 circuit
Code P2610=ECM/PCM Internal Engine Off Timer Perf
Is it a B or a P at the beginning, assume a P case it shuts off.
Jim
4" Magnaflow Exhaust
Modified factory air box
Ported Turbo Horn
EFI LIVE V2
mijdirtyjeep is offline   Reply With Quote
Old 11-04-2009, 11:04 AM   eBay Motors   #10 (permalink)
CMONTGOMERY325
It has less than 100,000 miles, but not for long. The dealer has supossedly replaced the ecm and reprogrammed it. I call BS. I turned the code of with the QS2 but as soon as I started the truck it came back on. As this also happens when the dealer says "its fixed". Also dont know if this matters or not but the remote start will not work as long as this code is on. No performance problems just want the freakin light off and the remote start to work.
