When to plug-in - Chevy and GMC Duramax Diesel Forum
post #1 of 86 (permalink) Old 12-02-2009, 06:19 AM Thread Starter
When to plug-in
I was just wondering when everyone starts plugging in there diesels in.I live in the Boston area and usaly only plugged in when very cold,only if I thought it would have trouble starting.But a guy I know starts just after Thanksgiving every day unless theres a warm spell to avoid cold start wear in the motor.Do you guys think it is worth the wear on heating element and expence of electricity to run every night to avoid cold start wear from happening.Mabey we should do a poll to see what everyone likes,if I only knew how.
jmac5058 is offline
post #2 of 86 (permalink) Old 12-02-2009, 06:37 AM
loners's Avatar
My rule of thumb is when it gets down between 32-23f(0--5c in canada) I start plugging in. It helps the cab air warm up faster and it is easier to start. Just use a timer and have it come on about 2-3 hours before you normally leave and you'll be fine. Some guys have reported a cel after having it plugged in all night due to coolant temp differing from engine temp iirc, so just use a timer and you'll be fine.
05 cc/sb slt, leveled w/285's, Ultra peacemaker rims, delta toolbox, PPE standard, 4" mbrp w/cat delete :rockin egr block, pvc rerouted, skull foglamp covers:rockin http://www.huskerdiesel.com http://performancetruckproducts.com
loners is offline
post #3 of 86 (permalink) Old 12-02-2009, 07:51 AM Thread Starter
Thanks I like the timer idea that sounds much economical and less wear and tear.An doing it from freezing and below is good to go?
jmac5058 is offline
post #4 of 86 (permalink) Old 12-02-2009, 08:24 AM
duratothemax's Avatar
you can plug it in anytime its below freezing but by no means is it "mandatory"
Mine starts fine in -20* (f) without being plugged in...takes forever to get any heat though.
ben
06 audi S4, V8/6spd
05 dmax/allison...always testing something new
-BT DieselWorks, LLC-
[SIZE="3"]Specializing in a wide range of custom electronics and great gadgets for your 2001+ GM full size truck/SUV
Allison torque converter lockup controllers, Allison Tap-Shift kits, digital DSP-5 switches, affordable injector harness repair kits, and much more!
duratothemax is offline
post #5 of 86 (permalink) Old 12-02-2009, 08:26 AM
just as an example here is my truck at -7* (f) starting up. The whining is the power steering pump.
sitting outside all night, not plugged in, ONE battery (everyone thinks they need two batteries to start/run), lower than stock compression etc.
http://www.youtube.com/watch?v=6iA72Mzv9ek
06 audi S4, V8/6spd
post #6 of 86 (permalink) Old 12-02-2009, 08:46 AM
BIGON's Avatar
That just looks way to cold for me. But I do live in the south, if it gets 25* here people thinke their going to die.LOL
2005 LLY CC SB 4X4 Ranch Hand Bumpers, 265/75/16 BFG'S A/T'S, EGR Blocked and FingerSticked, MB Gunner 8 Wheels, Banks 4" Monster Exhaust with MBRP Cat Delete Front Pipe, AFE Bladerunner MP, PCV Reroute, All Lights ON Mood, Nicktane CAT fuel filter, AirDog 100, Amsoil Fluids and more go fast goodies soon!.
BIGON is offline
post #7 of 86 (permalink) Old 12-02-2009, 10:24 AM
DuraMac's Avatar
Send a message via AIM to DuraMac Send a message via Yahoo to DuraMac Send a message via Skype™ to DuraMac
The bible says below 0 F / -18C and for a minimum of 4 hours, minimum of 8 hours if below that. If above that sometimes you can throw a P0181 which is a warning that the conditions are ripe for fuel to gel. To avoid the P0181, they say best thing if not too cold is warm it up running for a few. There is a few variables to set a P0181
DMax BLACK '05 LS CC LB @ 100K miles, factory 2" lift, HID's
Banks Economind, IQ, Intake, SpeedBrake, Boost Tube, Monster Exhaust
Other AFE MP, Amsoil & Bypass, Ameriguard spray-in liner, Leer Cap, Bed Rack, Bug Guard, Inverter.
Crap Iron Cross Automotive Nerf Bars - NOT RECOMMENDED!!
Helpful Helm GM Service Manuals - like... 9000 pages!!
Rescue VHF Radio, Jotto Desk Laptop command center, Rescue Gear, Lotsa Flashy LED's, Shinny Decals
Haulin B&W Turn Over Ball & Companion, Firestone Ride-Rite Air Lift Bags, '14 Heartland Warrior Toy Hauler, (12000lb dry), Kayaks, Harley
DuraMac is offline
post #8 of 86 (permalink) Old 12-02-2009, 10:27 AM
Banned
plug mine in pretty much everyday now since it's getting cold here. Was 39* this morning at my house and I park outside. Also rigged up a windter front cover.
Hondarider552 is offline
post #9 of 86 (permalink) Old 12-02-2009, 10:37 AM
maxthis's Avatar
Send a message via Yahoo to maxthis
Seriously! how cold does it get out there?
I haven't dug for my plug yet this year..she has been sleeping inside the garage though and hasn't been out for about 3 weeks. Last year there was a couple nights here that I had it in the heated garage to thaw out and plugged in to keep it warm....it was bad for Indiana. -degrees for a few days in row.
04.5 LLY
-68mm Cheetah w/ 4" dp
-DSP5 and G-Max5/1058 by Fleece Performance (473/871)stock turbo
-Leveling kit, 33" ATZ's 18" Ultra Predators
-shim kit, egr and resonator blocked
-Cognito Braces, PPE tie rod sleeves,60" traction bars
-4" banks turbo back and 5" MBRP miter cut stack
-AFE mouthpiece, K&N Stainless intake, AirDog 150
-Cowl hood, spray in bed liner
maxthis is offline
post #10 of 86 (permalink) Old 12-02-2009, 01:46 PM
Its just a worktruck
DMAXchris's Avatar
I plug mine in when its below 20. It starts fine without it, but I like having heat within a few minutes.
06 LBZ EC/LB 4x4
Built Motor/Trans Bullseye s475/87/.9 45% Injectors Stock CP3 Built and Tuned by Blackout Performance 11.76 @ 115
DMAXchris is offline
