I think my 05 Duramax gelled up - Chevy and GMC Duramax Diesel Forum
post #1 of 21 (permalink) Old 12-14-2009, 12:49 PM Thread Starter
It has been pretty cold the last few weeks (-20) and my truck gelled up. I tried to start it after it sat outside for 10 hours and it will crank good, but won't turn over. I pulled the truck in my heated garage and let it sit for three days, then I replaced the fuel filter. It will crank, but still won't start. Before this happend i hadn't had any problems in the cold. I didn't put any additives into it, just the winter blend from the fuel station. Any ideas?
mike128329 is offline
post #2 of 21 (permalink) Old 12-14-2009, 12:51 PM
what fuel additives have you put in?
03 LB7
Autometer c2 Pyro & Boost gauges
Remote start
T-bars cranked
4" straight pipe
resonator destroyed
h2 wheels, 315/70/17 rover maxx traction
superchips tuner
More on its way!!!
silversamps85 is offline
post #3 of 21 (permalink) Old 12-14-2009, 12:55 PM Thread Starter
No additives, I know stupid, but it's not normally that cold here.
post #4 of 21 (permalink) Old 12-14-2009, 12:57 PM
Administrator
ob_1jr's Avatar
:welcome to the forum!!
Did you bleed the filter? Normally the fuel wont gel as long as the area you are uses winter blend. Being that it was that cold there, i am more than certain that you have winter blend.
2016 GMC Sierra 2500HD Denali
Extang Blackmax Tonneau
X-pel clear bra
SOLD 2004 GMC Sierra LB7
ob_1jr is offline
post #5 of 21 (permalink) Old 12-14-2009, 01:01 PM Thread Starter
Yes, I bled the filter, and they do winter blend the fuel, but it's only rated at -10 and it was getting down to -20.
post #6 of 21 (permalink) Old 12-14-2009, 01:07 PM
Administrator
ob_1jr's Avatar
That doesnt matter...even when i treat my fuel it can get colder than what it can be rated for. I have seen -56F with no gelling and my truck was parked outside the whole time. My buddy had a fuel heater that didnt work and he wouldnt gel until it was -40F or colder.
How much fuel is in your tank?
X-pel clear bra
ob_1jr is offline
post #7 of 21 (permalink) Old 12-14-2009, 01:23 PM Thread Starter
half a tank, someone also told me they were cheating and not really adding anything to the fuel to cut costs. I don't know if that's true.
post #8 of 21 (permalink) Old 12-14-2009, 01:25 PM
Administrator
ob_1jr's Avatar
ok...have you verified there is still fuel in there? Also, you did get fuel out of your bleeder screw right?
X-pel clear bra
ob_1jr is offline
post #9 of 21 (permalink) Old 12-14-2009, 01:30 PM Thread Starter
I thinks so, when I primed it till it wouldn't push down anymore, then when I opened the bleeder screw just a bit, diesel sprayed out the screw. When I tried starting it, I could go back and prime till it wouldn't push anymore. not sure if that means anything, sorry for the incompetence.
post #10 of 21 (permalink) Old 12-14-2009, 01:32 PM
Administrator
ob_1jr's Avatar
you need to open the screw and pump it until fuel comes out and then tighten the screw. It will come out solid with no bubbles...then try to start it.
X-pel clear bra
ob_1jr is offline
